i may have a buyer for them Carl, ill let you know
cheers damo
let me know ;)
carl, i have a couple of pairs of standard s3 headlights if ya get stuck alright ;)
might hit ya up on that. if so ill bring it down. has no screamer tho YET. :(
Compaq Presario CQ61-107TU Notebook PC (NW982PA)
RRP is $999. Brand spanking new in box, not even opened or touched. Ill let it go for $800, FIRM.
Specifications can be found here. http://h10010.www1.hp.com/wwpc/au/en/ho/WF...29-3938413.html
PM me or email: [email protected]
$750
Compaq has released a new version of this laptop, pretty much same hardware/software. Both running Vista premium. new model is CQ61-214TU, rrp $999. asking price dropped accordingly
eoi
willing to trade for some different rims if anyone is interested send me sum pics with sizes and offsets.
mine are starcorp impuls 18x8.5 and 9.5 (+38 i think) with near new tread. silver face and dish.
must fit skyline studs. cheers
All parts are located in Adelaide. All prices are for local pick up. can post at buyers expense.
Work Xd9's
front 17x8.5 +25 with 215x45 tyres, in good condition
rear 17x9.5 +17 with 235x45 tyres, camber wear from previous owner.
comes with a set of new blue anodised work wheel nuts in box.
$2100 with tyres and wheel nuts
Malpassi rising rate fuel pressure regulator
brand new, never used comes with brass barbs
$120 ono
Fuel Swirl pot.
custom made 3 10mm lines, 1 12mm line (284mm x 70mm)
from memory, its TTr2xheight= capacity. all the important info is there for you to work out total capacity.
$100
S13 washer bottle
in good condition, can get more pics on request
$30
Also have an Apexi AVC-r stand.
mine got taxed. no need. also got box if someone wants that with the stand?
$50
Genuine Titanium muffler
some scratches. came off Uncle Marky's (Exhaust technology) S15 when it was yellow. comes with 3inch pipe clamp.
$150
T25G from redtop SR with manifold and dump
no back to front movement
alittle side to side.
$120
any further questions or requests for more pics via PM please.
Cheers
Wil
Hey guys want this stuff gone asap.
Metalic Silver Fibreglass bonnet for R32...exactly the same as in pic but fibreglass instead of carbon fibre - $400
Full 6 point Cusco roll cage for R32..immaculate condition - $850
Cusco front strut brace for R32 - $150
ISC rear camber arms for R32 - $150
Veilside 1 piece seat with R32 rails and harness...not willing to separate rails. Will bolt straight in - $400
If ya interested send a txt and il txt u pics because i cant get on here all that often.
Cheers,
Chris
0400 259 598
Cearing out the garage again in time for the new project
r32 front heater core, all air con piping and air con pump with bracket. basically everything u need.. $140 ONO
rb20 alternator. $40
rb20 crossover pipe with bov. $80
standard rb25 engine mounts with no bushes. $25
rb20 rubber intake pipe. $25
rb20 turbo. was leaking a bit of oil but minimum shaft play $60
rb20 front fan, not sure wat its called, runs off the engine. i think its called clutch fan? with the plastic cover around it but covers got crack up top. $40
rb25 standard clutch $25 or if u want a week ill have a flywheel aswell and u can have both for $90
rb20 exhaust manifold. looks ok condition. $25bux
some random blue/black drift brand steering wheel. good condition $15
txt or ring me on 0428851616 or pm me
cheers
Hey guys got a HKS GT25/35 for sale.. was going to put it in my skyline but lost interest in the car... so this turbo upgrade has to go.
HKS GT25/35 bought it of a member on SAU not long ago.. comes with dump pipe and stainless steel intake pipe to pod. doesnt come with any lines.. the turbo has very very little - no shaft play but every ball bearing turbo has a tiny bit shaft play, correct me if im wrong. looking for quick sale $1200!
no need for pics you all know what turbos look like. located in paralowie.
Got the following for sale:
KTS Tie Rod Ends, pillow ball suitable for A31, C33, R32 and R33 (RWD) - $100
Looks like so but filthy dirty as its been on my car:
Cusco Type OS front strut bar for an R33 - the blue end plates have been sprayed black therefore it is now standard and not an aftermarket mod - $100
Expressions of Interest
Group Buy - Siemens Deka fuel injectors
I ordered 6 injectors from Miami last fortnight and they arrived here in rapid time. Ended up costing me $360 for a set of 6 575cc injectors for my RB26dett (low impedance, top feed). A couple of members here are considering getting new injectors, so I was wondering if anyone is keen to join the purchase and maybe get a discount (maybe... $360 is pretty cheap as it stands, as it's half as much the australian distributors want for the exact same injector).
Sizes are from 300-1300cc, top feed only but either low or high impedance
PM me if you're interested - this is a once off and I won't be doing a repeat order.
-D
EDIT - He does do RB25 Neo injector top feed conversion packages for around $600 that include a fuel rail, 850cc injectors, ev6 and ev1 adaptor and seals
Am placing orders on Wed. Pm me asap if you want in on this order
-D
Following for sale...
A GReddy, two gauge A-pillar holder (60mm) to suit 33 GTS-t/GTR. Bought it not too long ago to fit my new Defi's in but ended up mounting them on the dash using the stands. Perfect condition, nothing wrong with it. I only ask what I paid for it, $100
SOLD
tie rod ends sold pending payment
strut bar still got sale........
Ceffy headlights S1 - $150
Ceffy Tail lights S1 - $100
Non hicas cradle - $150
all rear stock suspension arms - $50
SR X member - $80
S13, A31, R32 steering rack - $70
Stock S13, A31 suspension - $250
Front LCA's - $50
Rear LCA's - $50
stock castor rods - $50
complete ceffy interior - $100
R32 rear seats, m spec series - $50
A31, maybe R32 steering shaft - $100
ignition barrel with key and wiring (great if your car been broken into) - $75
ceffy front guards - $120 pair
ceffy rear window - $250
R32 lhr tail light - $40
R32 crash pad (dash) - $70 (1 or 2 bubbles in it)
SR20DET starter motor - $50
A31 BMC with booster - $60
A31 clutch master cyl - $40
A31 clutch slave cyl - $20
RB20DET intake manifold, complete with rail and injectors - $140
RB20DET injectors - $60
RB20DET head - $150
RB20DET coilpacks - $150
R32GTST pedders suspension lowered to 340mm eyebrow height - $250
ceffy front rad support, great for crashed car - $100
ceffy doors with glass and all electronics - $75 each or $250 for all four
call or sms on 0417 084 405 or pm me
i have lots more R32 interior panels aswell
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
