For Sale/Trade
6 x Nismo 740cc sidefeed Injectors
Have been cleaned and flow tested - all 100%
Currently installed in my car (RB25DET S2), am wanting to either sell for $850 ono...or Trade for 6 (Six) Nismo 550cc Sidefeed Injectors that have also been flowtested.
Pm for more details.
Part are located near Mitcham
Suspension/Steering
R32:
2x Front Sway Bar - $50ea
1x Front Complete upper control arm assembly (passenger side) including bracket and king pin bearing, urethane bushing - $100 -- PICS PICS
2x Front Camber Arms - $40ea -- PICS
2x Front Passenger side Lower Control Arm - $60 -- PICS
1x Front Tie Rod End - $10 -- PICS
2x Rear Traction arms - $35ea -- PICS PICS
2x Rear Camber arms - $35ea -- PICS
2x Rear Lower Control Arms - $60ea -- PICS
2x Rear sway bar links w/ Urethane bushes - $15ea -- PICS
2x Rear Hubs - $100ea -- PICS PICS
1x Rear Sway Bar - $50ea
2x Rear Toe Rods (non-hicas) - $35ea -- PICS
S13:
Misc
R32
1x Horn, can be hooked up to any car - $20 -- PICS
2x Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
1x Stock Rear Spoiler (with brake light) - $50 -- PICS
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x RB20 Fuel Pump - $40 -- PICS
1x Igniter Module (breaks down under a lot of heat) - $30 -- PICS
Random shit
1x Handbrake lever - $5 -- PICS
5x Hub Covers - $20 -- PICS
Stagea/33/34 radiator ... 64,000kms old .... good condition ... $150
Malpassi FPR ... used condition ... noisy on start up and hard to adjust ... don't know much about them sorry ... $50
Stagea in tank fuel pump ... 64,000kms old ... works well ... $80
R33 4 door Skyline ... 133,000kms ... runs great ... $8,500
PM me
:sick:
Expressions of Interest
Group Buy - Siemens Deka fuel injectors
I ordered 6 injectors from Miami last fortnight and they arrived here in rapid time. Ended up costing me $360 for a set of 6 575cc injectors for my RB26dett (low impedance, top feed). A couple of members here are considering getting new injectors, so I was wondering if anyone is keen to join the purchase and maybe get a discount (maybe... $360 is pretty cheap as it stands, as it's half as much the australian distributors want for the exact same injector).
Sizes are from 300-1300cc, top feed only but either low or high impedance
PM me if you're interested - this is a once off and I won't be doing a repeat order.
-D
EDIT - He does do RB25 Neo injector top feed conversion packages for around $600 that include a fuel rail, 850cc injectors, ev6 and ev1 adaptor and seals
I'm extending this offer for cheap injectors indefinately. Seems I've come to a good understanding with the distributor in the USA who is more than happy to continue selling injectors to us.
I can get any size injectors, from 300-1300cc, both low and high impedance, both top and side feeds. Can obtain injectors for any Nissan and Toyota engines, as well as GM V8's.
Note, I will not be making any money of this venture, however any orders placed individually will incur a higher cost for shipping.
Prices range from around $360* for 550cc injectors up to $500* for the hardcore 1000cc multi nozzle injectors (set of 6 - can also do sets of 4, 8, 12 or whatever you require)
If I get enough interest, I'll purchase stock for emergency use/quick sales.
PM me if you would like more details. Current brands sold so far are Siemens-Deka, Lucas and Delphi. Technical specifications are available upon request, and all injectors are flow matched within 1% tolerance of each other.
-D
*** Please note that these prices are estimates based upon the last 3 orders I've placed at the current exchange rate with the US dollar. They may rise or fall given the strength of the greenback vs the AUD.
got some whiteline urethane subframe bushes (pineapples) out of my car that i dont need anymore. for anyone who doesn't know these tighten up ur rear end without making it harsh, awesome solution for street cars, reduces axle tramp and lets u align ur subframe for squat, neutral or anti-squat.
according to the whiteline site, these will fit most nissans, S13/S14/S15 R32/R33/R34 GTS, GTR etc etc Ceffy, laurel etc etc even N14 pulsars it seems.
Price:
$80
Pics:
Items:
Dual Solenoid Blitz SBC Spec R Boost Controller
Item Condition:
Used, Good.
Extra Info:
Upgraded to SBC ID-III, this is wasted sitting in a box :wave:
Contact Details:
PM me.
Price and price conditions:
$280 + Postage (Or pick-up)
Items:
RAYS Engineering Dura-Nuts in Blue, Normal length type.
Item Condition:
Used, Average (Rattle Gun damage.). See pic.
Extra Info:
These are still on my car, which is at the body shop. I expect the car back from the body shop at the start of next week. I am upgrading them with the same nuts, in the Long type. There are no lock nuts with these, just 20 Rays wheel nuts, they retail on JustJap.com store for $275... shoot me an offer :(
Contact Details:
PM me.
$90 + Postage (Or pick-up)
Lilliput 629GL 7" VGA Touchscreen for CarPC in double din mount - $290, might consider swap for decent single din headunit.
Original box, stand, remote and casing included.
Dimensions of double din mount:
Width: 177mm
Height: 107mm
Depth: 71mm
Touch Screen: four-wire resistive touchscreen
Inputs: 1 VGA input and 1 RCA input, 1 AUDIO input
Built-in Speaker
Infrared Remote Control
Input Voltage: DC 11-13V
Power Consumption: <8W
Screen size: 7 inches diagonal
Physical dimensions (in): 7.33W x 5H x 1.5D
Ratio: 16:9 wide TFT screen
Native Resolution: 800x480
Resolution Range: 640x480 up to 1280x1024
Dot Resolution: 2400 x 480 (= 1,152,000 dots)
Color configuration: RGB stripe
Video system: PAL/NTSC
1 Video input plus 1 Audio input
VGA input
Touchscreen display (USB interface)
IR remote control
Full function OSD control (Multi-language)
Audio output: Speaker built-in
Video input signal: 1.0Vp-p, composite video
High resolution and no radiation
Computer display/S-video/DVD/VCD/Security system/Navigation system compatible
(Rear view camera connectible)
Mount type: Dash board
Power input: DC 12V
Width: 177mm
Height: 107mm
Depth: 71mm
Built-in Speaker
VGA input
IR remote control
Power input: DC 12V
You have to sell this when i have no money :)
Price:
$80
Pics:
sold
I have a Apexi Power Fc for sale to suit a 1993,94 R32 Gtr & R33 Gtr no hand set . $850 .
good option for RB25 guys also, i currently run a GTR pfc pro in my RB25det
Shaun at boostworx knows the wiring up procedure to have a hybrid ecu
I guess you'll also be happy to hear that it's sold :down:
You can grab all the gear from mp3car and bybyte when the time comes, it'll be closer to $400 to get everything new though ;)
