For Sale Thread
Cubes
Xmas specials
- Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW & Custom Braided lines oil restrictor and custom turbo drain etc
Also comes with new 19psi actuator, and hks alloy hard out let elbow to suit. $1700
- Trust Side mount intercooler (uses short piping and goes back into stock piping) $350
- Z32 AFM with plug $200
- SARD 850cc side feed injectors in rail with clips and loom all soldered in $750
- Yellow Jackets coil packs $280 suit r33 series 2
- Apexi Power fc + Apexi Commander with 300kw tune $1300 suit r33
- BLITZ Sbc ID3 SPEC-S Electronic Boost Controller $350
- Nismo 400r Sideskirts suit r33 $200
- Rda slotted rotors & QFM-k750 hight temp pads $400
For sale:
- Nintendo DS Lite, black, brand new unwanted/not needed prize - $100
- HICAS unit, came off a 1998 R33 Series 2 - $50
Also got:
BenQ E2200HD - near new condition - $100
has HDMI input, 22" widescreen, built in speakers etc
Up for sale is my 1995 R33 Series 1.5 Mspec 5sp manual makes 300kw on 18psi
Will make 350rwkw easy with more boost and e85
Price: $19,500 ono
Modifications:
Stock internally rb25det series 2 engine
- Tomei adjustable exhaust cam
- Garrett GT35 Turbo with 0.5 front cover and 0.82 rear IW
- Hpi stainless exhaust manifold
- Metal exhaust gaskets
- Custom Braided lines and turbo drain
- 3.5 "Bell mouth dump front pipe
- 3" Stainless Mandrel Bent Magnaflow cat back exhaust
- 3" Decat
- Silicon Hard intake pipe
- Pod Filter
- Silicon hoses and lines
- Trust FMIC
- Z32 AFM
- SARD 850cc injectors
- Bosch 044 fuel pump
- Exeddy Gtr Cerametallic Clutch Kit
- Lightened Chromolly Fly wheel
- Pro-Stopper Series 5 Alarm
- Triplex Immobilizer
- Head Unit - Eclipise 50x4 CD5444 CD/MS Receiver with MP3/ATRAC3
- Pioneer 6" 4way 280watt fronts
- Kenwood 7x10's 350watts
- Nismo Clear Side indicators
- Kenwood 600w Amplifier
- Kenwood 600 sub
- KYB Coil Overs
- 18" x 9.5 Dtm rush wheels stretched 235's front, 255's rear
- 20% Tinted Windows
- Twin K&N oil breathers
- Water methanol injection
- QFM-k750 hight temp pads
- Custom engineered hicas lock system
post-31991-1259112659_thumb.jpg post-31991-1259112677_thumb.jpg post-31991-1259112687_thumb.jpg post-31991-1259112698_thumb.jpgpost-31991-1259112760_thumb.jpg post-31991-1259112837_thumb.jpg post-31991-1259112876_thumb.jpg
Now 16.5K with stock r33 wheels with semis
r33 series 1 after market front grill (GTR style like the one Talbo was selling a while ago but with the screw tabs)
currently the grill is painted in Wine red
$40 or swap for a standard series 1 grill that is painted black
r33 series 1 coilpacks $120 ono
Danai 0402541975
For sale:
stock r33 dump & front pipe - $30
stock r33 rims and tyres - 2 off - $25 each
r32 seats rear - $250
r32 seats front - $250
r32 gtr gearbox - $500 ono
pickup
gearbox says HXB Nabco japan
pretty heavy tbh, lol. no knees, I could feel it :banana:
Xmas specials
Damn i cant pm yet, but my afm is green and im pretty sure 1993 would be series one
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
