that was quick lol 3hours....
seen it there when i picked up the gtr. was in mint condish. would have been worth paying for. even a bottle would have been suficient. now i just got to modify the gtr box so it can be installed into the 31.
if it aint broke dont fix it...
hmmmm my motto.
but im always breakin stuff.
hmmmmm
Gt3540 + Stainless Manifold + 3" Intake + 3.5" Dump Front
good for 350-400rwkw, turbo was bought from ATS( Adelaide Turbo Services) 3 months ago can call Bill to confirm.
$2500
-Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW, comes with Custom Braided turbo feed line, oil restrictor and custom turbo drain, water banjos etc
and 19psi actuator, also included is an hks alloy hard out let elbow to suit. Id CHRA is 706451-24
-Tune length low mount stainless manifold
-3.5" Bellmouth dump front pipe & catless pipe
-3" Silicon with alloy connector intake pipe
post-31991-1262941091_thumb.jpgpost-31991-1262941134_thumb.jpgpost-31991-1262941146_thumb.jpg
post-31991-1262941158_thumb.jpgpost-31991-1262941196_thumb.jpgpost-31991-1262941206_thumb.jpg
Water Methanol Cooling mist setup suit skyline r33 in excellent condition, kit is wired up ready to bolt in
$400
Includes the following:
Modified r33 skyline washer tank (also spare new trunk mount tank)
BLACK 150 psi pump
3 meters high pressure hose
Brass fittings
World class brass checkvave rated at 600 PSI and over 300 F
Injector that installs from the OUTSIDE of the pipe
Injector holder
Relay
Relay Harness
Fuse
Fuse Holder
boost switch adjustable from 1-25 psi.
various electrical connectors
Also comes with new spare tank and fuses/relays
R33 cross over pipe drilled and tapped
post-31991-1262941391_thumb.jpgpost-31991-1262941456_thumb.jpgpost-31991-1262941473_thumb.jpg post-31991-1262941573_thumb.jpg
Sard 850cc side feed injectors rb25det
come in fuel rail with fuel regulator, injector o-rings, collets, injector loom with clips soldered in and modified clips to suit, all bolts straight into rb25det, only 2 months old!
$800
Apexi Power Fc + Hand Controller Suit R33 RB25det
Comes with 310rwkw tune to suit rb25det with, 3.5" exhaust, gt35, z32 afm, sard 850cc injectors
$1300
Edited by FOOLBOOST
Hi guys,
Have the following for sale. Pickup preferred, unless you want to organise postage / courier.
17 inch Tyres + Rims
4 x Yokohama Advan Sport V103 (255/40ZR17 94Y) very good tread $800 (+$1600 new!)
4 x Bridgestone RE55s (255/40R17 94W) a couple of track days left in them $400
4 x Bridgestone RE55s (255/40R17 94W) 60 - 70% tread $800
4 x Dunlop V8 Supercar Slicks (280/680R17) 40% tread $400
4 x R33GTR Rims only with centre caps, reasonable condition a few marks $1100
RB26 Engine bits
Greddy Carbon Engine Cam Valley / Timing Belt Cover $300
R32 GTR Aircon Setup (everything aircon forward of the firewall, excellent working condition prior to removal for weight reduction) $100
Trust MX Front Pipes (goes from dumps to cat) dent in standard spot $250
RB26DETT Plenum / Inlet Manifold / Exhaust Manifold (6 Total) Gaskets Brand New $100
R32 GTR Clutch Slave Cylinder (good condition, upgraded to nismo oversized due to triple plate clutch) $40
2 x AFMs excellent working condition mesh not removed (removed due to D-Jetro) $100
RB26DETT standard dump pipes $50
Jap retuned standard computer (no speed cut, car made 270rwkw with standard engine/ turbos etc and this computer) $300
Misc
Nismo genuine boot spoiler internal damage but should be repairable $50
Earls Oil Stat – installs into oil cooler circuit to thermostatically control oil temp. Dash 10 fittings for easy installation. Also has ports for oil temp and pressure senders. See http://www.earls.co.uk/earls/catalogue/Cooling%20Systems.pdf PART # 501ERL $200
R32 GTR Silk Road Coilovers typical hard jap spring rates $400
Sub Box, fits 2 x 12 inch subs in R32 boot WITH rear strut brace. Made from 16mm MDF, including fittings $50!!!
R32 GTST Type M Driving lights fit in Type M front bar $50
RB25DET Alternator and Aircon Compressor Good condition $50 each
Low Ballers will be ignored, genuine offers considered. First in, best dressed and items not considered sold until payment received or pickup arranged. Get in on some bargains and help de-clutter my garage! Pics to come once the temp goes south of 40degC.....
Cheers,
Andrew
Blue32
Edited by Blue32
FOR SALE:
KTS Adjustable Tie Rod Ends - suits R32, R33, Cefiros and S14 - $100 - like these ones here
pair of R33 GTR standard side mirrors(complete in housing, wiring, mirror etc) in white, fits GTST or GTR - $50
Hi guys,
RB26 Engine bits
RB26DETT Plenum / Inlet Manifold / Exhaust Manifold (6 Total) Gaskets Brand New $40
Misc
Cheers,
Andrew
Blue32
pics added: Click here
NOW SEPARATING KIT
Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW, comes and 19psi actuator Id CHRA is 706451-24
$1600
Custom Braided turbo feed line, oil restrictor and custom turbo drain, and water banjos suit gt30 gt35
$150
Hks alloy hard out let elbow 2”-2.5 outlet” with silicon joiner and clamps to suit gt30 gt35
$120
Tune length low mount stainless manifold suit rb20det rb25det
$300
3.5" Bellmouth dump front pipe suit gt30 gt35
$350
3” catless pipe
$80
3" Silicon with alloy connector intake pipe and clamps suit gt30 gt35
$100
Sparco Bonnet Pins
$40
Billet Coolant Temperature Sensor Adaptor
$30
Car:
PowerFC (R32/33 GTR) + hand controller $850
2x Motul 4l 300V Chrono Oil $75 each
stock 32 GTR turbos $200
stock GTR injectors (new revision) $200
stock 32 GTR cam gears $40
stock 32 GTR harmonic balancer $20
stock 32 GTR dumps $20
Trust oil cooler (150mmx300mm) - use on engine oil at own risk, was in a car that spun a bearing $40
Computer:
4x tressels, white (1.8m x .7m) $50 each or $150 for all 4
1x satelite dish $50
Random:
Poker chips, 500 peice $40
DVD Box set series 1 of WPT $30
Scrubs Box Sets: $50 for all 3 or -
Season 1: $20
Season 2: $20
Season 3: $20
Futurama DVD Box Sets: $50 for all 3 or -
Season 1: $20
Season 2: $20 Unopened
Season 3: $20 Unopened
all i can think of atm.. PM me, all prices are pickup, happy to post at buyers expense
updated some prices, pics and details of pfc are here http://www.skylinesaustralia.com/forums/R3...nd-t303301.html
hey lads i have some wheels i need to sell they are 17 inch, with good tread, plenty of rubber, the fronts are 215/50 and the rears are 235/45, i must sell them i need money, $400 ono, im easy, just let me know cheers 0430 400 138- adam, call anytime, , there are photos in attachments!
