ok guys,
r33 S2 turbo, comes with elbow. veryvery minimal shaft play. $300
rb20det top feed Stock injectors. $100
r32 iondicators, one clip broken $70
r32, r33 bellmouth dump/front pipe to cat. $100
radiator (calsonic) $100
Adjustable R32 strut brace. $100
TRS 4 point harness in perfect condition - $150ono
10,000k HID kit. Bought used but in good working condition for my s13 track car never got around to fitting it - $170ono
could be keen, 10,000k is on the blue side of things yeah?
falken ZE912, 235 45 17
BRAND NEW,
$200 each
R32 gtr front bar copy
$100
r32, s13, a31 pineapples
$50
s13, r32, a31 stock castor rods, not leaking
$40
RB20DET stock turbo and manifold
$200
RB20DET intake manifold, complete, with throttle, injectors, rail
$100
34mm spacers, with nuts included
$100
ALL prices negotiable
0417 084 405, sms only
Edited by JD_CEF
Swiss Hutless Shifter Kart
Kart Is In Good Condition.
Just needs a 2stoke moto engine or a big thumping 4stroke.
Rolling Frame Ready To Drop A Bike Engine In As I Intended To.
Clutch And Shifter Set Up Ready To Go.
New Seals In Master Cylinder, Brakes Bled Ready To Go.
Has Chain And Sprocket Ready For A Bike Engine.
Lost intrest in a lil project i was going to do.
$400 ono
PM sent.
Very interested now. Got approval from the missus to inspect. :blink:
RB20 standard exhaust manifold $50
rb20/25 standard flywheel, needs a clean $30
standard dump pipe, 2x farmers union iced coffee's
got a fair bit of other standard shit for an rb20 also, just cant remember off the top of my head, pm me with
what your after..
1998 R34 4 door sedan
RB25DET NEO engine
167,xxx kms
Tiptronic trans
3" turbo back exhaust with HKS muffler
Greddy FMIC kit
Apexi POD filter
Turbosmart bleed valve set at 10psi
Pedders lowered springs
Traction control
Climate control
ABS
VLSD
Air bags
HICAS
Nissan flooormats
Kenwood DVD/MP3/DIVX player connected to nissan satnav screen (screen not currently working due to a dodgy wire)
Viper 5900 pager alarm/immobiliser system with remote start and turbo timer
Rear wing professionally removed
3 months rego
$12500 ono with the 17 x 9 Volks or 17 x 8 and 16 x 8 Enkies (see my other thread for pics)
$13000 ono with the 17 x 9 and 17 x 8 Advan wheels (see pics)
$14000 ono with the R34 GTR 18 x 9s with near new tyres (currently fitted)
PM / post here or call / sms me on 0410340449.
what your after..
hey dude im after a standard exhaust manifold for my series 2 r33. Any idea if ur r32 one is the same? cheers. Give me a sms on 0402523895
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
