For Sale Thread
Cubes
Parts - bought for R32, but most will fit R33/34 also. Selling car, parts not needed
in the image you can see:
Timing Belt Kit (gates racing belt, idlers, seals - says for RB20/RB25) - $200
Front Wheel Bearings (R32/33/34 incl GTR) - $150set
Rear Wheel Bearings inlc. Hub (R32/33 incl GTR and S14/S15) - $250set
Ancillary belt set (4rib®925mm, 4rib 870mm, 3 rib 835mm ) - $50set
and not shown;
Thrust/Throw out bearing (clutch) - $50
Genuine Work Equip 3 Piece Lightweight Wheels $650
Wheels only - no tyres.
PCD: 5x114.3
17x7 +35
17x8 +35
Edited by Cplus
Will these suit a s1 stagea? RB25 pre neo?
I am unsure. i'll see what i can find out.
edit:
1993-98 2.5L 6 Cyl. 24v DOHC Turbo EFI (RB25DET) 4PK850 Alt.
1993-98 2.5L 6 Cyl. 24v DOHC Turbo EFI (RB25DET) 4PK910 AC
1993-98 2.5L 6 Cyl. 24v DOHC Turbo EFI (RB25DET) 3PK850 PS
15-20mm out in most cases, that's on the high side of too much.
from the catalogue, this is the listing for them;
1989-93 2.0L 6 Cyl. Turbo (RB20DT) 3PK835 PS - w/ AC
1989-93 2.0L 6 Cyl. Turbo (RB20DT) 4PK865 Fan & Alt.
1989-93 2.0L 6 Cyl. Turbo (RB20DT) 4PK925 AC
1989-95 2.6L 6 Cyl. Turbo (RB26) 4PK875 WP & Alt.
1989-95 2.6L 6 Cyl. Turbo (RB26) 4PK925 AC
+/-5mm in fine.
Edited by Cplus
FOR SALE.
hks cast LOW mount exhaust manifold.
comes with hks ext gate.
to suit rb25.
these do fit gt30 turbos low mount but coz i got a 32 its gonna take too much to make it fit.
$750.
SOLD
5X Potenza RE050 215/40/17 for sale, one is a bit worn on the edge but the others are fine, all have good tread in the middle but are slightly rounded on the edges. $100 firm for all 5 PM me thanks.
4 tyre's left, $80 for all 4, 50% tread.
R32 GTS-t
Satin black
17 inch work s2r wheels +15 offset with 245s 9.5inch rims i think, (have polished dish)
HDI electronic boost controller with boost gauge (run at low boost 12, high 14)
R33 Turbo with 10psi actuator(hasn't been boosted yet)
Front mount intercooler
Brand new tein coilovers
Cusco front strut brace
Gtr fuel pump
Apexi exhaust
Gtech dump/front pipe
Pod filter in custom air box with Cold air intake
Option gauges - oil pressure oil temp and air/fuel ratio
GTR fuel pump
GTR seats
GTR front bumper
GTR rear pods
Type M side skirts
removable steering wheel kit with Isotta wheel
Not sure on clutch but is aftermarket has a purple clutch cover
Engine is strong, car has done 125000 km, oil changed every 5000km since i have owned it, all fluids changed, clutch coolant gearbox oil ect.
Rego till 31/5/10
Price: $9000 ono. selling because i want to get back on a motorbike, im keen on trades for bikes plus cash either way and maybe a cheep daily
Pics: car is pretty dirty in pics
Hi guys got a shed full of stuff I need to part with.
1) Vs-xx 17 x 9 + 10 Freshly powdercoated, Immaculate condition - $700
2) Blue smoking Joe's 235/40 R18 $190 pair OR 3 pairs $550
3) Sunfull 235/40 R18's Brand New $220 pair
4) Unknown 225/40 R18's 50-60% tread $50
5) S13 Carbon Aero Mirrors $50
6) R32 Climate Control Surround - immaculate condition/no cracks or scratches $30
7) Centre Consol Surround - immaculate condition/no cracks or scratches $70
8) R32 rear seat $50
9) R32 GTR rear trims (arm rest part) mint condition $80
10) R32 front seat drivers side - shagged leather but rails might be usefull $20
11) All rear seat belts R32 $20 each or all 3 for $50
12) R32 Boot interior + spare wheel (space saver) $90
13) R32 Stock springs with immaculate condition KYB shocks (just used succesfully for regency smile.gif haha) $100
14) R32 rear wing (metallic silver) $15
15) R32 stock rear camber arms $80 pair
16) R32 stock front control arms $80 pair
17) R32 standard rear bar - mint condition $50
18) R32 stock GTS-T bonnet - mint condition $100
19) R32 roof lining - make an offer
20) R32 stock side mount cooler $50
21) R32 Stock air box $40
22) R32 standard horn $15
23) R33 Blitz fibreglass grill - also fits R32 $40
24) R32 Standard Turbo - no shaft play $200
25) R32 stock AFM $15
26) R32 Cat-back 'twins' with resi and muffler - gives an awsome note $300
27) Brand new 'ADVANCE' dump pipe (6 bolt RB) $250
OR TAKE THE CAT-BACK TWINS AND ADVANCE DUMP (COMPLETE) FOR $480
Please contact me on 0400 259 598
Cheers
Chris
FOR SALE:
R34 Standard front and rear bumpers in silver!
In perfect condition no scratches dents etc.
Need em gone!!
$240 for both :)
piks on request
Hey guys, got my fish tank for sale!!!
The tank size is length:145cm - Height: 63 cm - Width: 60cm
comes with the lot.
tank light
black wooden Stand
1 gold guarami
1 guppy
3 tropical snails.
1 bronze catfish
2 fresh water prawns
3 red tail shark
1 sailfin gibby
Also comes with a Jebo external filter, 1 high tech pump, a fluval 300 watt heater.
$400 o.n.o
Pick up only . Pm me if your interested.
Kien.
Edited by kb-r33
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
