For Sale Thread
Cubes
need to get the car off defect next week... need cashish so buy my shit haha.
Yokohama AVS lightweight 16x7 +35 all round 5x114.3 with used tyres, still good for skids - $200
r33 rear widebody panels (viva garage ones) brand new, only test fitted rrp $300, i want - $200
http://www.vivagarage.com.au/cart/index.php?c=86&p=81
r33 m-spec front bar, in 2k primer, ready for paint (will be available in a week or so) - $150
r33 aids style s1 bar (burgundy with scratches) - $20
rb25 g-reddy copy intake manifold, brand new (runners straight), will keep if it doesn't sell - $300
r33 automatic tailshaft - $50
r33 standard front pipe + dump pipe - $50
pics:
m-spec bar
s1 bar
Cheers!
still selling my (fake?) AVS model 5's. have been told these are not genuine avs model 5's but im unsure
18x 8 and 9 +38. one front rim has rash and a small dent in it but does not leak. tyres at about 60-70% tread. tyres are 245/45/18.
see pics. $800. ph: 0422603195
can arrange to get them painted if buyer requests. had mine done gloss black for $100 for the set
may swap for some r33 parts
may swap for parts including strut braces, bolt on spacers, foward facing plenum, boost controller, new cooler core that fits behind a reo bar, series 1 reo bar, new centre console, gtr seat + cash depending what you got....
Edited by kenvv
i have an rb25 pod adapter. gasket thing included. $10 pick up add $2 posted
Go fast bits boost t $10 pick up add $2 posted.
King GEE overals size 102r im like 175 180 cm and it fits very bagy on me, but good for rolling round... worn a few times, not needed anymore.
FS: Apexi PowerFC boost controller solenoid.
The boost controller solenoid comes with the solenoid its self, and the wiring with both plugs but on the other side of the plug the 'female' end which would be your wiring that would plug into the standard solenoid thus meaning this apexi boost controller can be made to suit any RB series motor I'll assume being that both ends of the plugs come with this solenoid all thats needed is to chop off your plug in 'your' harness and hard wire into boost controller solenoid.
I've had this for ages with the intention on installing it in my car once I got my PFC installed - Well I sold my PFC and I don't see a point to this hanging around for another 12+months so I'll sell it - Not fussed if it sits there for another 12 months so I'm not really neg on price.
I'll take $150 for it - PM me or contact 0433830055. Should anyone not understand the write up PM me with any questions and I'll clear them up for you asap!
looking like its sold guys :laugh:
No that has nothing to do with this application. The map sensor reads manifold pressure and plugs directly into the top of the pfc with the other loom, without the map sensor the actuator doesn't know how much to open and wont even work
I see,
$50 for the solenoid by its self then. Surley any 'map' sensor can be used in conjunction with the solenoid? or buy the map sensor?
Purchased this last week for JB Hi Fi $39 bux. Watched it once and its not my thing. Will sell for $27. This is a Blu Ray/DVD set. As new condition (because it pretty much is).
Pick up from CBD or Gawler.
pretty sure that's sort of correct any map sensor can be used its just racing the loom i had a boost kit i since bought a AVCR due to it being too hard to get loom and map sensor
didn't want to stuff your sale up but i know you don't want to be known for selling incomplete parts also
FS: R34 gtr wheels
Have been professionally repainted a darker metallic gold/bronze.
Mint condition, not one scratch or mark on them.
They come with Nangkang ns2 tyres, 275/35 with around 80% tread.
After $2200 or R33 gtr rims with decent tyres + 1k.
PM or 0433943034
Brand New Blue Castor Rod Bushes noltec or nolethane to suit R33 sedan or coupe $50
cusco strut bar good condition suit R33 sedan or coupe (front) $130
call me on 0401409575(Allan)
regards
Allan.M
regards
Allan.M
also a pair of R33 5 stud rims with tyres camber wear on them $60
Hey guys
Selling my panasonic 42'' vierra plasma
Has been in use for only a year, percfect, as new condition. Inc remote and books
Selling only due to upgrade to 50'' full HD plasma
Model number is TH-42PX80A
$550 ono
Pm or 0433073302
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
