For Sale Thread
Cubes
r33 standard front and rear suspention - $100 a pair
r33 rear hicas set up (the bit u take out when u put lockbar in) 4 some one who has to go thru regancy? -$20
r33 front abs sensors -$10
r33 4door standard front seats in excelant cond -$50ea
r33 standard caster rods (may possibly need new nolthane bushes) -$50 or 160 with new nolthane bushes
pair of ca18 15" rims (tyres f*kd) -$50
r32 maroon rear right brake light -$30
r32 speedo cable -$ 30
r32window washer bottles x2 -$20ea
r32 turbo brake booster -$50
r32/r33/r34/s13 solid gearbox mount with bolts -$50
PLEASE SMS ME ON 0405248218 IF U WOULD LIKE ANY THING AS I DONT GET ON HERE OFTEN SORRY!!... CHEERS
Edited by moo_r32
R32 Strut Braces
Fronts - Bottom one, 3rd from bottom
Rear - 2 Top ones
R33
Front - 2nd from the bottom
S13 Strut Braces
Front - 5 front ones (2nd one from bottom is CA only)
Rear - Top one
No Idea, take a gamble $30
$120 Front
$110 Rear
Take a set for $200, if there are any left.
Nismo arms
FRONT ONLY SUIT R32
But rears suit R32/S13
Front:
Rears:
$600 for the lot
S13 NON-Hicas Rear subframe
$100
Located in Adelaide, first in gets the pick. Moving out of home, need the shed empty. HEAPS more stuff to come
Edited by JiN_MaN
R32 GTR HKS Pod Filters, Australian Colours :)
Filters in very good condition
$250
R32 GTR M's Pod Filters,
Filters in good Condition
$200
$150 - East bear seat came in R32 GTR from Japan, replaced with a Bride to fit my fat ass.
Side mount so gets nice and low.
$150 - Bought years ago for my S13, never fitted. Bottom mount
Rails can be included at an extra $120 each
Located in Adelaide
Edited by JiN_MaN
Complete ready to bolt on Turbo Kit,
HKS 2530
HKS 'snail' dump pipe
RB20 ECU remapped and ready to roll.
Adjustable Fuel Pressure reg
$2000 FIRM
This is a complete kit ready to bolt on.
Bolt on do skids! :)
Power from 210rwkw to 220rwkw
arg dude where were u 2 days ago lol? Might still be after front suspension, see how these ones I bought go
Tomei Poncams - 256 in/ex, 8.5 lift. Good condition, suits late model S2 r33 rb25det skylines (with the black CAS) - $700/pair
Much Want, PM Sent
FOR SALE:
Original Nismo/Aero rear bumper for R34 gtt.
Its silver but needs a respray.
I payed $650 never put it on so im asking $500.
PM or 0415087363.
Juran R33 GTR damper adjustable Front shocks, Brand new (approx 20-30km) + GTST stock springs
$200
Will fit GTST but are lower than stock. I had minor scrapes on hard lock turns due to my spacers.
Real shame, beautiful to ride on.
email: [email protected]
Mob: 0421 460 040
Edited by awsam
FOR SALE
RB clutch fan (untrimmed blades and all) - $150 - SOLD
RB non-neo CAS (crank angle sensor) - $50
Stagea fuel pump (excellent condition) - $50
Stagea tiptronic shifter assembly - $50
Stagea handbrake - $25
Stagea belts (for fan, alt, a/c, p/s) - $20
R34 handbrake - $25
HKS pod kit (inc adapter, pod, filter) - $50 - SOLD
Monza BOV - $30
Universal race seat - $100
RB25 water pump - $40
Timewasters and low-ballers will be ignored. PM me with inquiries.
Some price drops!!!
:thumbsup:
From Blitzkits in QLD. Full Dolphin style bodykit for Series 1 Stagea.
Kept in garage, never fitted.
Pics to come.
$1100 ono ... retails for $1600.
Lowballers will be ignored.
FOR SALE
Hypergear turbo ATR43 G3 500hp about 5,000 kms old
Awesome turbo made 301 rwkw on 22 psi selling due to car being defected so it has to come off and i wont be refitting it as the car will be sold
comes with braided oil feed line and custom oil drain pipe, factory waterlines fit up no worries also come with a 14 psi actuator and a 19 psi actuator which cost me an extra $150 alone
Asking $1000
PM or call 0417 899 445 cheers
NEW
Nismo R33 strong clutch pedal $60
NEW
Nismo R33 side winker clear lens set $60
NEW
Nismo carbon end caps to suit R33 GTR wing $140
All items have been open but never used.
Located at Rosewater
pm me
Dave
Price drop :(
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
