EOI
stock 34 gtt turbo 90ks
almost no shaft play... not of the car yet... as my new one is in the pipeline :D
ill have to check if the new one comes with lines n stuff.
will be off the car in a week or when ever someone really waves cash at me
$400
EOI
$400
PM sent
FS.
R32 GTS-t Type M 4 Pot Front Brakes (280x30mm) - calipers, rotors, caliper hardline. - $150 SOLD
JJR Coilpacks (RB20, S1 RB25, R32/33 RB26) - approx 18 months old - doesn't misfire or any of that rubbish. - $250 SOLD
RB20DET Coilpack Loom - good condition, no misfires. - $100 $50
RB20DET Turbo + Exhaust Manifold - turbo good condition, I never had a boost controller so was running on stock boost. - $150
RB20DET ECCS Inlet Manifold - complete with injectors, fuel rail, throttle body etc. - $150
PM/SMS. 0438858813.
Hey everyone up for sale i have a BRAND NEW good quality oil water line kit to suit RB20/25 with a gt series turbo (low mount) such as GT30 or 35/40
Includes:
2x 60cm braided water lines in -6 with banjo bolt ends and barb fitting for hose that runs around back of engine
1x 40cm braided oil line in -4
3x M14x1.5mm banjo bolts
banjo bolt end and banjo bolt for oil line
90 degree -4 oil fitting and nipple that screws into turbo
all required copper sealing washers
and a few other various 90 degree fittings that arent needed but come with it anyway
Asking $100
was taken out of packet for pic only
ALSO i have a blown c34 stagea turbo with op6 exhaust housing asking $50 ono
PM or call 0417 899 445 cheers lockie
R33 Series 2 Coil Packs - 6 of them.
Upgraded to yellow jackets as one of them was starting to break down occasionally, rest are fine. No idea which one was breaking down, but you get all 6 so great for spares if you dont want to fork out $400 for yellow packs!
$80 for all of them. NE Suburbs.
Still available. Will take $50 for a quick sale.
For Sale
Inlet and Exhaust Cam Shafts with Cam Gears off of a RB25DET Series 1 out of a C34 Laurel.
Price: $150 ONO, pick up or local delivery. Price is for Cam Shafts & Cam Gears Only, Backing Plate will be taken off - once I figure out how.
Got the following up for sale that i need gone, all located in the hills.
Genuine RB20 Water Pump - $80
Genuine RB25 S2 Water Pump - $120
^^ Both Brand New/Unused.
Cefiro Brake Master Cylinder, Looks almost new, hardly used - $50
HKS 2530 Turbo, in good working condition, minimal shaft play, nothing unusual for a ball bearing turbo. $1200 will be available by next weeekend as its still on my car.
Gizzmo EBC, later model with multi scramble feature. in perfect working order, removed due to not being needed. $150
RB20 Power Steering Pump and Alternator - $20 each
Pair of Enkei Circular wheels, PCD 4x114.3, 17x8 +34, in ok condition, few minor marks but nothing major - $250
Best bet is to contact me on 0407 633 573 as im not on here everyday, but PM's will be replyed to :yes:
Few Parts added, need these gone as i need the money!!
Edited by Jms_31
I have 2x gold drifttek for sale 17x8 5x114 not multi stud, not sure of offset but im guessing around the +34 mark comes with 255x40 rubber used but good, some light scratching on i think both rims will get pics up later
$550 all offers looked at, not all accepted
EDIT
because of where the car is parked i could only get a photo of the drivers side
colour, size, offset pics
for description of Hero tyres see >>Here<<
UPDATE 1 rim no good so price drop
1x 8.5" gold Drifttek $150
2x 255x40x17 $200
Includes:
Asking $100
pm sent
For sale are some Items off my 98 r34 gt-t
HKS GT 2540-46T, hasn’t done many Km’s upgraded to a bigger garret $1200 ono+shipping
Greedy 600X250X70 return flow FMIC, includes everything you need, clamps, joiners $320 ono+shipping
Stock rotors, plenty of meat left $50 each ono+shipping
Other items include
Qfm A1rm semi track pads 80% left $40+shipping
Stock r34 gtt brake lines $50+shipping
Stock intercooling piping$40+shipping
Located Port noarlunga S.A
0405326532
Please ask for pictures!!!
Hey all. I have a set of black drift teks for sale. They are 17x8 and 17x9 multi stud to suit Nissan. Tyres at 50% all round.
Asking $950 for the set.
Also have a Nintendo Wii package which includes:
Nintendo Wii with all fittings
2x Controllers with 2x nunchucks
Da Blob
Need for Speed undercover
Super Smash Bro's brawl
Wii Sports
$350 for the lot there
All items located at dernancourt SA.
Contact me on 0402 035 914. Can mms pics
Edited by Mowbuss
Bump
EOI
almost no shaft play... not of the car yet... as my new one is in the pipeline :P
$400
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
