hey bee whats the spec on those wheels???
hey Krishy, honestly I have no clue about the specs. you can always try them on.
According to a website: Front & Rear: 18x8, +30mm offset, Weight: 23.5lbs, i had tyres size 235'40'18
Hi guys im stripping a white S1 R33 GTS-T I bought recently.
If you are interested in any parts throw me a PM and Il get back to you with a price asap.
Parts off the car that I have sold so they are no longer for sale include:
1) Motor
2) Gear box
3) Drivers side front Guard
4) Bonnet
Thanks
Hey Guys,
Selling set of 4 standard skyline rims 5 spoke. with new tyres 100% tread, havent used em since the day I bought em nearly 3 months ago.
Taking offers for them, but nothing too ridiculous!
Cheers! :(
Guys sorry my post count isn't high enough to pm lol message me on 0423610484
Cheers
I have some items forsale that i no longer need.
Stock R33 GTST Front pipe $40, Dump pipe $30
Stock R33 GTST Rims and tires $140 SOLD
Stock R33 GTST front and rear Suspension, good to get off defect $120
Brand new HEL Braided Brake lines Front and Rear R33 GTST never been used, only just recently bought via Group buy $110 SOLD
Brand new Earls 19 Row Oil Cooler never been fitted or used $220 $200
Brand new fittings for oil cooler:
Straight Hose End Push-On x4 $50
O-Ring Port Adaptor -10AN x2 $22
Flare to Pipe Adaptor x2 $20
Brand new Oil cooler sandwich plate adaptor 3/4"-16 $50
Contact Via PM or Mob 0403792707
for sale, pick-up prices, need it gone:
2x z32 6-pin afm maf plugs wire harness, suit gtr rb26 - $20 for the pair
2x z32 afm plastic adapters, connects z32 afm to pod filter, $30 for the pair
2x rb26 gtr standard afm maf sensors, good condition - $120 for the pair, no plugs / wire harness
1x z32 afm maf sensor, professional repair fitted with 5-pin for rb20/25/30 for plug'n'play installation, part# N62 A36-000 22680 30P00 - $100 pic below
http://i59.photobucket.com/albums/g302/bwi...on/DSC00941.jpg http://i59.photobucket.com/albums/g302/bwi...on/DSC00940.jpg
r32 sedan rear seat set, blue/grey excellent condition - $20 need it gone or will dump
r32 sedan rear spoiler wing with brake light, grey good condition - $20 need it gone or will dump
r32 gtr dba4000 slotted discs, 297mm, 98% new condition, trial fitted years ago sat in shed since, $200 for the front pair.
c34 stagea series 1, front slotted discs & front stock discs, used condition, $100 for the lot
c34 stagea series 1, front 2-pot brake calipers, 2x sets of front bendix pads, calipers fitted with 20cm-long braided stainless steel banjo brake line, comes with caliper rebuild pack, $100 for the lot
c34 stagea series 1, drivers steering wheel with airbag, excellent condition - $80
c34 stagea series 2, tiptronic auto controller - $60
c34 stagea series 2, drivers steering wheel with airbag & tiptronic controls, excellent condition - $100
For Sale
R33 GTR Turbos, Manifolds and dumps.
Currently fitted to my RB25DE i was running 13psi and had 240RWKW, i want to drop a forged RB25 in and bo for bigger power.
These turbos weren't smokers and made good strong boost with no dramas, the wastegates are also in good condition.
Open to offers but keen to move them along ASAP so i can start my build.
If your interested please call or text me on 0401 337 481.
Cheers BJ
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
