hey bee whats the spec on those wheels???
hey Krishy, honestly I have no clue about the specs. you can always try them on.
According to a website: Front & Rear: 18x8, +30mm offset, Weight: 23.5lbs, i had tyres size 235'40'18
Hi guys im stripping a white S1 R33 GTS-T I bought recently.
If you are interested in any parts throw me a PM and Il get back to you with a price asap.
Parts off the car that I have sold so they are no longer for sale include:
1) Motor
2) Gear box
3) Drivers side front Guard
4) Bonnet
Thanks
Hey Guys,
Selling set of 4 standard skyline rims 5 spoke. with new tyres 100% tread, havent used em since the day I bought em nearly 3 months ago.
Taking offers for them, but nothing too ridiculous!
Cheers! :(
Guys sorry my post count isn't high enough to pm lol message me on 0423610484
Cheers
I have some items forsale that i no longer need.
Stock R33 GTST Front pipe $40, Dump pipe $30
Stock R33 GTST Rims and tires $140 SOLD
Stock R33 GTST front and rear Suspension, good to get off defect $120
Brand new HEL Braided Brake lines Front and Rear R33 GTST never been used, only just recently bought via Group buy $110 SOLD
Brand new Earls 19 Row Oil Cooler never been fitted or used $220 $200
Brand new fittings for oil cooler:
Straight Hose End Push-On x4 $50
O-Ring Port Adaptor -10AN x2 $22
Flare to Pipe Adaptor x2 $20
Brand new Oil cooler sandwich plate adaptor 3/4"-16 $50
Contact Via PM or Mob 0403792707
for sale, pick-up prices, need it gone:
2x z32 6-pin afm maf plugs wire harness, suit gtr rb26 - $20 for the pair
2x z32 afm plastic adapters, connects z32 afm to pod filter, $30 for the pair
2x rb26 gtr standard afm maf sensors, good condition - $120 for the pair, no plugs / wire harness
1x z32 afm maf sensor, professional repair fitted with 5-pin for rb20/25/30 for plug'n'play installation, part# N62 A36-000 22680 30P00 - $100 pic below
http://i59.photobucket.com/albums/g302/bwi...on/DSC00941.jpg http://i59.photobucket.com/albums/g302/bwi...on/DSC00940.jpg
r32 sedan rear seat set, blue/grey excellent condition - $20 need it gone or will dump
r32 sedan rear spoiler wing with brake light, grey good condition - $20 need it gone or will dump
r32 gtr dba4000 slotted discs, 297mm, 98% new condition, trial fitted years ago sat in shed since, $200 for the front pair.
c34 stagea series 1, front slotted discs & front stock discs, used condition, $100 for the lot
c34 stagea series 1, front 2-pot brake calipers, 2x sets of front bendix pads, calipers fitted with 20cm-long braided stainless steel banjo brake line, comes with caliper rebuild pack, $100 for the lot
c34 stagea series 1, drivers steering wheel with airbag, excellent condition - $80
c34 stagea series 2, tiptronic auto controller - $60
c34 stagea series 2, drivers steering wheel with airbag & tiptronic controls, excellent condition - $100
For Sale
R33 GTR Turbos, Manifolds and dumps.
Currently fitted to my RB25DE i was running 13psi and had 240RWKW, i want to drop a forged RB25 in and bo for bigger power.
These turbos weren't smokers and made good strong boost with no dramas, the wastegates are also in good condition.
Open to offers but keen to move them along ASAP so i can start my build.
If your interested please call or text me on 0401 337 481.
Cheers BJ
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
