f/s-
i have a 38mm turbosmart wastegate.
fitted with a 7psi spring.
it held 15psi FLAT on my 25 with 3076r.
ONLY upgrading due to getting a craig helps merge collector manifold and HAVING to go 44mm or bigger :ermm:
used for 100km's
$300
up for sale my 32 CBF fixing it
up for sale is my r32,gts 4wd turbo AUTOMATIC.
black in colour
with 146000kms
rb20 DET
3inch cat back exhaust
17inch black r34 gtt rims
tinted windows
very clean body
bad points are little things like a few plastics in the interior are broken
NEEDS r/h side controll arm, front bar and tire to be swapped over as it has a puncture but i have a tire to go on.
and no rego but it can be all you have to do is go to the rego office and pay for it.
price is firm as its CHEAP as CHIPS , no swaps BUT i want a bigger turbo for my 33 so maybe cash a turbo and cash.
text me on 0415232397 located in mansfield pk
pics here...http://nissansilvia.com/forums/index.php?showtopic=463264
4 Sale
R32 ISC Rear camber arms, Brand spanking!
Bought coz they were going to on the track car but decided to take the ones off the streeter instead.
Bought for $179 (+15 bucks postage i think).
Sell for $150
z32 afm setup for 5-pin plug (suit Rb20, early-mid Rb25) still for sale - $100
I have some sets of Front Brake disc rotors (pairs) for sale:
1x DBA4000 296mm x 30mm 99% new. R32 GTR
unused from project, upgraded to 324mm set
had slight surface moisture rust, sandpapered off as per pic
$100
1x RDA 280mm x 30mm 90% new. R32 GTst, Stagea S1
had slight surface moisture rust from leaking shed, sandpapered off
$80
1x RDA 280 x 29mm 75% new. Stagea s1, R32 GTsT
$70
1x stagea S1 front brake caliper set, with braided line as pictured, new pads
$50
need it gone
thanks
FOR SALE:
Carbon bonnet for r34 300$
Blitz LM fmi return flow type r34/33 300$
R34 Nismo/Altia rear bumper, original not fibre glass copy 150$
pm me if your interested!
PM sent for bonnet and FMIC
cheers
for sale
genuine r34 aero front bar 500 neg
fibreglass aero front bar brand new still in gel coat, no pic 150 neg
brand new never been used greddy dual pillar gauge holder for r34 gtt/gtr 120 neg
msg or ring dylan on 0433091947
Bendix Ultimate Pads + Discs To Suit R33 Skyline
Includes:
Front Discs x2
Rear Discs x2
Front Pads x2
Rear Pads x2
Not sure on the true value of these, so if some makes a good offer i will probably take it
These are also listed on ebay at the moment, here's the link to view pics of the dics and pads
http://cgi.ebay.com.au/Complete-Set-Brakes...=item3a5f3a5ae5
The discs have hardly a lip at all on them at all, the front is like not even a 1mm lip i rekon,
And as for the rear discs, they just feel like there is no lip, just where the pad doesn't reach the edge of the disc its a lil rough, which is normal
The pads have 7mm all round front and rear, and they are Bendix Ultimate,
Do not want to post as too heavy being metal, obvious reasons ofcoarse. Would prefer pickup only
Contact me through here or send me an e-mail at [email protected]
Locater in craigmore 5114
r32 standard turbo. Came off the car running stock boost before I did a turbo/injector upgrade. $200.
Set of rb20 injectors $100
rb20 airflow meter $70
prices are neg. I am willing to swap parts for the following things--
Bonnet. Drivers side front guard. Drivers side head light and indicator to suit r32.
Pm for details thanks
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
