I'm sure the mrs will understand why the wedding needed to be postponed :banana:
lol, she doesnt know it yet...and prob never will..
but seeing as half the ''gift money'' from the wedding is mine, fair sure ill be getting a simonbuilt half cage...
kthx
kthx
lol i dont see that starting arguments
For sale:
S14 Brake Rotors (280mm) and Calipers (4 piston). Front set only. Dont know what brand pads. $200
Comes with the stock rubber lines, caliper bolts, and a hug from yours truly.
R32 GTR intercooler core, inside is clean, in decent nick. $100
R32 GTR standard radiator $50
S14 SMIC with complete stock piping $100
R33 rotors, freshly machined. $100 Firm, itll cost you $50 to machine your rotors so why not save yourself the hassle and buy mine.
S14 front and rear seats in excellent condition, with rails. $150 firm!
R34 oil cooler and relocation kit. Used by previous owner for <5000k's, 18 row core and long lines. Comes with filter. $290
Brakes are back up for sale
A few r32 bits and peices up for sale that i am selling to fund for my 25/30 project,
RB20DET Standard turbo - excellent condition $110
R32 GTS-T Standard rear camber arms, $50
After market Suspension, possible tein front springs, great lowerd street look and awsome handling $100
Standard r32 suspension, resprung to get my car through regancy, Make Me An Offer !
standard r32 gtst SMIC, $50 with some piping.
R32 LED Rear taillights, retails for $400 take it for $100
R32 GTST standard steering wheel $30
All items are ono, or swaps for items of interest !
pm me, im on here all the time so i will reply straight away.
thanks joe.
okay guys time to sell some turbos i had plans for.. these are brand new NEVER been used
2 x gt3582 or gt35r in .63 4 bolt external $1600each posted or picked up
1 x T51SPL in 1.05 ceramic coated and polished comp $2600 posted or picked up
located down south PM for more details
R34 power FC with hand controller $1200 it is used but i have never had it in my car.
I bought used 2 years ago and due to circumstances have never had the money to install and tune
UPDATE !
R32 GTST Type m skirts, gun grey $100
All items are ono, or swaps for items of interest ! eg PARTS for my 25/30 conversion
thanks joe.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
