some bits and pieces for sale that ive had hanging around (and the sheds getting a bit cluttered)
pics on request (i have some but camera batteries went flat).
contact via PM or my number if u have it
R32 GTR interior
Interior trim parts that ive removed from my race car
Carpet
B pillar trims
C pillar trims
Rear 1/4 window trim
Rear seats
Front seats (located at virginia at the current moment)
Boot carpet
Boot plastic trims
Boot "floor"
Headlining, door trims, map light, interior light and dash still in place for now. Parcel shelf is already sold
Looking at $900 for the lot (or will work out deals for someone who doesnt want everything)
Other parts
R32 GTR FRONT only brakes (Sumitomos)
Rotors (reasonable meat left), calipers, pads (condition / brand unknown), stock lines
$300 negotiable
HKS Mechanical gauges (52mm)
Oil Pressure, Oil Temperature and Water Temperature
Complete with wiring for lighting. One gauge (oil temp i think) doesnt light up, didnt ever check why)
No instructions, but i know which temp gauge was which lol
$200 for the lot
HKS recall / warning boost gauge (big motherf**ker)
With lines, wiring etc, no instructions but the important wires seem to be the longest
$100
Mines "LCD boost meter"
pretty flash looking jobbie, digital boost gauge readout. LCD on the display is slightly damaged, but still reads alright
comes with control box and wiring, just plug boost line into the back of it
$80
Blitz BOV mounted to a solid pipe (S13 CA piping apparently). Never used since i bought it at Drift Supercup second hand off a trade stall
$100
Interior parts now down to
Front Seats ($600 for pair, $400 each)
Rear Seats ($350)
Rear under window trims ($50 each)
Ohter parts still available
For sale as a package is the following
Uniden "Bearcat" UBCT-8 250 Channel Scanner (pre-programmed for Metro SA)
GME AE4018K1 antenna with 3ish metres of cable (and plug)
Small external speaker and cable
Plug will need to be re-soldered onto the cable as thats the only way i could remove the antenna from the car
Scanner also comes with small telescopic antenna (for out of vehicle use) and 240v power adapter
Pre programmed for metro Adelaide (and you get lucky about 100km radius on occasion) with:
SA Ambulance Service
SA Metropolitan Fire Service
Country Fire Service
State Emergency Service
plus airband channels for Adelaide Airport and Parafield Airport
programming was done by Electric Bug at Croydon
pic of it as in car, fits nicely in a DIN slot with no need for mounting bracket (firm fit)
best pic i can find of it, below CD player
more details about the unit itself can be found here: http://www.uniden.com.au/AUSTRALIA/p_ubct8_index.asp
$250 NEG. still in the car, but most of ya have seen me playing around with it ;)
all parts off my running rb20 motor:
turbo no shaft play$100
alternator :$60
starter motor:$40
power steering pump$:40
coil pack loom:$40
engine loom:$100
ignitor:$60
plus other random stuff: http://nissansilvia.com/forums/index.php?s...=0#entry5965949
DEFECTED 4door 32
fruitylicious-PERFECT TRACK WEAPON
ENGINE
-120,000 klms
-custom turbo ( ats )
-greedy fmic, truck clamps
-Earls oil cooler an relocator
-dose pipe, afm relocated
-screamer am, strate pipe
-power fc an controller
-hks evc5
-adjustable cam gears inlet an ex
-walbro pump
-brand new headgasket, belts and lines
SUSPENSION
-npg coils in front
-isc in rear
-whiteline front an rear sway, extra bracing
-strut brace front an rear
-brake stopper
-33 lcas
-hicas lock
-kkr camber
-kkr castor
INTERIOR
-kenwood mp3
-kenwood speaker fr an rear
-greddy indiglo boost gauge
-shift light
_FREEZING COLD AIR_
EXTERIOR
-weathershields
-custom 1 of side skirts
-pods
-custom front bar
-roof wing
-passenger side rear quarter seen a white reflector post !
JUST SERVICED WITH ALL FLUIDS AN EXPENSIVE OILS , oil changed monthly til now
Asking $10k will remove parts to make cheaper or swap for stockish S14
PLS ME ME IF INTERESTED !
Edited by PROXIMITY
you cant legally sell a defected car
of course you can otherwise wreckers would be empty it can be sold to make a track car or to be parted out . ive bought a defected car and had the defect removed and the rego changed over with the old owners help .
nothing is impossaible
He said legally though Adrian was warned by the po po for buying and selling a defected car. We all know theres ways around most things.
you can legally sell a defected cars to the wreckers . you can legally sell a defected car if it's not going back on the road . and we all the know the po.po aint right all the time every time :-)
1- Blackberry storm 9500.
had for about 12-13 months. works perfectly fine, never had an issue. its a vodafone locked. only selling due to getting a iphone4.
comes with box, leather case, charger, mini usb cable and all the manuals and CD.
$200.
2- Blackberry Pearl
used this for about 12months. been sitting in the box for another year (2 years old)
same as above, works perfect. comes with box, charger, usb, manuals and CD.
$100
i can mms pictures to anyone interested.
pick up can be arranged from west subs or meet somewhere close.
or buyer pays post.
cheers,
Adrian
Apexi dual N1 exhaust, decided to go back to my old single 3 1/2", has small dent on center muffler but still in excellent condition. Excellent exhaust, great flow and sound $550.
http://www.apexi-usa.com/products/?id=5509
Best to message with the hours im working. 0413 697 162
Still up for grabs
Hey guys I have a shed full of stuff I no longer need so have a look through and see if theres anything u need and give me a text, call or pm if u are interested in an item/s.
GENERAL ITEMS
1) mint full set of Buddy Club P1 racing wheels in hypermax gold with good condition Kumho KU36 semi-slicks all round plus Work annodized valves. $1300.
17 x 9 + 37 & 17 x 8 + 32 255/40/17 & 235/45/17
2) full set of ISC N1 coilovers for R33 GTS-T. 12kg front, 8kg rear. Immaculate condition, recently purchased and stripped off a car I bought. $800
3) pair of 25mm spacers (5 x 114.3) $90
4) Immaculate condition Garret 2871R "disco potato" for SR (no lines included) $800
R32 ITEMS
1) RB Nismo Super Copper Mix rigid Clutch plate with Nismo 860kg Heavy duty pressure plate with RB fly wheel $350 post-4555-1290052740_thumb.jpg
2) L/H front vent for R32 $50
3) R32 GTR door trims $90
4) pair of R32 stock front lower control arms $30
5) pair of R32 stock rear upper camber arms $30
6) pair of R32 stock front castor arms $20
7) R32 stock side mount cooler $20
8) R32 GTS-T stock rear wing (silver) $10
9) R32 glove box $20
10) R32 driver and passenger interior front section (above door) $30
11) R32 stock orange side indicators $15
12) R32 dash cluster $50
R33 ITEMS
1) R33 series 1 afm with pod filter $50
2) R33 series 2 afm $50
3) pair of R33 stock front castor arms $20
4) R33 glove box. immaculate condition $30
5) R33DET (RB25) Tailshaft $90
6) R33 interior gearboot and surround $30
7) R33 drivers side dash vent $50
8) R33 centre dash vent $80
9) RB25 aftermarket manifold (brand new) $200
10) RB25DET Series 2 coilpacks, mint condition, $80 (all 6)
11) R33DET stock diff, condition like new $90
12) pair of R33 rear drive shafts (rear axels) $100
13) R33DET power stearing rack $50
14) R33 centre consol $40
15) R33 driver and passenger interior front section (above door) $30 post-66618-1290053617_thumb.jpg
16) R33 rear interior upper section $40
18) R33 dash cluster $50
19) R33 series 2 engine x-member plus brackets (lowest RB engine drop / conversion for silvia) $180
20) R33 rear cradle (all arms - no hicas, hubs, diff or axles) $150
21) R33 brake package, mint with plenty of meat (all 4 rotors, hubs, calipers, knuckles and front uprights) $700
22) R33 stock exhaust manifold $20
23) R33 front strut brace $15
24) R33 rear strut brace $15
25) R33 passenger side front guard (white) $30
26) RB25DET series 2 Ecu $100
27) RB25DET standard clutch, pressure plate and flywheel (condition like new) $150 msg-34341-1290061343_thumb.jpg
28) RB Nismo Super Copper Mix rigid Clutch plate with Nismo 860kg Heavy duty pressure plate with RB fly wheel $350 post-4555-1290052740_thumb.jpg
Please contact me on 0400 259 598
Cheers
Chris
for sale:
bosch 044 $180 brand new
enkie 17 x 9 or 9.5 unsure, say: bnr33 n1 racing inside
with 4x bridgestone re55 semis slicks. just above wear bands and a fair few good laps in them if rotated correctly
currently fitted maxxis z1, fronts pleanty of meat. rears about 2mm above wear bands.
$1800 ono for rims with tires + very good semi slicks
for sale, pm me please:
1x single working rb26 r32 gtr afm air flow meter, $70
one pair slotted 280mm discs, suit r32 gtst or stagea s1, $50
one pair rear Skyline/Stagea/Silvia/300zx braided brake lines, adr tag approved, Maltech brand, fits nissan, tighten up rear brake feel, $100
1x r32/33 passenger Bride seat rail, $120
clean rear r32 seats, with seatbelts, $40 bargain
rear r32 wing, grey with LEd brake light, $20
RPM 5-point racing harness, 3" straps, $50
ZX9R Ninja stock exhaust muffler, $50
POST UPDATED WITH SOME PICS
R32 GTR interior
Rear 1/4 window trim (lower rear passenger trim)
Rear seats
Rear trims - $70 pair
Rear seats - $250
Front seats - $500 for pair or $350 each
Other parts
$300 negotiable
$200 for the lot
$100
$80
$100
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
