For Sale Thread
Cubes
mums daily car,
she doesnt need it anymore wants me to get rid of it.
91 KF laser, white, manual, 1.6L carby, think its just under 200,000kms or maybe just over. Runs fine, new cv joints, new brake pads, water pump/timing belt done less then 3 months ago. comes with 15" alloys, however one tyre is bust and is on a stocky. very very cheap on fuel. Battery less then a year old. Bit of paint missing on rear bumper but its cheap!!! Rego runs out soon.
$1,200ono.
pm me
or 0422 314 938 (Marko)
TRD sticker can be negotiated with the purchase :P
Can get pics on request but come and see it in person, take it for a test drive or whatever!!!
Item:
RB26- R32/33/34 complete oil cooler kit for sale with stainless hoses , filter holder + brackets
18 row cooler , complete with all adaptor fittings was $400 new
Item condition:
:P New
Contact details:
Please pm
Price:
$220 - or Reasonable offers !!!!!
Pics:
wrecking s1 r33 in silver im keeping these parts but everything else for sale, the car has rear end damage
KEEPING: gearbox, front brakes,tail shaft,steering rack,front lower control arms,
THE ENGINE IS A SERIES 2 complete engine, loom,ecu
completely stock, never even been boosted.
still in the car so can hear running, compression and any other tests welcome....$1800 $1600
OTHER PARTS:
bonnet $100
S1 front bar $80
lh guard with indicator $100 each $80
s1 headlight $80 each
rh complete door $150 each
s2 spoiler $50
rh mirror $30 each
type m sides fiber glass $100 $80 needs bit a work
fuel flap $10
rear window $100 taken out
quarter glass $80
radiator $100
condenser $50
condenser fan $50
master cylinder non abs $80
washer bottle $20
cluster $100
dash $100
mint air bag steering wheel with clock spring $140
seats $100 pair
glove box $20
console $40
door trims and 1/4 panel trims $40 each
seat belts $20 each mint
indicator and wiper stalk $25
rear seats $40
manaul conversion pedals clutch master interior boot trim $150
anything else just ask, will swap for parts of interest!
LOCATED IN ATHOL PARK...TEXT or CALL on 0422030855
Edited by hcR324door
mums daily car,
$1,200ono.
pm me
TRD sticker can be negotiated with the purchase :bunny:
SOLD
S14 front 4 pot calipers + rotors $220
includes pins, shims, stock lines, good Bendix pads, slotted RDA rotors
Broken S14 SR20DET gearbox, 160,000kms old $60
Blown second gear, good for cut and shut bellhousing or rebuild
Factory S14 SR20DET sump $make an offer
Taken out of car to upgrade to bigger baffled unit
Whiteline eccentric camber adjustment bolts KCA414 $50
Adjust camber on the front struts, 14mm bolt, suits S14 and lots of others
180SX factory quarter window visor thingos $make an offer
a few clips broken when removed from car
R32 handbrake cables $20
Stock S14 swaybars $30
Can provide photos on request. Prices somewhat negotiable.
Located north eastern suburbs SA. PM or SMS 0424085308.
Still got 2 sets of suspension to sell
$600 for Bilstein R32 GTR/GTS4 - provides a nice balance between street and track performance, but is not street legal due to eyebrow height
$500 for Tein HR R32 GTR/GTS4 - stiffer than the bilsteins, so more oriented to track use, however these actually ride higher and are street legal
and I can still source injectors for those who want it. Windowshoppers and shoegazers can get f**ked. PM me only if u want to buy, I dont tolerate time wasters
-D
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
