Versus rims
2 x 18 x 9.5
2 x 18 x 8
1 has slight gutter rash maybe 15cm long. Rest are in mint condition
Looking for $900 ono tires (3) inc but pretty worn.
Mobile: 0401 355 434
Pics
Price Drop $800 want them gone.
Up for sale is a set of R33 GTR sway bars.
I bought these off a while back and they don't fit my car(Auto)
They will fit manual C34 series 1 or 2 stagea.
the rear is 22 or 24mm solid from memory, a great upgrade over the standard 17mm hollow bar.
Selling them for less than i paid for them.
Rear sway bar comes with rubbers, u bolts and links to suit.
$150 + postage
Located south of Adelaide
Pm or call me - 0423 10 11 10
stock rear sway bar compared to r33GTR sway bar
N13 pulsar for sale!!! Got 15 inch wheels, whiteline front strut brace, lowered king spings with new shocks, exhaust! Keen to swap for some wheels to suit my 32! Open to offers and cash offers too.
msg me for anymore details or pics of the car.
Brad - 0430033573
100k service kit for GTT, I don't have the car anymore so no longer required: rb25det neo water pump, gates timing belt, tensioner bearing, idler bearing, 3x Ancillary belts
post-47337-0-94923400-1291524979_thumb.jpgpost-47337-0-36269200-1291525011_thumb.jpgpost-47337-0-72578400-1291525052_thumb.jpgpost-47337-0-98687800-1291525128_thumb.jpg
$400
Pm me or sms me on 0433348748 for further info..
$150 + postage
Would this bolt on to a R33 GTST??
If so then i am very keen
Set of Lenso D1R's with tyres and centrecaps, near new, no rash, excellent condition.
front: 17x9 +35, 225/45 tyres near new
rear: 17x10 +15, 235/45 tyres near new
$1,100
call or txt 0422140579
Edited by banhzSIIR33
FS:
Brand New Tomei Sump Baffle $280 rrp $399 at JJR
Used Tein Fixed Height Coilovers, Type HR to suit R32 GTR/GTS4 - $600 negotiable
Used Bilstein Fixed Height Coilovers, unsure what type but they handle very nicely. Slightly lower than the Teins. To suit R32 GTR/GTS4 - $600 negotiable
Used Toyo T1R Proxes with camber wear x4 to suit 16x8 stock gtr rim (225wide), $50 or a bottle of wild the sphincter of the universe
pics upon request
-D
$1,100
do you have a pic of them fitted?
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
