For Sale Thread
Cubes
Need to clean out the garage as the old man told me to.
Series 1 spoiler - black - good cond has some marks on it tho - 50$ ono
Drivers side seat - worn - has a rip in it - still works bit stiff with the adjusters - 30$ ono
Passengers seat - good cond - works fine no complaints just the usual wear - 50$ ono
Rear seats - top and bottom - good condition usual bits of wear - 75$ ono
Door cards both sides - have holes in them for tweeters, bit worn - 30$ pair ono
Rear quarter cards - great condition almost like new just a bit dusty maybe some marks - 50 pair ono
Pm me for more info/pics
Aaron Buzz
post-78652-0-40239400-1298104166_thumb.jpgpost-78652-0-05344000-1298104189_thumb.jpgpost-78652-0-56277800-1298104209_thumb.jpgpost-78652-0-25014900-1298104265_thumb.jpgpost-78652-0-79031100-1298104296_thumb.jpgpost-78652-0-53208200-1298104323_thumb.jpgpost-78652-0-43592200-1298104343_thumb.jpg
r33 parts
driver door & mirror, glass $100 silver
stock intercooler $20
washer bottle $15
overflow bottle $15
bonnet verticle lock support $10
inlet manifold with sensors $ 30
subframe with all arms $100
stock front pipe with cat $30
steering colloum with ignition barrel with door locks and 3 keys$70
boomex sides maroon genuine $ 60
type m rear pods maroon $80
cluster $ 50
stock fuel pump $15
s2 drivers side window switch $30
starter motor $50
s1 front seats drivers rail needs work$50 pair
front cross member $70
drive shafts $60 pair
r32 parts
turbo good condition no actutor $100
center dash vent $60 mint
2 door tail lights $50 pair
after market front shocks look stock height $50
gtr caster rods with white line bushes $50 pair
4 door front seats $50pair
lca' $70 pair
stock fuel pump $15
diff has been shimmed with new oil used for 3 months on street $ 120
power steering pump hicas $50
alternator with loom $50
starter motor $50
a/c compressor has been freshly oiled $100
air con condensor with lines and fan $80
r32 gtr genuine front bar with lip and mesh ,needs small repair easy $350
r32 gtr fuel pump with sender $80
isoto steering wheel red $50
autometer lgf gauge 30 psi & cup $30
blitz timer $15
25mm bolt on spacers $100 or swap for 15mm or 20mm nissan thread
s15 front crossmember $50
r34 a/c compressor $150
r34 drivers door with glass red $200
located in adelaide athol pk text 0422030855 can mms any pics...
swaps for 32 gtr drivers seat ,s13/32 adjustable camber arms,toe arms,r33 adjustable rear camber arms
Edited by hcR324door
Apexi AX53B70-P25 Turbo. steel wheel, ball bearing. only had on my car for the last 8months 2 months was only running 12psi the rest running 16psi (8,000km roughly).
made 241rwkw on 16psi with basic mods. can send dyno report if needed. reson for selling i want 3076r.
$1800 ono.
Have some bits and pieces lying around...
Full set of Aragosta/Tokoshima adjustable shocks, 6-way Damper Adjustable and Circlip height Adjustable, work with your factory upper mounts, these are brand new in the box, never used, bought them off a guy off ebay but never fitted them, come in the original boxes, suit R32 GTR $400.
Mint R32 GTR Factory Airbox, all clips and plastic intake snorkel $200.
R34 type RB26 Coilpack cover decal, NUR spec (I think?), light gold colour, good condition, $50.
R32 GTR/GTS-t Front Strut Brace, polished alloy look with removable ends/mounts $50.
Interior Rear 1/4 window trims for R32, average condition, $20 the pair, price reflects condition.
Standard S15 200SX front and rear swaybars, $20 each.
Autotechnica Red/Black sports steering wheel with boss kit to suit R32, $40.
Cannon muffler, 5" tip, 3" through the guts with short section of 3" pipe attached, used, $40.
Slightly negotiable on some items.
PM or 0412 957 615. Cheers.
Edited by NSNPWR
1-Full set of Pia rozza rims 5x114.3
Front 17x8+35 with bridgestone er3000 215 45 17 approximately 50% tread
Rears 17x9+38 with crappy 235 45 17 tyres
Being second hand rims they have some gutter rash
$500
2-Pair of SSR Integral A1
5x114.3
16x7+44
no tyres
$100
3-Pair of wantanbe style rims
15x8
5x114.3
with a pair of brand new yokohama 225 50 15
$220
Located around Pt Adelaide.
Contact by PM
Item: 18 x 8 +38 Racing Heart Wheels and Tyres Set of 4, Multi stud!
Condition: All wheels have gutter rash to an extent, will get better pics soon. Tyres have very good tread (225 40 18)
Location: Adelaide, willing to organise freight for interstate buyers.
Price and price conditions: $1200ono, or tell me you have R33 or R34 brakes with lines rotors and pads plus some cash rolleyes.gif
Other info: All tyres same size to keep attessa equipped vehicles happy, can be run with or without center caps as pictured bellow
PM me.
Edited by kidafa
Item: Series one/two center console with series one automatic gear surround, PERFECT for modifying for a manual conversion to avoid damaging your stocker
Condition: Very good, often treated with Aerospace protectent when in car
Price and price conditions: $80 ono
PM me :-)
Item: Series One Leather Shift Selector
Condition: Good
Price and price conditions: $40 ono
RB25 triple core alloy radiator. In good condition, some small fin damage on the back. All good apart from that, kept my 25 nice and cool on the track for 12 months, only selling due to it not fitting in the new car.
$200.
660cc Injectors to suit RB26 fuel rail
Rochester Type injectors.
Cost me $660 to buy and $100 to modify to suit rail.
Will sell for $500
Ran these in my GTR for 1 year, only changed them for 1000cc injectors for e85
Good injectors, never had any dramas with them.
Pulled some good power with them. Perfect for a GTR wanting to get in the 300+kw range on PULP
Located in Glenelg
G4 Adjustable suspension for R33/R34 GTR
MONO Tube large diameter series
10kg front 8kg rear (great for a street cross track car)
Great condition
Height and Compression, rebound adjustable 30 position
$700
Pickup avail
Matt
0413023669
Edited by BoostdR
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
