Nissan Skyline R32 with widebody kit front and rear (S15 SR20DET motor)
TRACK ONLY
Only reason for sale is the fact that I no longer have acces to the car trailer which I did otherwise after the fun I had in the hillclimb I just did I certainly wouldn't be selling it if there was a way I could get the use out of it I hoped to when i got the car.
If someone has a registered S13/180 they want to trade with cash my way i may consider it too.
Engine:
S15 SR20DET conversion (completed in japan)
TOMEI 256 cams
550cc injectors
HKS GT SS turbo
N/A SR20 throtlle body
GTR fuel pump
xforce manifold
rb25 airflow meter
'TRUST' FMIC
'GReddy' triple core radiator
straight through 3" Exhaust
Power FC and hand controller
HKS evc 4
211rwkw on 1.2 bar
Driveline:
S13 5 speed
OS geiken twin plate clutch
KAZZ 2 way diff
Suspension:
HKS coil overs
camber adjustable
Brand new Whiteline Adjustable 24mm sway bars front and rear
Brand new Kazama Adjustable Castor rods
hicas lock bar
drift pineapples
Strut tower brace
Drift button handbrake
Interior:
SPARCO driver's seat
GTR Passenger seat
sparco steering wheel
Apexi boost gauge
Bolt in half cage
Sparco Harnesses
Exterior:
body kit is genuine BN Sport kit
Work Meister's 18 X 10" & 18 X 12"
Full wide kit 30mm rear and 25mm front.
$12,000
0488446696
Edited by mr_rbman
Few RB25 parts left over from a recent engine swap, they're all from a S2 engine unless otherwise stated.
new headgasket $100
clutch fan $60
intake manifold $50
exhaust manifold $50
new exhaust manifold to head gasket $50
power steering pump $50
alternator $50
injectors and rail $100
coilpacks $100
s1 ecu $60
injector loom $50
throttle body with tps $50
r32(?) radiator $50
25det block (water/oil/sensors still attached) - 2 pistons damaged $250
Adjustable FPR $60 (I was told it was a nismo item but there is no brand/model/serial as far as i can see to identify)
PM enquiries.
Gizzmo Dual Stage Shift Light - $130
R32GTR Rear Brakes $250 - Brake ducts / genuine nissan rotors / Endless Pads / braided lines / rebuilt calipers excellent condition
RB26 ACL Head Gasket - used but good condition and REUSABLE. $100
MUST SELL all parts must go
R33 series II GTS-T
Driver and passenger door (no dents/damage, scuff mark and small paint chip passenger door as pictured)
both doors have handles but no barrrel locks, I believe passenger door has power window motor)
$50 the pair!!!
Front windows both driver and passenger (nil damage)
$50 the pair!!!
Rear re-bar as pictured (includes most bolts)
$50
PM for response
CAS - $50
new headgasket $100
clutch fan $60 $50
intake manifold $50
alternator $50
coilpacks $100
s1 ecu $60
injector loom $50
r32(?) radiator $50
PM enquiries.
Full set of R32 GTR rims $550
Complete with centre caps, 5x114.3 16x8 +30. Great lightweight wheel.
Has 225/50/16 Kumho KU31s all around, two just above wear bars, two just under wear bars.
S14 ABS VSLD manual 3.692 ratio shimmed diff $180
Shimmed by a known workshop a few thousand kms ago, new oil put in ready to go.
Cant afford a 2 way? buy this diff, tight as a locker, great for drift and circuit.
I dropped 2 seconds at Mallala after shimming it up, get that power to the ground reliably!
Factory S14 SR20DET sump $make an offer
Taken out of car to upgrade to bigger baffled unit
Whiteline eccentric camber adjustment bolts KCA414 $40
Adjust camber on the front struts, 14mm bolt, suits S14 and lots of others
180SX factory quarter window visor thingos $make an offer
Both have been snapped in two while in storage, could probably be glued back together
pm/sms for photos
R32 handbrake cable pair $10
Can provide photos on request.
Prices somewhat negotiable, make an offer, worst I can say is no!
Located north eastern suburbs SA. PM or SMS 0424085308.
Edited by subliminal
is anyone interested in some Bilstein Struts, with King springs, to suit 33/34GTR?
These struts are $$$$ and handle great, whilst still being legal height (just) and regency friendly.
I'd love some coilovers in okay condition. could organise swaps or swaps +cash either way
Hey guys
Have a blown s2 r33 turbo suit rebuild/high flow I'll take $20 for it.
Also have a s2 r33 wing was silver in colour but has been sanded back for respray includes brake light $30 and it's yours
Pm or call/msg 0423904934
Cheers jarad
PM'd re turbo
Hi guys,
No longer in the car game. And did a shed clean up and found a couple of items.
3 x gtr wheel keyrings (brand new) - $12 each
1 x H3 Mtec bulbs good for fog lights(Brand new) - $10
R33 series 2 gear shift surround with no coin box - $15
Got a car hydraulic jack set comes with two stand, hydraulic jack with long and short handle, 2 tyre stopper. Only used a couple of times. -$35
Brand new car audio cables in packaging. Will throw in all climps and cables i have sitting around. $25
All pick up in Marion. Text me at 0433 128 610.
brake bias gauges
1 set of longacre liquid filled brake bias gauges in a alloy dash panel
good condition
$100.00
0402258352 dean
sorry pic went in twice for some reason
Edited by mid life crisis
Got a few parts i want to sell to get my turbo rebuilt:
Q45 afm. 3 inch intake. Better upgrade than a Z32 i believe. $150
S2 RB25DET coilpacks. Good condition didn't missfire. Bought splitfires and no longer need these. Offers?
A set of rear R32 rotors. Calipers, pads, rotors and braded lines. Pads have 80% meat left. $150
R31 lower controll arms. Bought new ones from Nissan. Balljoints still good don't knock etc. $50 for both.
EOI:
Single piece tailshaft to suit a RB20 box in a HR31 coupe. New unis recently.
Large Nissan flag. Red Nissan letters and white background.
Pm me if interested.
Edited by Ad's
Hi Guys,
Selling a few brake spares after installing R34 stoppers onto my C34 Series 1 Nissan Stagea on ebay....
Series 1 owners get yourself some cheap pads ;-)
Front Brake Pads on Ebay
Rear Pads on Ebay
Rear Calipers AND Pads on Ebay
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
