G/Box back up for sale since buyer would not pay deposit. Clutch Cover/Flywheel required so have been removed from sale. Price still as per above.
Engine no longer available.
Gearbox sold pending deposit.
Engine back up for sale.
got a blitz nur spec exhaust from my 34 4dr, should fit 33 & 34 2 & 4drs
it bolts to the first stock flange not cat back.
$250 o.n.o
r34 4dr weather shields $200
r34 neo engine complete with what ever you need 138xxxkms was completely standard with only pod filter
any tests welcome $1850. with auto box if needed .
34 rear body kit lip (small crack) $100
pm or text is best 0415 23 23 97 located in mansfield pk
Bought some new tyres so have these for sale.
They are Achilles ATR Sport tyres in 235/40/R18.
Tyre 1 - 4mm tread until tread indicator
Tyre 2 - 4mm tread until tread indicator.
These were on the back of my car. Have no camber wear at all.
Tyre 3 - 3mm tread until tread indicator.
Tyre 4 - 3mm tread until tread indicator.
These were on the front of my car. They have slight camber wear but still legal for street. Just need to swap what side the tyres go on to get the camber wear even.
Tyres located in Modbury, South Australia.
Edited by SIR_R32
R33 gtr fuel pump $50 (changed to walbro)
Stock camber arms 50
Stock castor rods 50
R33 l and r foglight set up with cover. 50 a side
R33 air box and snorkel 50
R33 cluster , tacho doesn't always work. 98xxx. Put your tacho in it. 50
Located in SA
R33 Sedan (4 door) side skirts and rear pods. these are genuine Nissan parts; not fibreglass junk copies.
Side skirts are in primer, will probably just need a light sand, then ready for paint. Rear pods are painted, so will require sanding back, primer then respray.
Will fit both Series 1 and 2 sedans.
Pretty rare items, asking $230 for the lot. (wreckers ask $260 and upward just for the skirts alone)
can send pics on request - contact via PM.
pm sent regarding tyres. keen for pickups this sunday
Selling
Nissan Stagea Rs-4 Dayz Edition 1998 Wine Red
PRICED TO GO! $11,990 Neg
Due to needing a 4x4 for an upcoming trip she must be sold fast.
I don't want to sell but miss's orders.
140,000k's genuine
Good condition
Only Ever Run on BP Ultimate, and shell 98 when no BP in sight.
Carriozeria Twin Din Stereo
Tien SuperWagon suspension
AWD, ABS etc
Full Leather Interior
Twin Sun roofs
Self Closing rear door
LED parkers and upgraded H4 headlamps
Both front seats electric
Serviced every 5000ks with full synthetic oils
Timing Belt and Water pump done
Small scrape on rear bumper
Contact Mathew on 0421515816
Car can be viewed at Morphett Vale Or Port Elliot by arrangement
ANY questions, just ask via my mobile above as I don't get on SAU often anymore.
Edited by Stagstock
R33 GTR Front Shockers, practically brand new. Drove approx 150-200km's on them.
Put them on my GTST and they scrubbed with my spacers. Shockers are 6 point damper adjustable.
The brand on the side is "Juran"
Awesome ride while I had them on.
$180 o.n.o
pm or sms Sam @ 0421 460 040
Edited by awsam
For sale:
Cannondale Super V 700 sx Lefty
2000 model, x-large frame
Full Shimano Diore XT gearset
Upgraded Hayes Nine hydraulic disc brakes front and rear
Included in sale is a 300psi pump for the front and rear shocks, and i also have a new rear fox float shock.
Price: $600.00
Standard R32 GTR Twin turbos + standard actuators
100,xxx kms
Very minimal shaft play
Have since upgraded to -5's
Price: $250.00
Located Victor Harbor SA,
PM here or phone / sms 0415 117 115
Rb20det short motor suit rebuild ( timing belt went) or head transplant . No manifolds.
$150 ono pick up northeast suburbs
Hayden 0435163144
Also got r200 6bolt make an offer.
Also got cat to diff 3.5" exhaust with muffler
car is def up for sale now...
car is a 1993 mspec
sunroof
s2 rb25det
rb25 gearbox
exedy hd buton clutch (1000kms max)
tomei poncams
hks cam gear
gtr valve springs
rb26 rockercovers and valley cover and cam cover
mines cam cover baffles
splitfire coil packs
mahle forged pistons and rings
spool rods
acl bearings
grout filled block
fully balanced blah blah blah
nitto oil pump
gates timing belt
nitto metal head gasket
helps high mount stempipe manifold
50mm synapse wstegate
gt3076r .82 surge slotted turbo (500kms)
full braided lines and fittings (speedflow)
plazmaman plenum
z32 afm in cooler pipe
turbosmart bov
moroso catch can with speedflow fittings
12 row oil cooler with speedflow fittings
just jap front mount
battery in boot
044 external
surge tank (speedflow fittings)
defi oil temp, water temp, oil pressure, control unit
bride style seat
rb20 ecu with nistune
eboost controller
ful 3inch exhaust no cat
rear camber arms (not fitted)
jjr front caster rods
isc coilovers
r32 gtr front guards (on there way from streeter)
r32 gtr front indicators (on there way from streeter)
s13 origin rear boot lip (on there way from streeter)
r34 gtt front brakes with dba 400 slotted rotors and qfm pads
mspec side skirts
rear pods
stock front bar
viva 25mm rear bolt on guards
cst 18x9.5 +15 all round with 90% 595ss 235/40/18
so yeah car makes 380rwkw on e85
boost is set to 21psi atm but drops to 16 because i forgot to fit the stiffer wastegate spring which i have here..
should make plenty more with boost holding 21+ psi...
dunno what its worth but somthing like 16-17k
will swap for a jzx100 manual stock kit with coilovers..
Hey guys I have a full set of LENSO D1R's (5 stud) for sale.
They are 18 x 10 + 22 (5 x 114.3)
The centres have been professionally painted in Arctic Blue. The wheels have had 5 coats each of arctic blue and then finished off with a solid clear coat (also out of the gun).
The paint is still immaculate to this day and I painted these in January of this year. They have no dents, buckles, flat spots, scratches etc. There like new.
Asking $1100 for the full set of rims or $1480 with a full set of brand new Neutons fitted (235/40 18's).
Inspection Welcome, im located in Glenelg
Pm if interested or call on 0400 259 598
Chris
hey guys, got a couple of things that arent required for the new car so they are up for grabs.
1. Hybrid Intercooler core. Used in my old 31, in average condition but still does the job fine, there is some fin damage. Have some random bits of I/C piping i think i can include if wanted. $150
2. Sparco 4 point harness. $150
3. Monza 4 point harness. $100
4. Pair of Takata copy harnesses, never been used, bought these to use in my car but have since decided to go some different ones. $350 for the pair.
hey guys up for swaps are my PIA Rims dished,
nicely dished rims that would suit any import
i ony want to swap the for Meshes or DRIFT teks in similar sizes.
i have a thing for meshies and teks so thats the reason for swaps
rims have good tyres all round rears are 70% fronts are 60%, have a bit of rash here and there but al in all good condition.
specs are as follows,
fronts 17x8 + 35
rears 17x9 + 38
two 30mm spacers can be thrown in at request
heres a pick of them on my 32
pm me for further details
Edited by r32gtr92
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
