L&RH DOOR LATCH INSERTS $ 15
mint 180sx door trims
centre console with mirror controlls
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $400 with the front cut
bare 180 front cut minta totaly bar 150
R34
POWERSTEARING PUMP $80
AUTO CONVERTER $50
AUTO STARTER MOTER $80
R32
4 door bn kit brand new minus front bar $250
2 door bn sideskirts good nic $100
R33 STEARING COLLUM
BUMP!!!!!
R33 stock air box and snorkel with near new apexi pannel filter $70
By joey_5004 at 2011-07-14
r33 stock coolah with all pipes $50
r33 sers2 rear seat set in mint con $50
r34 set of GT-T rims with out tyres $170
r33 stock front shocks and stock rear springs$50
r33 aftermarket front bar, needs paint. has afew cracks and is missing the left hand side cover over the fog light $150
R33 seris2 front grill in silver.. has a clip or 2 missing and afew scratches $50
Pm or 0431528958 ..
BUMP !! everything needs to go .
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $10ono - Pending payment
2: HKS Boost guage and loom (60mm) $40ono - Pending payment
3: Steel Mate 386M Remote Central Locking System (No Actuators came with kit) $40ono
4: 2x 5 stud 15mm Hubcentric Bolt On Spacers $100 FIRM - Need to sell spacers ASAP - SOLD
5: R32 2door L&R boot trim $5 each (Has holes cut out for strut brace)
Or take Boost guage and piller for $50.
Central locking kit was bought for my Daily but never got round to instaling it (Has never been used)
Boost guage will NOT come with vaccum pipe due to it being used for another guage.
Items:
Hankook RS3 265x35R18 (x4).
Item Condition:
Brand New.
Extra Info:
Surplus from Superlap, and I don't own any 18s to use them myself post event. Locally approximately $395 per tyre. Very impressed with the grip of these tyres on a racetrack. Fantastic high performance street tyre. These are the tyres you want for Superlap clubsprint class. Available now.
Contact Details:
Via PM is fine.
Price and price conditions:
$1,200 FIRM. Pickup - Cash, EFT, etc.
Now with a picture!
have 4 18'' lenso wide track rims for sale 2 in perfect condition 2 need to be re rolled due too buying them already like that, comes with 4 tires in near new condition if i remember correctly. just sittin in the garage $200
Edited by gilly_ECR33
Could you pm me width offset tyres etc with pics
For Sale following items which i purchased but never got around to installing. Due to defects I have changed my mind on what i want to do with the car so this stuff needs to go.
Sard 600cc injectors $500
Greddy cam gears to suit RB26(new) $400
Sard FPR $80
Tomei Type A poncams $600 inc postage These are for BNR32/BCNR33 (RB26DETT).
A252X A269IN lift in ex 9:15
Apexi Power FC with hand controller (suit R32/R33 RB26DETT) 1000$
For sale.
R33 S1 Dash 100$ - Has 3 screw holes on the passenger side as seen in picture.
10 000k HID Kit - Used for a few months but working fine - 50$ (Blue light)
Cusco Strut Brace - Type OS (New but with some scratches) - 100$
hey i have a silver 4door shell.
the shell is pretty bare, not much inside worth using, lhs side doors are mint, 3 out of 4 door trims mint, handbrake cables (all 3) are there, rear subframe and all rear setup is there minus diff and rear steering arms.
no boot, rear bar, rear lights.
you can make some $$ off the handbrake setup and rear brakes and the rear subframe/rear shocks.
has rego 2months
needs to be gone this weekend...
$500
has rego 2months
$500
When can I grab the handbrake handle off of you?
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
