For sale
Sa belt 4 point harness , black with shoulderpads
80$ono
Rb20 turbo no play. Can cometh dump/front/elbow .60$ono
R32 catback exhaust big hap system with cannon not too loud good street exhaust.150$ ono
Gutted 3" cat 30$
R32 back seats 80$
All boot trim and carpet make an offer
0435163144 plz text or call coz I don't check pm's
SHED CLEAN OUT
All items located in the eastern suburbs near Norwood
1. RB25DET coilpack/valley cover $30
2. RB25DET Standard front/dump pipe $30
3. S14/S15/R33/R34/Stagea Rear Camber arms with bushes $20
4. S14/S15/R33/R34/Stagea Rear Toe arms with bushes $20
5. Redline Shockproof Lightweight gearbox oil 2 x Quart bottles $20ea
6. OBD 2 Consult to serial cable w/ Belkin Serial to USB adaptor $80
7. Set of 4 tein coilover bump stops $10
8. RB25DET Side mount intercooler $20
PM ME
SHED CLEAN OUT
PM ME
redline oil is in the bin thanks to my old man.... :/
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst false rear wall $20
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50
RB25det stock dump on black vht $20
R33 gtst rear bar with gtr pods both will need repair $50
r33 gtst sr1 power window motor regulator LHS $80
r33 gtst sr1 power window motor regulator RHS $80
R33 gtst rb25det hicas computer $60
ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project)
ARP rb25 Exhaust Manifold Kit new never used $100
R33 bonnet in black primer has a small bend in lip $50( can get pic)
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
dave
r33 s2 complete doors - white
r33 gtr front grill brand new never used
nismo steering wheel with boss kit
veilside bodykit to suite r33 s1
4inch cat back exhaust with 5 inch cannon (exhaust is cut in half) has no muffler or resinator straight piping sounded insane
offers for anything pm me
can you please add a price that you hope to get for these parts
Thanks
sorry, dont even know really
grill - 160 or so
doors 125 each or 200 for both
cat back exhaust 100
steering wheel 75 or something
bodykit 150
dohmar ill send u a pic tonight when im home from work, if u wanna pm me your mobile number i can probably send you one during the day.
cheers
items FOR SALE:
  • Twin tip straight pipes made from high grade stainless steel $150 firm designed to be flanged under the sub frame/ diff originally came from exhaust technology. very good quality pipes. suits R32.May suit other Nissan models.
  • Standard r32 GTS-T series 2 steering wheel (rare with leather horn button not plastic black one) mint condition no rips or tears,stitching is perfect $150 firm best you will find pics on request.
  • Standard r32 RB20DET injectors x 6 $100 firm come complete with o rings and seals, came off my 20 for GTR injector upgrade last kms was about 115,000. Good condition no leaks.
  • Midnight blue R32 GTR front bar (not N1) genuine plastic with genuine un cut GTR reinforcement, factory mesh and number plate bracket and custom made tow strap fits between lip and bar $600 firm will not split. sold as a package.
  • Original side repeaters mint condition on fascia sides x 2 one has broken top clip supplied needs plastic welding $100 for both or $50 each. Not supplied with globes and holders.Suits replacement.
  • Genuine din pocket with spring loaded front cover flap fits in center of dash near climate control and cd player. suits r32 skyline $30 mint condition
cheers guys please call me or text me on 0421675373 if there are any questions or interest. Im not on here alot anymore :(
regards BEN.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
