Hey got a generic z32 air flow meter for sale it was given to me when i bought my car but dont need it looking for $90 it looks new. text me on 0424873897, thanks Damien
Edited by Bucks
REAR ONLY
Nismo damper adjutable shocks with lowered springs to suit R33 and early Stagea. Bought off RBD2 and only had them in for a short while till I changed to full adjustable coils.
They are pretty stiff at the highest setting but feel like factory on the lower setting. No leaks.
$170ono
0425151620
hey all.
im parting my car, as i CBF waiting for it to sell.
so here goes..
shell - $4500
1993 mspec, Clean rego;d shell, sunroof, gtr front guards, geniune N1 gtr front bar, gtr front indicators, BRAND NEW BC coilovers, rear camber arms, front caster arms, hicas lock bar, vanquish roof spoiler, origin s13 boot lip, CF vented bonnet, bolt on rear guards, r34 gtt front brakes with slotted rotors.
NO rear seats, no drivers seat, no diff, no engine, no gearbox, no wheels.
can make cheaper for removal of parts.
engine built rb25 - $6000
s2 RB25, RB25 gearbox with excedy heavy duty brass button clutch
Mahle forged pistons
spool rods
crank was balanced, grub screwed
block decked, honed, acid dipped
block grout filled
nitto oil pump
ross metal jacket balancer
n1 water pump
oil restricters
head to sump oil drain
refreshed head
gtr valve springs
tomei pon cams
r34 neo CAS
r32 gtr rocker covers/timing cover
mines cam cover baffles
working vct
gates timing belt
has done about 1500kms worth of use.
made 350.1rwkw at horsepower in a box on e85.
RB25 gearbox + clutch - $1400
excedy heavy duty button clutch
VSKF - $3000
18x9-6 and 18x10.5 -5
225/40 and 235/40 neutons
black with chrome dish
fuel setup - $500
external pump, surge tank, magnaflow fuel filter, speedflow fittings for pump surgetank and filter
gt3076 .82 + full lines - $1600
surge slotted gt30, .82 exhaust, speeflow fittings and braided lines
1500kms use max.
helps highmount mani - $850
50mm gate port.
Plazmaman intake plenum - $900
rb25 throttle body inc, all fittings and bottom half of plenum also
id1000cc with rail, aeromotive FPR, lines + speedlow fittings - $1200
z32 + plug $200
defi BF gauges x3 - $800
oil temp, oil pressure, water temp, control unit, light up white with black background
bride style seat with superlow rail - $450
takata style harness - $150
tail shaft suit rb25 in r32 - $200
made by hardie spicer
power fc + hc - $1400
i have all my pics on my phone so please txt me and i can mms you what you need to see.
or see my car sale thread for some pics.
contact 0433 290 801.
cheers
Heys guys got for sale full set of R33 GT-R coilovers <br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">G4 Racing 32 way adj and also base and spring height adj. Could go super low if thats your thing. I believe they are 8kg fr and 6kg rear but not sure<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">excellent condition Blue anodised alloy body. no longer needed also comes with hardened steel laser cut C-spanners i made at work.<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">$550 firm<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">no time wasters or lowballs please cheap enough for such good nic coils..<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">0424521315<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">
Edited by hitman85
R33 series 1 standard cams $100
R32 GTR standard cams $150
R33 series 1 AFM $60
R33 series 1 ECU $50
Rb20 rocker covers $50
S13 brakes + rusty rotors $50
R32 Tailshaft...$75
R32 side mount cooler $50
R33 rear bumper...black. exhuast melted a little bit $20
Rb20 package....complete motor,box,flywheel,clutch,loom $1300
ono on all prices
may post some items
Located in Gawler SA
pm or text as im either working days or nights
0433650850
Have a pair (2 only) ISC 15mm bolt on spacers 4 stud - $80
also a pair of ISc 25mm bolt on spacers suite 4 stud - $80
Can post pictures if needed but fairly basic item, can post at buyers expense.
Live western suburbs of Adelaide
Contact via Pm or 0430 362 050
Hey guys im in the process of clearing out the shed so i have the following for sale.
(the money from the bars will be donated to Viva Garage for his help)
R32 Type D1 style front bar - all cracks have been glassed except left hand corner near front guard - $15 post-57119-0-35801500-1322804306_thumb.jpg post-57119-0-76643900-1322804340_thumb.jpg
R32 Type D1 style side skirts - $30 post-57119-0-57473400-1322804384_thumb.jpg
R33 aftermarket fibreglass front bar (unknown brand) - Glassed up, requires paint - $30 post-57119-0-03432400-1322804498_thumb.jpg
R32 projector style headlights, 'smoked blue' - mounting brackets need fixing / plastic weld - $50 post-57119-0-47393900-1322804540_thumb.jpg
R32 standard style headlights - brackets and everything are mint, except passenger side has crack in lens - $50 post-57119-0-26380200-1322804600_thumb.jpg
RB25DET Series 2 standard ECU - $20 post-57119-0-35194900-1322804688_thumb.jpg
R33 power stearing reservoir - $20 post-57119-0-87472000-1322804770_thumb.jpg
RB25 engine crossmember (dont have pics as camera went flat) - $20
Pm or call / text on 0400 259 598
Cheers,
Chris
FOR SALE:
R34 GTT MANUAL BLACK 4 DOOR (ALL FACTORY)
After months of procrastination my sedan is for sale.
The Run down:
Excellent condition all round
Factory Turbo manual 5speed
Factory Black (the one with the slight metallic about it)
17" Drifteks with new tyres all round
UV glass rear
Factory Lip kit/sideskirts
125,000kms
No rear spolier
Factory Xenons
Windshild kit
Mods:
Tein Coilovers - Electronic in car adjustable (EDFC)
HKS Turbo back exhaust
17 Drifteks
JJR no holes intercooler Kit
APexi SAFC 2
Alloy radiator
Maintenance:
New tie rod ends
New front brakes
100k service conducted at 90K - (new timing belt, cam seals etc)Nissan Belt
Thermostat and alloy radiator recently installed
Oil changed every 5k with motul or decent brand synthetic
Redline gearbox oil
Never Defected or seen the track. Its my daily drive.
What it needs:
*Needs some bushes done at the front
*One of the side skirts is a little rough up close
In saying that im negotiable on price
Car is in excellent condition all round, turns heads and is a great car. I originally purchased it in sydney and brought it over when I moved here.
Asking 17k ONO
0402.621.974
No swaps thanks
FOR SALE 18" mags that came of the 33 i bought to wreck, tyres will need replacing, bit of gutter rash not too ricey and have some dish ideal cheap upgrade :P $400
PICS ARENT WORKING???? wont upload for some reason...
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=367991
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=367992
also has stock r33 front and rear struts. castor rods rear arms etc
NOTE: I will be adding a Xtreme 6 puc button clutch + pressure plate to suit S15 on here shortly so once it's out in about 2 weeks I'll add it to the list below. Only done around 6,000 kms, cost me $1000 brand new. - Feel free to PM me anyway regarding the clutch. Reasonable offers considered.
Located in Southern Suburbs of SA.
Pickup preferred but will post if necessary.
No low-ballers please but willing to consider somewhat reasonable offers.
Reason for sale is because I have since upgraded and no longer require the current parts:
S14 / S15 2nd hand Hybrid FMIC RS Spec - $200 ONO - Includes all silicon joiners and clamps!
Great for decent power gains required on a budget without much pressure drop.
Piping is damaged but will throw that in for free as I believe there may be missing pipes too (can only find 2 pieces since my last tune as tuners changed intercooler to a Blitz CS). Buyer is to arrange adequate piping for intercooler core.
Core was previously damaged due to the preivous owner incorrectly installing it, however it has been addressed with a weld and Epoxy. Doesn't leak any boost what-so-ever from the core.
If you are concerned it may leak then try some Expoy Multi-Metal from Sprint / Autobarn for $10, BUT I CAN GAURANTEE IT WILL NOT LEAK!
S14 / S15: Unused and Unpackaged K&N Panel Filter - $80 ONO
Throw away that Ryco filter and get some air flow form a proven filter to provide better throttle response and economy.
Unused Nismo 1.3 Bar Radiator Cap - $50 ONO - WILL POST FOR FREE!
Hold that pressure in for more effective cooling!
S15: Used Clutch fork pivot ball from an Xtreme Clutch set: TO BE SOLD WITH CLUTCH KIT
Previous owner had this installed on the car. You will want this if you have an aftermarket kit and didn't install the upgraded clutch fort pivot ball to minimise the load that's placed on the standard one.
2nd Hand Gearbox and Engine Mounts from an S15, OK Condition - $40 or make an offer?
8x NGK BCPR7ES to Suit Modified CA / RB Setups (will fit SR but not the preferred sparkplug) - $30 ONO - RELISTED
In regards to contacting, please PM me and we can go from there.
Cheers.
Items:
Samsung 2233SW LCD monitor
Item Condition:
Very Good its a LCD monitor not a footy
Extra Info:
Will be ready for pickup or drop off next week
Contact Details:
txt or PM
0421932750
Price and price conditions:
$165 ono
Samsung 21.5" 2233SW+ Widescreen LCD Monitor - High Gloss Black, Full HD 1920 x 1080p, DVI, 5ms Response, 50,000:1 Contrast (DCR)
pickup/drop off Friday
Price drop $135
