For Sale Thread
Cubes
s2 rb25 (not neo) splitfires with braket and loom - $450
r34 GTT front brakes inc: calipers, rotors (dba4000 slotted), pads (a1rm). rotors and pads under 500kms old - $600
eboost boost controller with solenoid, wiring and vac hose - $300
99% brand new r32 gtst BC br coilovers - $1000
1.5L surgetank ($150), 044 pump ($200), magnaflow fuel filter ($150), lines and fittings - $300
r32 early style brick headlights (n1 looking without the brakets for n1 vent) with globes and wiring - $150
pm and i can txt pictures.
Rb20 starter motor $50
Rb20 BOV $30
Rb20 CAS $100
Rb20 inlet plenum $10
Rb20 turbo an manifold $200
Rb20 intercooler $10
Rb20 dump pipe $10
chrome sideskirts $20
15" alloys with tyres 4 stud 4x100 $80
hr31 passage window control unit (broken button still works) $30
rb20 valley cover $20
rb20 coil packs x 10 with mounting brackets unknown condition $40
RB20 AFM unknown condition $5
R31 S3 grill in black $10
Wastegate spring 38mm 3-4psi $5
R34 RB25DET Engine wiring loom x 2 $150
R34 RB25DET ECU (auto) $150
R34 RB25DET Air Flow meter $50
R34 RB25DET OP6 Turbo $550
R34 RB25DET NEO Engine cover $80
R34 RB25DET Air con Compressor $80
R34 RB25DET Air con lines (2 that bolt to compressor) $40 each
R32 Nismo Fr camber arms, (non Adjustable) $40
R32 RB20 Waste gate Actuator $50
R32 RB20DET Engine with TD06 19C(rebuilt around 5000k ago), 550cc Injectors (this is making 230KW@ 21psi on very safe tune) includes Turbo inlet, dump pipe, adjustable cam gears, has had new water pump and greddy timing belt, cam, crank seals, T/belt tensioner and idler, fitted around 5000km ago. engine is under 100,000km, serviced every 2000-3000km $3000
(NO WIRING LOOM, ECU, AFM, COIL PACKS) May sell with loom ecu and afm if get good offer. Power FC, loom modded with injector resistor, Z32
Still in car, will remove after deposit , fitted to R31
also have cooler piping to suit
R32 RB20DET Gearbox $600 from above package,
Paul 0422444532
Tee Tree Gully Area
stuff for free out of some 33 doors
drivers side- (dont have window switch or power reg motor)
door trim
mirror in white
glass
wiring, plugs, whatever is there anyone can have
passenger i have a full white door at this stage,
so take whatever you need/want
also have a left handed ESP guitar + line 6 amp, + leads and wah wah pedal, stand.. etc
will only sell if i get what i want - $1100
enquire for more details .
door stuff was out of an s2 forgot to mention
all i have left is a power window regulator from passenger door (these go for over 100 at a wreckers)
and the passenger door trim
extra stuff for free too
rb25 valley cover in standard black
the (condensor??) fan or whatever it was that sat in between head lights on a 33
and still for sale
nismo steering wheel with boss kit - 75 or seperate 50 for wheel 25 boss kit
r33 4inch exhaust 5 inch cannon cut in half atm $100
R32 RB20 Waste gate Actuator $50 SOLD
Paul 0422444532
Tee Tree Gully Area
have some tyres for sale, just some i have sitting around that im not using.
2x bridgestone potenza RE050A 215/40/18 80% $80
2x bridgestone RE001 225/55/17 30% $20
2x maxxis 245/45/18 50% $40
miss matched pair 215/35/18 90% $50
miss matched pair 235/40/18 50% $30
miss matched pair 235/40/18 30% $20
bike tyres Rears: bridgestone metzeler renn sports 190/50/17
Fronts: battlax bt-003 raing 120/70/17 $20 for pair 30%
can send pics contact nick on 0414450101. cheers
Edited by vhsle
Specs: WORK Varianza T1S - MSP (machine silver polish) http://www.workwheel...ory=24&wheel=50
Specs: 18x8.5F and 18x9.5R and +35 offset all round.
LEGAL tread on all four tyres, front tyres are 225/40/18 Yokohama Avid and rears are 235/40/18 Bridgestone Sneakers stretched for that exta low!
I bought these about a year and a half ago and there was only a slight marking to the insert on one wheel, since then nothing has changed, there are a few minor scratches here and there.
These wheels are really hard to get here and you won't see them up for sale often as I found when I was looking for them!
Rears will need replacing within a few months, but as stated they have legal tread.
Price: $2550 ono
Contact: 0404128656
Still got goodies left
R32 GTR PowerFC + hand controller
$800
R34 GTR PowerFC D-Jetro + hand controller
no MAP sensor kit, as new condition (plugged in, tested, re-packaged)
$950
Blitz Dual SBC boost controller.
The whole deal (dual solenoids, all the vac lines you should need, wiring and unit)
$300
Plus adding to it
4x R34 GTR wheels with centre caps
1 wheel has a tiny bit of rash (not done by me, but by previous owner), otherwise really good condition
Will not be coming with tyres
$1200
Pics able to be supplied on request
Contact via PM
GTR Wheels back up for sale, price drop
$1000 FIRM. No tyres on them. Need these gone!
R34 factory strut Brace
$30
R34 Air Con compressor
Zexel part number 506221-2852
$60
R33 5 stud Fr Knuckles (pair)
$100
Edited by DR30RSX
FS: New Blitz LM (same as CS except not polished) return flow intercooler to suit R33 and R34
$500 ONO
Western Suburbs, call if interested 042031335
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
