2 X bridgestone 215/40/18 80% tread = $120
3 X bridgestone 225/40/18 30%-40% tread = $120
set of 4 X r32 gtst wheels & tyres good tread = $150
r33 gtst airbox = $50
r32 gtst front calipers, pads and rotors = $150
r32 gtst passenger seat = $20
r32 gtst rear seats & trims = $50
r32 gtst complete front hub assembly with calipers, rotors & pads = $200
rb25 turbo unknown condition = $50
garrett gt3540 turbo excellent condition, 1.06 rear housing = $550
complete rb20 engine running rich don't know what the problem is (could be injectors or tuning) turbo blows smoke, still in the car = $350
0430606223 (text&call)
Edited by r33 rb30dett
Thinking about swapping my R33 GTST series 2 turbo manual coupe. I think its a M Spec, not sure.
Has front lip, side skirts and a GTR wing. 18" dish rims.
I bought it of a bloke that looked about 60, he has owned it since 1998. (car is 1996, so he got it when it was 2 years old).
He had a few other cars so only drive it on weekend etc.
The car has now done 49,000kms (i am told genuine but can't proove). The car is mint and speaks for its self.
I am interested in swapping it for a daily driver such as:
R34 4 door turbo
Stagea
Legnum
VR4
V35 sedan
Calais.
Please sms me on 0418807844 if you are interested, I will send pics via mms. Please don't pm as my phone doesn't notify me and I won't see it.
il put $15k on it
Few car audio stuff for sale - each item is used but in good condition and works 100% - PRICES ARE FIRM:
Clarion VRX-486VD single DIN 7" DVD Player
Price: $350
Specs: http://www.clarion.com/au/en/products/2009/multimedia/multimedia_source_units/VRX486VD/au-en-product-pf_1172419833304.html
Fusion EN-AT1100 Active 10" Tube Subwoofer
Price: $100
Specs: http://www.fusionelectronics.com/car/products/active-enclosures-encounter/en-10-Active-Tube-Enclosure
Sherwood 4-Channel amplifier
Price: $50
unsure on specs - it was used to power a pair of Pioneer TSC-160R and it worked well.
1998 Toyota Starlet Life
- registered until February 2013
- 5-door Hatchback
- 5-speed manual
- power steering
- 1.3L econobox cheap on petrol
- aircondition works excellent
- dark green
- 15" ROH alloy wheels
- 2-way alarm immobiliser system
- fresh new tyres
- 206,000KM
Runs well, excellent first car and/or cheap daily, cheap on petrol and cheap to insure!
Price: $3000
Contact me on 0433743661
DVD player would be pretty baws in the truck too ;)
Already got a DVD player in the back for the little one.
Plus if I put one in the front, combined with the American spec lounge chair drivers seat, I'm likely to fall asleep driving it. Lol
- 5-door Hatchback
- 5-speed manual
- power steering
- dark green
- fresh new tyres
- 206,000KM
Price: $3000
Photos can be seen here: http://www.gumtree.com.au/m-my-ad.html?adId=1000342913
Price: $350
Price: $SOLD
Price: $50
Subwoofer sold!
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
