For Sale Thread
Cubes
Aftermarket Fuel Rail to suit greddy intake manifold anodized purple, selling due to buying a set of injectors which came with a billet rail $60
RB25 top mount stainless exhaust manifold, used and heat wrapped $200
RB25 clutch fan $60
RB25 air conditioning pump and condenser (may have some lines) $40
R33 passenger window reg/rail $40
R33 series 1 mint dash $30
R33 central locking motors $40 the pair
R33 mirrors silver $30
Hicas ecu $40
R33 stock rims set of 4, 2 tyres near brand new other 2 barely legal $150
R33 series 2 wing silver $40
R32 GTR Interior
Front seats,Rear seats,Door trims,Rear side trims
$700neg
R32 Gtr Front Brakes
Complete front set,calipers,disc,pads,hubs,uprights
$350
R32 Stockies
Painted Black,70% tires
$300
R32 Skyline 5 stud brakes
r32 front discs and calipers $250
r32 rear brakes $300 have 2 sets
r33 Front calipers
$250
R32 non abs
Brake Master Cylinder,Needed when doing 5stud conversions
$100
r32 gtr front
lower controll arms
$100 each side
r32 gtr driverside guard $150
3x r32 cat back exhausts $150ea
r32 clutch master $25
r32 passenger side lower controll arm $75
r32 passengerside guard $100
rb26dett startermotor $75
r32 gtr stock blow off valves $100
r32 aftermarket blow off valves $150
r32 gtr brake master $75
r32 gtr tailshaft $150
R32 gts-t Manual Tailshaft $100
r32 gts-t stock intercooler with piping $70
typm m side skirts $150
r32 gtr stock front pipe $50
r32 gts-t stock steering wheelgood condition $150
R32 rb20det Manual ecu $100
parts are in mansfield park
0431 391 262 luke
Front and Rear Whiteline blade adjustable swaybars for R32 GTR, and adjustable link bush kits for front and rear
Suitable for R32 GTR and GTS-4, front (22mm) and rear (24mm) upgrade ADJUSTABLE swaybars and adjustable link kits to get that swaybar setting just right for your street car
Reason for upgrade: Cage has made my overall package too stiff, so want to go back to standard items. Have had minimal use. RH side of front swaybar has small secton of powdercoat rubbed through from wide tyre contact, it has not rusted at all
Price: $500 for the whole package, or will swap with cash my way for standard swaybars + link pins with good bushes (cash my way will be factored on condition of bars and bushes, will take either rubber or urethane bushed items)
All the bits are still in the car, so if you'd like them, please have some patience as i will have to arrange hoist time to be able to remove them
Part numbers (for reference)
Front swaybar: BNF27Z
Rear swaybar: BNR26XZ
Front link bush kit: KLC108
Rear link bush kit: KLC109
Selling my Immaculate 2005 WRX STI Belair South Australia
Have recently moved house and don't have room for 5 cars anymore - needs new home ;)
Major 100K Service has been done ($1200)+ Full Service History SOLD for 27K - Thanks
-Brand New Federal 595 Tyres
-New Bendix Brake Pads
-Has just been serviced
-Never been in accident or used on track
-Registration till Jan 2013
-Always indoor garaged only driven on weekends
-Interior in perfect condition
-$4500 worth of extras - quality stereo system and full titanium exhaust .
-Genuine offers - $27000
The best of all STI models
Can post more pics if interested !!!! :cheers:
Contact/ Pm if interested Mark
SOLD FOR 27 K - Thanks
I have an R32 gtst RB20det 5 speed gearbox recently pulled out om my skyline,
It drives perfectly shifts well all of that. I pulled it out because it has been noisy input shaft bearing which was quite loud.
To stay safe I would say suits rebuild or at least suits a bearing kit.
Only after $200
Comes with speedo drive, no clutch fork or shifter,
Located at Andrews farm or Thebarton, can courier around d Adelaide for not much through work.
Got 600cc side feed injectors to suit r33gtst and probs s15 and 180 sx.. They have been on my car for about 2weeks and drove the car 1 day only. Reason for sale is i had to change plans for my car they dont have o-rings as i had to use them when i was returning my old injectors back but the whole kit is just like $50 or less. Asking $400 . Here is some info Flow Rate in CC per minute: 600CC/min @ 43.5 PSI or 3 BAR Resistance: 11.5 ohms Voltage: 8-15 Volts, nominal 13.5 Volts Amperage: 1.0 Amps Pressure: Min 30PSIG/ Max 100PSIG
Contact me on 0415440332 txt only cz i work odd hours.
FS
32 Gtr from guards in matt maroon $500 ono
180SX white bonnet gd condish $80 ono
S13 bonnet primmer $60
R33 HKS super dragger exhaust system has been regency specd legal by 1 db $400 ono
180sx tailights n garnish $100 per set
r200 dif 4.3 needs bearings $100
yellow drift pinaples $100
rb25 bottom end 72 thou ks head was removed due to broken exaust studs $500 ono
stock rb turbo manifolds $50
R32 gtr door trims rear panels and window quaters $250
R32 front strut brace $80
piaa racing wheels lightweigt spokey design 17x8/9 +30 ISH 500 ono
5 stud r32 s13 rear conversion minus brakes 250
5 bold drive shafts $50
180SX vertex front bar $100
180 ca front bar no lip black $50
Pair for R33 JUN Rear pods (FRP) in black, minor chips and scratches - $100
17x9 +30 Origin DNA 02 Wheels in gold, Some rashing, tyres shot, good for track wheels - $500 the set.
Phone Ben on 0403 395 819
Dude you want to awnser your text messages or make sure your phone number is correct
HKS GT2535 Full Kit for R33 RB25DET. Great condition with minimal shaft play and ready to bolt straight up to your GTS-T.
Includes turbo (duh), elbow and silicone joiner/shield, all lines, basically everything you need to swap out with your standard turbo. I'll include some new turbo to manifold bolts. An easy 250-260rwkw with supporting mods.
$1000. Pickup from 5098.
Bump. Need this gone, open to reasonable offers.
Lenso D1R 18 x 10 all round awesome condition only a little bit of gutter rash, hardly noticeable. basically new tyres on all 4. PM for more info, pics and details of tyres etc.
$1650
also got a cat converter came off a GTR but itll suite any nissan
75 ono
cheers
$1650
75 ono
cheers
lenso wheels sold
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
