For Sale
R33 GTST stock radiator - $20
R33 sunroof hood lining - $15
R33 hood lining (no sunroof) - $15
R33 Sunroof - $30
R33 GTST Coilover suspension JIC front pair, Ohlins rear pair - full set - $250
S/S catch can - $10
R33 4ws - $20
R33 stock rear sway bar - $20
R33 passenger door interior skin (excellent condition) - $40
R33 seat belts (multiple belts) - $15
R33 glove box - $15
RB water pump - $20
Turbosmart BOV with right angle adaptor to suit RB stock mount (as new condition) - $200
12inch US Audio Box+sub - $50
VT commodore wagon with full tow kit, 17 mags, tinted windows, Blue, Auto, 239000km - $4,900
HKS boost gauge - $50
PM for photos (gear located in Mawson Lakes area)
updated
Wrecking 97 40th Anaversery R33 GTS-t I purchased this car in vic with the intention of getting it rego'd here but it has fallen into the 'too hard' basket due to mods. Still has Vic plates. Let me know what you want. Greddy TD06-25G turbo kit (turbo, high mount greddy mani, ext gate, dump) $2000 Apexi Power FC with hand controller - $1000 Apexi AVCR, as new black edition - $500 Splitfire coil packs - $400 Tomei Poncams 256 8.5mm with adustable greddy ex gear - $650 Greddy gauges x5 with senders - $500 3.5" straight through stainless exhaust - $400 Z32 AFM with intake - $225 Genuine Greddy plenum / manifold with Q45 tb - $850 RB25det with cometic MLS hg - $1500 RB25det Manual conversion - $1600 Big clutch - will advise what/condition when removed Fuel pump - will advise when removed Diff 2 way - will advise when removed Cusco coil-over suspension (painted black for rego) - $750 White line sway bars - $200 AVS Model 7 19x8 40ish offset with gc kumo tyres (1 rim damaged, can still source replacement) - $700 Hybrid FMIC with piping - $350 complete 40th anaversery interior great condition - $500 Nismo Steering wheel - $150 Nismo gear knob - $40 Heaps more! let me know what you want Also have a 1993 S1 shell all panels with plates, not written off, not defected!
Also on gumtree
0438422461
1996 Nissan Skyline R33 Series 2/II Stock Manual ECU - $120
Nissan Solid Short Bosskit - $50
3" Stainless Steel GKTech Highflow Catalytic Converter (no flanges) - $130
Genuine Nardi 330mm Deep Corn Perforated Leather Steering Wheel - $300
3" full exhaust from turbo back to suit R33 Gtst. Has Advance dump/front pipe in one, decat (looks like a genuine cat), mid muffler and Momocorse rear muffler with 5" outlet - $850
600W Kenwood 4/3/2 Channel Amplifier - $100
12" Sub Box - $50
Located Adelaide hills, willing to post smaller items at buyers expense.
PM for pics or any more info. Cheers, Brenton.
Edited by brentos_mentos
-Straight pipes, twin 3". $80
-Jap brand 3" cannon, has mount for R32 which it came off of. $50
-Drivers side fixed low rail (has adjustments though) Came off a Bride Stradia in a R32, but will fit other cars. $100
-RB20DET gearbox, 2nd gear syncro not the best on hard shifts, other than that the gearbox is fine. 134,XXXks on the box always used Redline gearbox oil. Only pulled out a month ago, make an offer
-Nismo RB20 short shifter. $100
-RB25 "Quick Shifter" 25% less gear throw whereas a normal short shifter is only 10%, very notable difference, comes with solid shifter bush. $100
-Kicker sub and amp in a proper kicker ported box, plus full Kicker wiring kit. $250.
This one: http://www.jbhifi.com.au/car-sound-gps-navigation/sub-woofers/kicker/amp-sub-box-combo-sku-73622/
-Kenwood W3011 12" Sub in box $100
-R32 Clutch slave used but in good working order $20
The following stuff is BRAND NEW, unused:
-Turbosmart Dual stage boost controller $150
-Turbosmart fuel cut defender 2 $100
-Viper 5901 Alarm $400
-Saas gauges, black face with white dials X2 water temp and 1 Volt gauges $50 each
-Heap of redline oils, auto/manual trans and motor oil $80 a bottle
-Garage 7 R31 Roll Centre Adjustors 30mm, brand new still, comes with high tensile bolts. $150-Random brand podfilter with heat shield, think it's a 4" $20
Taking offers on some of this stuff want to start clearing it. SMS/PM me for more info/pics
Swing me a PM/text for pictures 0431308647.
Located in Mount Barker
For Sale: R33 Skyline, S1 1993, 158,000km's, 17" wheels (245F, 255R) Engine is stock, runs fantastic.
S2 radiator, S2 hicas, stainless steel cat back nismo exhaust, 400r sides, gtr spoiler, window tint, Fusion
front & rear speakers, fusion removable sub & amp tube, all interior blue neon/led door switched lighting.
cd/mp3 player, alarm/3 point imob/turbo timer.
I've owned this car 4 years, second Aussie owner. Still have original import papers.
Runs fantastic, sounds fantastic
$5,900
located Henley Beach
mob 0421 460 040
Also on gumtree
0438422461
keep me update with diff specs bud might be interested :P
custom forward facing RB25 plenum still for sale!!!
My '33 is for sale, female owner.
Has been meticulously cared for, washed weekly and waxed regularly. No dents or scrapes, it's always kept under cover and parked away from other cars. I have owned this for a year now and previous/1st Aus. owner worked for Nissan. Has been serviced every 5000kms there until the last 6 months where all work has been performed by Garage 7.
Receipts for all work kept including services. Only quality parts used, no expense has been spared or overlooked. Just had new rotors, brand new pads and a new heavy duty clutch installed.
Genuine kilometres that are mostly free way, I use it mostly to travel to and from work. Some tasteful modifications have resulted in it being fantastic to handle and drive every day, whilst still being quick but reliable. For full list- see link.
Tuned in December 2012 by Garage 7, running a safe tune of 210rwkw @ 11psi.
Had a full comprehensive check performed last March by RAA prior to purchase. Never been in an accident, stolen, defected, tracked or drifted. No rattles or noises. Genuine enquiries only, no time wasters. I work during the day, if I cannot answer please leave a message and I will return your call.
$13,250ono.
http://www.gumtree.com.au/s-ad/bridgewater/cars-vans-utes/1996-nissan-skyline-r33-gts-t-series-2/1019653739
Edited by Nikki-33
4.3 R200 diff, suit Skyline or Silvia. Shimmed LSD tight but streetable. No noises at all. - $300
full Set of Work Stitch wheels, 17x10 -7 and 17x11 +5 very hard to get sizes. 5 stud can come with tyres or no tyres. Price Depending. $1900 ono with tyres.
947399_10200512671712677_1588423422_n.jp
Got a whole heap of S14 parts for sale... heres a pic.. if you want something send me a PM
PM me if your after any of these parts. i dont check here often
Located NE adelaide suburbs
2006 Bayliner 175 XT Bowrider boat - $23,500 ono.
Great fish/ski/family boat, meticulously looked after with NOT a cent spared ALWAYS flushed and washed after use, owned by an extremely fussy owner. Sale due to requiring extra room in garage for a bigger fishing boat. Compression test has been carried out and reflects a VERY healthy engine. Has been serviced annually, with fluids checked and any adjustments made during the season as necessary.
Boat Specifications;
17’5” licensed to carry 7 passengers
Powered by a 135hp 3L Mercruiser with Alpha 1 drive – VERY ECONOMICAL
Standard Bayliner 175 Features;
Collapsible cockpit seats into sun lounges
Volt gauge
Water temp gauge
Spedometer
Trim gauge
RPM gauge
Oil pressure gauge
Fuel gauge
Bilge blower
Bilge pump
Navigation and anchor lights
Horn
Boarding Ladder
Cup holders and grab handles throughout
Marine carpet
Large ski locker
Added Extras;
Custom made Bimini top – folds flat or quick complete removal
Wakeboard Tower - Liquid Indy with quick release - folds down in minutes
Snap on Bow cover for use on water or while trailering
Snap on Cockpit cover for towing and storage
Fusion iPod head unit – iPod/iPhone is sealed inside
Fusion true marine remote at helm
JL Audio Digital class d amplifer
6 X 6” Fushion 200w Marine Speakers
Bazooka 8” Marine Subwoofer
Garmin 300c Color Fish Finder with depth & voltage alarm
Garmin GPS map
Advantage Stainless Steel 19P propeller – Great for water sports
Century Marine Pro 720 Battery
Digital hour meter in engine compartment to monitor service intervals
Wake/Knee Board & Ski rack on bimini
Sound deadening in Engine compartment makes it CONSIDERABLY quieter than standard while cruising
Water Damped Compass
Fishing rod rocket launcher
2 x stainless steel rod holders
Stainless steel bilge thru hull
Ski mirror
1 X Folding Grapnel anchor
1 X Sand Anchor
Anchor rope with chain
Keel Guard – protects hull when beaching boat
Led Stern light
Ski locker and bow where anchor is stored lined with anti fatigue bar matting
Karvan Skid Trailer;
Extremely easily launch and retrieve, can do with one person
Bearing buddies for ease of maintance
Led Tail Lights
Led Side Markers
Folding drawbar
Great tread
$23,500 ono
Sad to see the boat go as it is my pride and joy but I would now like to spend more time fishing offshore.
