reposting my Stock 17 inch Stagea wheels...
$350.
Tyres are basically brand new generic brand, wheels are also almost prefect aside from one tiny mark.
I can sms pictures to anyone interested.
Pick up only from Seaford area.
Cheers folks.
Edited by Beregron
R33 boot trim Make an offer
R33 straight pipes turbo back mild steel, cannon at the end. $200 Ono
r33 front adjustable strut brace $70
Sr20det manual ecu $90
Genuine type x spoiler 180sx $110 Ono
s13 stock front and dump pipe $50
R33 battery tray with fuse box etc $40
RB crossmember with 33 engine mounts $50
R33 manual tailshaft $80
Set of Vskfs 18x9 +33 & 18x9.5 +39. Had them in the garage for a few years and need the space
drift wheels as theyve got gutter rash and 1 has a minor kink in the inner lip.
Or u could refurbish them.
$600 obo wont go lower than 500
Willing to swap for parts, ie. EBC, JZX100 parts (coilovers). I'll try get pics uploaded tomorrow.
post-16827-0-49841200-1374109457_thumb.j
The wheel with the inner kink, I dunno how the previous owner did it but I bought these wheels like it from Japan and was misinformed on the actual condition of the wheels:
post-16827-0-75746200-1374109644_thumb.j
Work Euroline DH -pretty good, some minor rash on 2 rims, does NOT come with tyres.
5x114.3
18x8 +7
18x9 +7
Suit Toyota, Nissan and Ford
-$1000ono
post-16827-0-88872300-1374110119_thumb.j
S13/180sx Front reo bar UNCUT
-$60
post-16827-0-27517300-1374197982_thumb.j
very keen on vskfs pms sent
  • Like 1
For sale - Logitech G27 Steering Wheel / Racing Wheel in perfect condition. Includes wheel, pedals and shifter. $400 neg.
Located Adelaide (southern). Pick up only, local delivery can be negotiated.
Mounted on a home engineered stand. Pedals are adjustable for position on base.
Wheel angle, wheel height and shifter are adjustable to suit your seating position.
This stand has specifically been built to suit a lounge/couch seated position. Can be adjusted to suit any seating style.
Wheel/stand folds down flat for ease of storage, trolley wheels to assist in moving it around. The base is quite thick/heavy to ensure the set up wont move around with intense racing/force feedback from the G27. Rubber feet also ensure it grips a tile/slate floor surface.
Perfect for you PS3 or PC, works amazingly with GT5 and LFS.
not loud enough still bud?
Haha, I didn't even try putting it on, changed my mind again so the current one will be staying on there for now. :P My ocd kicked in. :( Is my old exhaust quiet enough for ya? :laugh:
Brother MFC 9210 printer for sale $100
It would make a good small office printer. In excellent condition. Pick up only Nth Suburbs
Brad 0427999093
Bump $50
Pair of Britax LED beacons for sale
(as most would have seen on either my Patrol or on my Ranger)
These are 2 spare units that i have that are now taking up space. If you're needing a yellow flashing light for your vehicle for going onto a construction site, these are a good bang for buck unit
Specs:
Clear Polycarbonate Lens with Twelve LEDs
12 Auxiliary LEDs in the Top of the Beacon Provide 360° Vertical and Horizontal Coverage
Waterproof, Shock Resistant, Potted Circuit Board
Permanent Mount configuration (if you want to mount them on a standard roof bar mounting plate, the holes are standard pattern the same as any Narva or Hella flashing light unit)
Black Powder Coated Die-Cast Base
Thirty Built-in Flash Patterns, Including Four Simulated Rotating Patterns
Alternate or Simultaneous Flash Patterns with up to Eight Connected LED Beacons
12/24V applications
Come with instruction book, laser cut brackets, and pre-wired with Narva waterproof plugs
$200 for the pair
Contact me via PM
R33 3" Catback to AMPerformance 4" Twin Tips.
Asking $400.
Bump, $350!
its perfect bud missus just wants to change the big ass tip haha
Haha awesome! Nothing wrong with the tip! :P It even has the 'Momocorse' logo on it! :laugh:
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
