R33 side feed nismo 550cc injectors (yellow) 5000kms old
They come complete in the rail ready to go straight in
They are still in my car and will remove them when sold
Only selling to upgrade to e85
$500
Brand new r33 GTR jun style carbon front lip
$360 firm
17inch buddy club p1 racing originals in hyper gold
Mint con, tyres just about all had it
Nissan 5 stud patten
Unsure on width and offset will update soon
If your interested just text me and I'll go check
$750
0407083177 - Joey
Edited by joeyy
Got a heap of parts to get rid of. Moving at the end of the month and want to get rid of as much of it as possible. Make a decent offer and it's urs
S13/180SX - STOCK
stock front pipe
stock dump pipe with oxy sensor
4 stud hubs with good bearings
sr turbo front brakes with disks and pads
Hicas power steering resivour with level sensor
Hicas subframe with all Hicas lines, senders, lower control arms, disks & knuckles
AC condensor with lines
AC compressor with idler and brackets
R180 diff (suit 5x1 half shafts)
half shafts (5x1)
interior fan and heater core
AC interor core
hicas PS pump
T25 turbo on standard manifold
clutch fan shroud
stock intercooler with piping & BOV
charcol canister
standard suspension arms
most interior parts available
AFTERMARKET
Blitz aluminium mandrel bent piping to suit front mount
3" front dump pipe (mandrel bent, mild steel) with oxy sensor
C34 STAGEA
wrecking a c34 stagea (no gbx, motor), if any parts u want aren't listed let me know as i probably have it
nismo front suspension (springs & shocks, not height adjustable)
standard rear suspension (springs & shocks)
interor fan with heater core
AC interior core
front seats
door shells
rear hatch shell
roof rack
dash
carpet (minus hatch area)
headliner
visors
rear seats (top section only)
steering wheel (with radio controls) no centre
auto shifter
wiper and indicator stalk assemblies
front & rear seat belts
front AWD knuckles with 5 stud hubs
ABS unit
front X-member
rad overflow bottle (good condition)
UNIVERSAL
5x114.3 space saver spares
floor mats
4x114.3 space saver spares
4x 17"x7.5ish ROH adrenalin rims without tyres (4x114.3). can get specific offset/width if required. Can be freshly sprayed (rattle can) if needed
4x 17"X7.5ish speedy rims with pretty much gone tyres, one rim damaged (probs beyond repair). 4x114.3. can get specific offset/width if required.
Also have an NA R33 manual with full kit and a MQ patrol diesel 4 speed man for sale, soon to be posted
ph. 0407971706
Whats going on fellas, been a while since I've pocked my head around these neck of the woods...
Got my drifter up for sale.
Im selling up for a clean streeter as I get my full license back November :).
ENGINE:
JZS147 2JZGTE approx 110xxxkms
Cast single turbo manifold T4 flange 38mm wastegate
GT3582 anti surge turbo .82 ATP rear housing T4 flange
Custom oil + coolant turbo braided lines
JZA80 water pump
Re-routed wiring looms + bonnet cable to engine bay
GKtech plastic overflow bottle
Walbro GSS442 high pressure fuel pump
Removed throttle body traction control
Light weight drive pulleys
Sard radiator (S14) + custom piping
Front mount intercooler 450x300x76 + custom piping
HKS oil cooler core
Oil filter relocation kit + custom lines + Speedflow fittings
Oil catch can
Modified rocker covers with Speedflow fittings
Tial 38mm external wastegate
Bee R rev limiter
HKS FCD
3" custom exhaust turbo back 1 muffler
Custom accelerator cable
Radiator shroud with 2x 12” thermos
Turbo heat blanket
POWER: 299RWKW, 840NM @ 17PSI
DRIVETRAIN:
R33 RB25 gearbox
Cut and shut RB>2JZ bellhousing
Billet flywheel (W58)
single carbotic 5-puk clutch (RB25)
1300KG pressure plate (W58)
Custom 1 piece 3" tailshaft
Welded R200 diff + 5 bolt half shafts 4.1 ratio
Powered By Max solid subframe risers
R34 rear 5 stud hubs
Super Now engine mounts (R32)
Super Now gearbox mount
Craig Helps engine block mounts
Custom gearbox xmember (R32)
S14 clutch master cylinder
Braided + custom clutch line
Uras solid shifter (R34)
Enkei wheel nuts
AMG style 17x9+11 (pair) REAR
Mesh style 17x9.5+15 (pair) FRONT
SUSPENSION:
KTS rear strut brace
JIC FLT-FAS coilovers 7k front 5k rear
S14 LCA’s modified/boxed + S13 balljoints
Kazama castor arms
Tomei 3 point front strut brace
A31 front sway bar
STEERING:
S14 steering rack
Ikeya Formula tie rods
KTS roll centre adjustment tie rod ends
KTS aluminium steering rack bushes
GT-1 Motorsports steering bush
BRAKES:
S14 front 4 piston calipers
Project Mu front rotors
Braided front lines
S14 BM44 master cylinder
Hydro h/brake installed under standard console
INTERIOR:
Pioneer front 6” speakers
Works Bell boss kit
Works Bell quick release with flipper
Works Bell steering wheel 330mm
Yashio Factory spin turn knob
Bride Zeta III (Red with gradient)
Bride seat rail
Cusco D1 8 point roll cage
Okuyama Carbing gear knob
Blitz SBC
Sard battery box
Isolator switch
Broadway mirror
Apexi water temp + oil temp + oil pressure gauges + controller
Alpine CD/MD player
Type X passenger seat
EXTERIOR:
S13 silvia front end
Blacked out quarter windows
Flared guards
Resprayed red
0433 830 055 | $10,500
$500- SOLD
$360 firm
$750
0407083177 - Joey
Sard fuel rail brand new never used with all fittings $200
Sard fuel pressure regulator brand new never used $500
Parts will brought from RHDjapan but have decided to used stock rails instead.
Pm me if you are keen
few things ive got lying around
R34 gtt decat its a just jap one - $30
R34 spoiler KR4 silver in colour, couple of small marks - $50
R32 wastegate actuator 10psi - $25
Turbotech boost tee, pretty much new - $25
Pioneer deh-1350 mpg stereo, pretty much new comes with nissan harness for plug and play - $50
Clutch fork pivot ball, New in wrapper part no 30537-40p01 think it suits r33 - $5
and a left hand side r34 weather shield - free
Ben - 0433 987 945
Up for sale is my R33 GTS25T Series 2. Selling as I now have a work car and don't need two cars.
This car is in excellent condition, very clean and unmolested. Only mods are exhaust and pod filter, rest of the car is stock.
Has travelled 106850 KM always serviced, timing belt was replaced at the 100000 KM service.
New front tyres
New battery
New Coolant
New tint
Pioneer 6 stack DVD/CD with remote and vehicle dynamics processor module
Alarm system
Registered till 19/10/13
If you are looking for a clean 33 check this one out, has been owned by a mature aged person and it has not been thrashed, raced or tracked.
Asking for $10000.00 Negotiable - reasonable offers considered.
Phone - 0438 830 788
post-79573-0-10465500-1376022008_thumb.jpgpost-79573-0-11885300-1376022063_thumb.jpgpost-79573-0-16868800-1376022120_thumb.jpgpost-79573-0-66621400-1376022205_thumb.jpg
R33 3" Catback to AMPerformance 4" Twin Tips.
Asking $400.
does anyone know if this would be louder than my hks 3" straight pipe exhaust which i have on. my current exhaust is just under 90db.
Id guarantee it
Ben - 0433 987 945
Asking $400.
Bump - $300 :( Last price drop. I want this gone and I'm pretty sure that $300 is dirt cheap as well.. :(
R33 GTR carbon front lip *brand new*
$300 if gone in the next few days
Buddy club p1 racing originals
Good condition , slight rash on 2 rims
Front tyres ok. rears finished
17x9 5 x 114.3
$700
Call or text any time
0407083177- joey
Edited by joeyy
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
