Price Drop
Stock r33 exhaust $100?
Stock side mount $80
R33 series 2 rear seats, rear side cards and front door cards $150?
4x 300zx wheels $100
2x volk challange zero 17x9 +22 tyres have serious camber wear. $200
18x8 18x9 +35 Racing Hart CX $900 tyres low on tread. 1 rear has a slight buckle, 2 have gutter marks. 5x114.3
1383578_10152307140528082_317662478_n.jp1425766_10152307140653082_1096246840_n.j1379617_10152307140573082_1731398252_n.j
2x Mickey Thompson et street radials 255 50 16 on 2 piece rays wheels. 90% tread, only had 3runs then broke my drive shaft
$400
Set of "Sienna Roadbattler" (Yokohama?) alloys - made in Japan - 17x7.5 +40 Fronts, 17x8 +45 Rears, with Zetum Sport tyres - 235/45ZR17. Rims were on an R33 GTST, and could use a tidy-up. 2 tyres are just legal, the other 2 have around 40% left. Includes centres & tools to remove centres - $250
https://www.dropbox.com/s/1gfqa4v9pj3yv70/2013-11-09%2012.00.14a.jpg
https://www.dropbox.com/s/rhwb0ksl9kl7cqx/2013-11-09%2012.00.29a.jpg
Eibach lowering springs out of R33 GTST - Rears marked as 51,96 6340102, fronts I need to find the numbers (they are not here...). With these springs fitted ride height was around 330mm front & 340mm rear - measured centre of wheel to wheel arch - $120
https://www.dropbox.com/s/363xdghtlu4wfjj/2013-11-17%2013.21.46.jpg
US Audio Power USA200ZM 600W amp, mounted on board with fuse & wiring, & Kenwood 12" Sub in box - $150
https://www.dropbox.com/s/s87lb2oxi6um6eo/2013-11-09%2012.04.13a.jpg
https://www.dropbox.com/s/qjaw20wbeu2xij3/2013-11-09%2011.57.34a.jpg
Edited by GeeDod
R32 GTR 2 piece OEM side skirts, KG1 (Silver)
Good overall condition, need a clean as they've been in the shed for a while (plus moving house twice with them) and taking up space now
R32 GTR Nismo N1 style pods. Im only saying "style" as i am led to believe the genuine ones would be plastic, and these are fibreglass.
Alright condition, also in KG1 silver
2 Piece skirts - $70
N1 style fibreglass pods - $20
or take them as a package (and have the complete N1 3 piece look) for $75
(pictured as they were on the car)
Couple more photos as i can't edit the original post
1467547_10201443022569755_1183796913_o_z
1471424_10201443021489728_472856662_o_zp
1481392_10201443020729709_500731794_n_zp
update
s1 r33 front bar indicators $30
gfb blow off valve $70
rb25det ecu turbo manual $60
RB25/SR20 injectors x 10. comes with a set of 6 in a r33 rail, and 4 spare $80
full loom, engine loom, includes coilpacks and injector loom, and also lower loom, starter knock sensor alternator etc, also includes ignitor. $80
starter motor $70
Power steering pump $70
Rb20 turbo unknown condition $50
Bonnet $50 green mint condition will go to scrap soon if no one takes it.
Stock suspension $75
Tail lights, surrounds, bulbs, wiring etc $50
R33 engine mounts got 4, $20 each
R33 suspension arms $40 a pair. rear LCA, rear camber, traction, front camber castor etc.
Pair of 5 bolt drive shafts $100
Clutch master and pedal $40
Bm44 brake master, pedal and booster $70
Pair of 17 inch chromies legal tread $80
r33 x force exhaust deletes cat stainless steel, twin mild steel blast pipes $200
For sale need these gone asap
Came out of my daily 33 gtst 4 door, car was running and driving great before removal.
The parts came out because I had plans to do the engine gasket kit, turbo clutch and ecu upgrade but my plans have changed direction.
I also have the shell if anyone is looking around, walk in rego, tein coils, clean interior etc.
Series 1 Rb25det 160,000ks, minus turbo. standard motor with splitfire coilpacks, also have standard ecu.
Complete Nissan engine gasket kit plus a few extras, turbo gasket kit, greedy filter, greedy sumpplug etc will also come with the motor. $1200
Rb25det manual gearbox 160,000ks on this also, comes with sensors and Extreme clutch but it was starting to slip prior to removal. $1000
Greedy intercooler core painted black with black piping to suit 33 gtst. $250
Dump/Front pipe with oxy sensor to suit standard rb25 turbz
1 exhaust is Redback cat, xforce middle with quite muffler tip
2 exhaust deletes the car, no mufflers, big f**k off cannon tip Both exhaust/dump came off a 33 gtst 4 door sedan $220
R33 GTR Drivers seat with rails to suit gtst, excellent condition. $550
R33 gtst viscous LSD, welded up for skids. came as a spare. $80
I need to clear out some shed space, want these gone.
Having trouble resizing pictures so for any more info/pictures you can txt me on 0457 451 391.
Peace
Bump:
Eibach lowering springs out of R33 GTST. With these springs fitted ride height was around 330mm front & 340mm rear - measured centre of wheel to wheel arch - $120
Complete Nissan engine gasket kit plus a few extras, turbo gasket kit, greedy filter, greedy sumpplug etc will also come with the motor. $1000
Rb25det manual gearbox 160,000ks on this also, comes with sensors and Extreme clutch but it was starting to slip prior to removal. $Sold
Greedy intercooler core painted black with black piping to suit 33 gtst. $200
2 exhaust deletes the car, no mufflers, big f**k off cannon tip Both exhaust/dump came off a 33 gtst 4 door sedan $200 for the lot
R33 GTR Drivers seat with rails to suit gtst, excellent condition. $500
R33 gtst viscous LSD, welded up for skids. came as a spare. $60
Peace
Gearbox sold, need the shed space so these have to go
Selling my jerico box and set up. Works brilliant and is fantastic to drive. Selling because I'm planning on going to a 6 speed sequential. Box comes with the following.
Jerico gearbox
Dellow Bellhousing to suit rb
Npc clutch with 26 spline
Quartermaster concentric slave
Tailshaft to suit s14
Hurst shifter and linkages
Price $5000. Gearbox is rated to excess of 800hp. Has been serviced with new oil after each meet. Can Get it inspected by a technician if the buyer requests. I'm located in Adelaide but can place on a pallet and send interstate.
I have plenty of pictures. None on me atm as I'm away from home. If you are interested I can be contacted via pm or email [email protected][
  • Like 1
For Sale - All brand new and still in box to suit rb20/25
Link G4 PNP computer purchased below. Unused still in box with warranty. Also comes with loom ($62)
http://www.garage7.com.au/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=2944&category_id=611&option=com_virtuemart&Itemid=53
Tomei Poncams to suit non-neo rb25 and rb20. 264 cams. Please note these are much harder to get than the common (and much cheaper) 256 cams. Will also come with exhaust cam gear (inlet not needed) purchased below:
http://www.cj-motor.com/store/index.php?main_page=product_info&cPath=11_40&products_id=117
NPC heavy duty cushioned ceramic clutch rated to 380rwkw
http://www.garage7.com.au/home/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=938&category_id=396&option=com_virtuemart&Itemid=53
Please note all items were bought here in Australia from reputable companies listed above and still have a valid warranty.
Prices
computer and loom $1450
Poncams plus exhaust gear $890 Also have a brand new timing belt for sale
clutch $650
email - [email protected]
located southern subs but do travel out north
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
