R34 gtt steering wheel good condition, air bag intact: $200
R34 neo engine cover, $50
R34 gtr centre caps, $200
S14 gktek front strut brace $50 like new
S14 suspension with aurora springs really low, $100
S14 stock wheels, tyres shagged, could use a paint $100 for four.
2x 17x8 +32 5x114 drift wheels, made in jap, need paint tyres shagged, a little dent still holds air no probs $100.
All parts located in strathalbyn, cash talks no swaps
0466614799
http://www.gumtree.com.au/s-ad/strathalbyn/other-parts-accessories/r34-gtt-steering-wheel-neo-engine-cover-gtr-centrecaps-s14-/1034628968
Edited by chops_r34
  • Like 1
Selling Custom number plates RB26 moving interstate soon , ideal for a built GTR
" RB26 " Registered in SA for 3 months
Asking $450
Thanks
Mark
Price is now $420
$400 Now
Drivers side Recaro on recaro rails suit R32.
small tear in bolster fabric from getting in and out of car.
offers
mint R32 dash no bubbles or holes
$200 ono
+35mm vented guards FRP
good condition.
$150 pair
After a genuine GTR front bar and R32/R33 GTR front and rear seats. will swap with cash adjustment either way for parts above
0416 580 two two three
Edited by CRSKmD
For sale
R32 gtst type m front bar in732 black $100
R32 front guards have dents but usable in black $50pair
R32 gtst rear swaybar, good for na s13 with bushes $20
R33 gtst wheels and 80pc front 50pc rear tyres $250
R33 gtst stock struts with king springs $100
R34 gtt side mount intercooler and piping $50
0423789155 text anytime
Hey got a few parts for sale
* R32 Vertex front bar $150
* R32 4door Vertex side skirts $200
* R32 4door Vertex rear bar $150
* R32 front camber arms $50 (Offset bushes)
* R32 gtr passenger seat $150
* Rb26 Rocker Covers $300
* Rb26 coil cover $50
* Rb26 nitto clear cam cover $80
* Rb26 stock cam cover $50
* Rb26 cam backing plate $100
* R33 GTR rear sway bar $100
Greddy Y pipes $550
(replaces the twin turbo pipe on any rb26)
* HKS intake pipes
(Bolt onto stock rb26 AFM's)
$120 or swap for stock air box
* R33 GTR 320kph Nismo Dash cluster
White face..speedo not working and rev
Counter jumps all over the shop
$200-
* R32 gts-t
Front calipers & cross drilled and slotted t
Rotors painted gold
$200
* S14 front Calipers and rotors $200
* Solid alloy subframe bushes $100
* S14 front hubs , lower control arms and knuckles $350
Apexi EL gauges
-oil pressure
-boost
-vacuum
-oil temp
All wiring (no sensors they ran off stock Nissan sensors on my gtr)
$250 for the lot
Lenso mesh type wheels
19 x10 +19 GTR Offset
5x114.3
One has a hair line crack needs to be re-rolled quoted $150 so far..but they were on the car tires held air didn't affect anything
$350
Rb25det package 156000ks
Afm,Ecu,Loom,Turbo
All the parts needed still complete
$1200
Can come with auto trans if wanted at no extra cost,still in can can hear running
1jz Twin turbo motor and 5 speed w58 manual gearbox..
Never heard the motor running as the piggy back Ecu was taken out prior..
Spoke to the old owner and he said the motor was mint up until he crashed the car
The linkage on the shifter is broken and will need to be replaced
Comes with loom (bit of a mess) ecu,all bolt on's air con,power steering, tailshaft,ect
Motor is sold as is...no offers..unsure of k's on motor,..unsure of condition but from looks off things should be any hassles
$1400
ATTENTION
I Will swap anything above for the following Parts I'm chasing All to suit a r32
R32 gtr rear seat
R32 gtr bonnet
Nismo 2 way suit r32
Adjustable r32 front camber arms
Greddy/purple gktech diff housing
Aftermarket Rear knuckles
Aftermarket front knuckles (r32)
R33 gtr brembo calipers
Black carpet
Rear camber arms (brand name only)
Rear traction arms (brand name only)
Bolt in full roll cage
Nardi dish steering wheel (genuine)
R32 intake headlight (fiberglass headlight)
Any r32 carbon fiber parts or
-carbon fiber dash
- interior parts
(gear surround/cluster surround ect)
-carbon fiber doors
-carbon fiber door trims
Any rare parts of interest to suit r32
Txt 0431 391 262 for pics or any other info
For sale
Also now have
R32 type m boot spoiler in 732 black $50
R32 passenger seat on stock rails dirty but ok cond $20
Asking $450
Thanks
Mark
Price is now $420
$350 Or nearest offer
R33 GTR oem parts FS
All parts came off car at approx odo 70,000km
Turbos $300
ECU $100
Coilovers $200
Injectors $200
Stock Cam gears $50
Fuel pump $80
Coil Packs $20 (5 only)
Spark Plugs - NGK BCPR7ES $20
Will give away plugs and coil packs for free with any other purchase
0430-wun-ate-five ate-wun-three
See my main thread for pics and description
http://www.skylinesaustralia.com/forums/topic/437216-r33-gtr-oemstock-items/
Stock rb25 injectors $100
555cc injectors. Bran new top and bottom seals. Cost over $120 just for seals. $400
Stripped rb25 inlet manifold $40
rb25 exhaust manifold. $80
Braided oil and water lines. RB turbos. Never used as Kando turbo came with lines. $100
S2 rb25 afm. $100
Pm for more info
R33 GTST which consists of a 3" mild steel catback to 4" AM Performance Stainless Steel Twin Tips exhaust system. Asking $550 negotiable. Located Meadows (SE Adelaide Hills).
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
