once again, these are up for sale. got hella interest. but no ones fronted the cash (most promising offer has been $800).
work mesh, 17x8 +5 and 17x9 +11. fronts are straight 5x114, rears are multifit 4/5x114.
bit of kerbage on them, but you have to be looking pretty close. the worst of them was one of the 9's which had a slight dent in the outer hoop which has recently been repaired.
http://i63.photobucket.com/albums/h151/sca...902P5120746.jpg
http://i63.photobucket.com/albums/h151/sca...ck/IMG_3157.jpg
taking offers around $1500 without tyres. offers lower than $1400 will be laughed at, and responded to in kind.
contact me on here or on 0408961657.
if you dont shit me off within 4 seconds, i might even be able to arrange a payment plan.
mcbump with fries.
just got a message asking if ill sell the rears. my reply was $1000. im going to amend that.
if you want just the rears, the price is $1500...
... but for that price ill throw in a pair of 17x8+5 wheels in the same style for absolutely nothing.
Edited by scandyflick
17 8 and 9 rays volk racing rims, rears legal frnts bald 450
18 9 unknown jap vipish style rims (would look fat on a 33) no tyres bought them for 1000 selling for 700
first set came off my 32 and second set i bought for it but got 15''ssr's instead
0433 307 918 for pics
Blitz LM Front Mount Intercooler (complete return flow kit) - Was installed to my car but has never been used as the car was a unfinished project - $500
Series 3 R33 GTR seats - Great Condition $800
No Offers as these prices are cheap already.
FOR SALE: R32 GTS4 skyline
Asking Price: $9990 neg or swaps for sil80 or 180 but show me anything you have to offer that must be an import and rear wheel drive!
Killometer's: 118 000 km
Manual or Automatic transmission: Manual
Engine Type: RB20DET
Modifications: pretty stock exhaust pod H/D clutch king springs H/D kyb shocks
Road Worth Certificate: N/A
Registration: runs out this month but putting another 3 months on
Crash History: No Accident History - Inspection Welcome
I Bought the car at the start of the year very stock just neatened everything up put in a H/D clutch in it, new fuel pump, serviced every 5000k's using good oil and coolant, had the attessa system flushed and filled with new oil when i had the clutch done and fresh G-box oil, had new front dump pipe fitted.
the car has never been boosted thats how stock it is bein the gts4 it full of extras ABS etc also has electric front lip which works
There is probably more i havent thought of love the car am a perfectionist with it, there is nothin wrong with the car. anything that needed doing has been done including a re-gas of the air con and its now icy coooooooold!!!!!
Contact Details: 0430025163
cheers
Bill
Have the following for sale, still on the car can see running etc, made over 300kw on 18psi with current tune, most parts are brand new and have just been fitted within the last 2 months, can buy the whole lot or will separate.
located in Adelaide
- Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW & Custom Braided lines oil restrictor and custom turbo drain etc $1850
- Tune Length stainless exhaust manifold $300
- 3.5 "Bell mouth dump front pipe $350 suit gt35 IW
- 3" Silicon Hard intake pipe & Pod Filter $100
- Trust Side mount intercooler (uses short piping and goes back into stock piping) $400
- Z32 AFM with plug $250
- SARD 850cc side feed injectors with clips and loom all soldered in $850
- Yellow Jackets coil packs $300 suit r33 series 2
- Apexi Power fc + Apexi Commander with 300kw tune $1450 suit r33
- BLITZ Sbc ID3 SPEC-S Electronic Boost Controller $400
- Nismo 400r Sideskirts suit r33 $300
- Cusco Coil Overs $800
- 18" x 9.5 Dtm rush wheels stretched 235's new tyres front, 255's 1/2 tread rear $1500
- Rda slotted rotors & QFM-k750 hight temp pads $450
- Nismo Fpr $120
Price neg on some items all gotta go...
ITEM: S13 Coilovers
Silk Road Section RMA-8 Coilovers with adjustable camber tops and base height adjustment. As far as i know, theyre a 7kg front and 5kg rear spring rate.
They have been in my car, but only for rolling it around. Not seen any street / track work as yet. Reason for upgrading, getting something newer for my application
Price: chasing $700 ONO. Note this is COILOVERS ONLY: NO HUBS, KNUCKLES OR LOWER CONTROL ARMS.
I do have some R33 non turbo brake rotors i can throw in for 20 bucks, they're a bit rusty but still alright
Contact: Via PM
Pics available on request
matty im starting to run out of money with things to buy off of you.
what else you got that i need bro.
you should really open up your own wrecking yard with all these parts and all your cars.
its like 31 heaven out there.
ITEM: S13 Coilovers
Contact: Via PM
can you send me some pics of the coilovers please mate!
ITEM: S13 Coilovers
Contact: Via PM
SOLD PENDING PAYMENT
DENSO injectors unknown impedence or capacity $100
I bought these from a forum member a while back - at the time they told me they were sard 700cc injectors
clearly they aren't........................ :wub:
BUT they might be useful to someone, if you can identify them and you use them let me know by PM
regards
Jason
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
