Cusco front caster/tension arms, suit R33/r34 GTR and others im sure.. roughly 5000ks old $300
Cusco rear Camer arms, 5000k's, suit r34, s15,s14, r33 and others $350
Cusco Rear toe Arms, 5000k's suit r34, r33, s15,s14, non hicas $300
R33 Cusco Zero 2E Coilovers, roughly 7000k's no leaks, no knocking, $1800
Nismo BNR34 front sway bar, was on the Tomei drag car in Japan, has been resprayed.. $200.
Nismo R33, R34, s15, S14 rear sway bar $150
EOI
Work XD9 18x10 +18 all round, tyres are KU36, not much tread left. $2200
BNR34 Front Brembo's, Braided lines, A1RM pads, plenty of meat, 25000ks old calipers, slotted 330mm rotors, freshly machined $2000
All second hand and in Adelaide
Edited by Luke_ENR34
Much want! :laugh:
Few things for sale..
- R34 NEO engine cover in good nick $50
- R34 GTT Coupe front rotors with plenty of meat left ... left over from a cross drill swap. $80
- R34 GTT door sills (the plastic variety)... $30
- R34 ash tray .. $20
- R34 manual gear surround .. condition is pretty mashed as I sanded it and did all sorts of shit to try to get it onto the auto .. so needs lick of paint ... $20.
Howie, if you're home tonight, I might walk up the road to eyeball this. Need to tidy up my console after the manual conversion. :action-smiley-069:
For sale: stock RB motor BOV. Bought last night to eliminate possible problem with car. BOV not the problem, so now for sale.
Sell for what I bought it for last night $30
PM me
For sale: pickup 5162
R32 sedan silver wing with light, $50
Pioneer Carrozzeria ts-x550 4-way speakers, $80 pair ono
R32 sedan rear and front seats with seatbelts, as new condition, $200
Map-Ecu manifold based (remove afm's) piggyback ecu, wires in like safc 5-wires only
see www.mapecu.com products map-ecu, support map-ecu, $400
Found some wheels i want, so these have to go. Im selling for way less than their worth. GRAB A BARGAIN!
Nismo LM GT2 produced by RAYS Engineering Japan, A rare find nowadays.
F : 17 x 8 +35
R : 17 x 9 +38
5x114.3 pcd
Rims have a little bit of gutter rash, and the paint is starting to peel in a couple of spots.
$650 ono
Actually scratch the NEO cover ... i reckon it must've been thrown out because I can't find it anymore. Sorry about that.
Couple more things to add to above :
- R34 GTT space saver rim/tyre - $80.
- R34 GTT standard air box + snorkel with brand new filter in box unopened. $60
- R34 GTT standard Automatic shift knob $20
- R34 GTT Triple gauge (just the gauges no surround) $40
- R34 GTT Manual handbrake lever with boot $15
- R34 GTT standard side indicators (orange) - $30
- R34 GTT standard front indicators (orange) - $30
- R34 GTT centre aircon panel (condition pretty mashed, good for spare buttons/lcd and what not) - $20
- brand new US-Audio 8gauge amp wiring kit for car (unopened in box, includes 5.5m 8 gauge power, 0.5m 8ga ground, 6m 18ga trigger cable, 5 mtr rca lead, 50amp fuse) - $60
R33 Mspec Front Bar
looking at $100
This is a hard/rare to find front bar
I bought it a couple of months ago and i planned to fix it up and put it on my car
But just dont have enough money
This bar comes with two front indicators (not in the photo because i forgot to put it on, but comes with both)
It actually has 2 cracks in the bar now front falling over once when it was windy but there not huge and can be fixed either by doing it yourself by following simple steps and using a soldering gun (if you want i can send you the information and pictures to fixing it up)
Or you can take it to a panel beater which can fix it up
heres a few DIY tutorials
http://www.skylinesaustralia.com/forums/Fr...ar-t304013.html (look at the bottom there should be a tutorial)
or buy a fibreglass repair kit from a hardware store (20-30 bucks)
The bar has been trimmed behind so it is ready for a intercooler to be fitted and it will fit if you need it to without any adjustments
If needed i welcome interstate buyers and i can organise delivery for you or you can organise it yourself up to you but i can get a cheap rate for you because my mate owns and runs a delivery business
If you need a quote just send me your postcode and i will get back to you
PM me if you want to contact me or call me on 0432716869
Thanks
Just cleaning up my fs thread (couldn't edit for some reason).. and attaching pics.
- R34 GTT Coupe front brake rotors with plenty of meat left ... left over from a cross drill swap. $80
- Original Trust brand 3" flanged gasket x 2 - $10
Swiss Hutless Shifter Kart
Kart Is In Good Condition.
Just needs a 2stoke moto engine or a big thumping 4stroke.
Rolling Frame Ready To Drop A Bike Engine In As I Intended To.
Clutch And Shifter Set Up Ready To Go.
New Seals In Master Cylinder, Brakes Bled Ready To Go.
Has Chain And Sprocket Ready For A Bike Engine.
Lost intrest in a lil project i was going to do.
$400 ono
Imageshack - sdc10023v
Imageshack - sdc10026
Imageshack - sdc10025
Imageshack - sdc10024
Blitz Dual SBC with all parts... $300 firm
32/33GTR power FC- $750 FIRM no hand controller
SR S13 fan shroud $50
Z32 AFM mint w/o plug $190 (can get one for xtra $10)
ASE coolant header tank brand new with 3x speedflow outlets.. $200 cost me $250
JZX100 stockies ok tyres $200
S13 half cage no cross bar non sunroof $350
S13 whiteline front swaybar $150 2nd hand
S13 R200 lsd 5 bolt good nick $200
S13 R200 SHIMMED LSD CENTRE ONLY (toight as a toiger) $50
S14/R32 rear hubs $80 pair (CHEAP!!!)
ORIGIN BRAND NEW IN PLASTIC stylish rear bar for 180SX $380
S13 standard front corner parker/indicator lenses $30 pair
180SX '94 digital climate control assembly with loom etc mint condition $180
180SX '94 heater box and all aircon parts $100 take it away
S13 rear handbrake lines $20
S14 rear handbrake lines $20
2x recalibrated R33 gtr AFM's $200 pair
S13 standard black elec mirrors $50 each
S13/180sx origin led mirrors (with indicators in them) same as on the CTS car $200 firm
180sx C-Pillar braces x3 $100 each (identical to zenith tuning braces)
all items in northern suburbs SA
can send interstate at buyres expense...
cheers- Ben
0423487731
Edited by D1C33
Compaq Presario CQ61-107TU Notebook PC (NW982PA)
RRP is $999. Brand spanking new in box, not even opened or touched. Ill let it go for $800, FIRM.
Specifications can be found here. http://h10010.www1.hp.com/wwpc/au/en/ho/WF...29-3938413.html
PM me or email: [email protected]
$750
Compaq has released a new version of this laptop, pretty much same hardware/software. Both running Vista premium. new model is CQ61-214TU, rrp $999. asking price dropped accordingly
$650. come get it.
2000 VX Commodore Exec
Dark Blue
160kms
FE2 Suspension
New genuine fuel pump
Near new tires
HD towbar
Large Trans cooler
Can email pics on demand.
Located NE burbs
Boot needs respray as clear coat has peeled, book in to get fixed week after next (16 Feb).
This is a great car and is silent on the road, with ice cold a/c.
$6500 or $6250 without boot respray
Parts Clear Out
R32 GTR Castor arms- instructions say JIC, box is from Just Jap, brand new $150 ono
R32 factory type-m side skirts and rear pods, $120 ono
R32 type-m front bar, needs painting $120 ono
Walbro 550hp fuel pump brand new $150 firm
Buddy Club P1 rims, no tyres just re-painted them in original greeny-grey colour, gutter rash but not real noticble since being painted, $500 firm
R32 spare seat- $50 ono
located in Gawler
pm me here or phone 0449753595
Cheers, Tim
Hey DR GTST, I have forwarded all your details onto a mate in the PM :banana:.
Here guys, back up for sale due to being stuffed around; have a look please ;)
http://www.skylinesaustralia.com/forums/Fs...27#entry5067227
Great car
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
