r33 standard front and rear suspention - $100 a pair
r33 rear hicas set up (the bit u take out when u put lockbar in) 4 some one who has to go thru regancy? -$20
r33 front abs sensors -$10
r33 4door standard front seats in excelant cond -$50ea
r33 standard caster rods (may possibly need new nolthane bushes) -$50 or 160 with new nolthane bushes
pair of ca18 15" rims (tyres f*kd) -$50
r32 maroon rear right brake light -$30
r32 speedo cable -$ 30
r32window washer bottles x2 -$20ea
r32 turbo brake booster -$50
r32/r33/r34/s13 solid gearbox mount with bolts -$50
PLEASE SMS ME ON 0405248218 IF U WOULD LIKE ANY THING AS I DONT GET ON HERE OFTEN SORRY!!... CHEERS
Edited by moo_r32
R32 Strut Braces
Fronts - Bottom one, 3rd from bottom
Rear - 2 Top ones
R33
Front - 2nd from the bottom
S13 Strut Braces
Front - 5 front ones (2nd one from bottom is CA only)
Rear - Top one
No Idea, take a gamble $30
$120 Front
$110 Rear
Take a set for $200, if there are any left.
Nismo arms
FRONT ONLY SUIT R32
But rears suit R32/S13
Front:
Rears:
$600 for the lot
S13 NON-Hicas Rear subframe
$100
Located in Adelaide, first in gets the pick. Moving out of home, need the shed empty. HEAPS more stuff to come
Edited by JiN_MaN
R32 GTR HKS Pod Filters, Australian Colours :)
Filters in very good condition
$250
R32 GTR M's Pod Filters,
Filters in good Condition
$200
$150 - East bear seat came in R32 GTR from Japan, replaced with a Bride to fit my fat ass.
Side mount so gets nice and low.
$150 - Bought years ago for my S13, never fitted. Bottom mount
Rails can be included at an extra $120 each
Located in Adelaide
Edited by JiN_MaN
Complete ready to bolt on Turbo Kit,
HKS 2530
HKS 'snail' dump pipe
RB20 ECU remapped and ready to roll.
Adjustable Fuel Pressure reg
$2000 FIRM
This is a complete kit ready to bolt on.
Bolt on do skids! :)
Power from 210rwkw to 220rwkw
Juran R33 GTR damper adjustable Front shocks, Brand new (approx 20-30km) + GTST stock springs
$200
Will fit GTST but are lower than stock. I had minor scrapes on hard lock turns due to my spacers.
Real shame, beautiful to ride on.
email: [email protected]
Mob: 0421 460 040
Edited by awsam
FOR SALE
RB clutch fan (untrimmed blades and all) - $150 - SOLD
RB non-neo CAS (crank angle sensor) - $50
Stagea fuel pump (excellent condition) - $50
Stagea tiptronic shifter assembly - $50
Stagea handbrake - $25
Stagea belts (for fan, alt, a/c, p/s) - $20
R34 handbrake - $25
HKS pod kit (inc adapter, pod, filter) - $50 - SOLD
Monza BOV - $30
Universal race seat - $100
RB25 water pump - $40
Timewasters and low-ballers will be ignored. PM me with inquiries.
Some price drops!!!
:thumbsup:
From Blitzkits in QLD. Full Dolphin style bodykit for Series 1 Stagea.
Kept in garage, never fitted.
Pics to come.
$1100 ono ... retails for $1600.
Lowballers will be ignored.
FOR SALE
Hypergear turbo ATR43 G3 500hp about 5,000 kms old
Awesome turbo made 301 rwkw on 22 psi selling due to car being defected so it has to come off and i wont be refitting it as the car will be sold
comes with braided oil feed line and custom oil drain pipe, factory waterlines fit up no worries also come with a 14 psi actuator and a 19 psi actuator which cost me an extra $150 alone
Asking $1000
PM or call 0417 899 445 cheers
NEW
Nismo R33 strong clutch pedal $60
NEW
Nismo R33 side winker clear lens set $60
NEW
Nismo carbon end caps to suit R33 GTR wing $140
All items have been open but never used.
Located at Rosewater
pm me
Dave
Price drop :(
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
    • Don't use "gasless MIG" (FCAW) you want to use proper MIG. FCAW burns a few hundred degrees hotter than MIG will for mild steel. It is a true ball ache for sheet metal. New MIG / TIG machines even have features like "Spot Weld" as well as "Automatic" settings. Plenty of people say for DIY home hobby, the auto machines are pretty good for 95% of welding. I personally, I'm a sucker for punishment and wanting to dial it in, and be able to adjust the machine. Mainly because I used to MIG weld for a living, and being able to tweak and tune things ever so slightly was my preference. Hence when I bought my ACDC TIG, it has all the adjustments for everything and no "easy" mode. Ha ha I have stick, MIG, "gaslessMIG" and ACDC TIG at home. Out of them, if you're doing mild steel sheet metal repair, and want to do mild steel exhausts, go MIG. If you're thinking you'll want to get into doing some aluminium stuff, or stainless steel, get an ACDC TIG with HF start. If you can, get one with a foot pedal too. My MIG machine is a UniMIG, and my Stick/TIG is CigWeld. If I were buying another machine, I'd buy another CIGWeld. Lots of people having issues with UniMIG, and them not wanting to cover warranty. Everything has to go back to UNIMig themselves. CIGWeld, I've had to use their warranty on my machine for a gas leak, they have repair centres everywhere, (contracted authorised repair centres). First repair place I used were hopeless, but the second place were amazing. Warranty process itself super easy, and second repair place was telling me CigWeld actually cover in their warranty, upto an hour of techs time to help you with your machine, and going through the settings and helping teach you the machine. UniMIG keep trying to get out of replacing motherboards on 12 month old machines.   TLDR, mild steel sheet welding, buy a MIG. my vote is CigWeld for brand.
    • I guess that's what happens when someone can't convert metric to freedom units to machine something. 😛
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
