^^ just as a sale point even if a car is out of rego for a year so long as there is no hold on the registered drivers license or no defects you can still register online
also pics or links to pics would be good
http://adelaide.gumtree.com.au/c-Cars-Vehi...QAdIdZ204275210
Thanks mate
excuse the metric dick ton of pics.
price will probably go back up to $15k at the end of next week.
Make/Model: Nissan S14A
Year: 1996
Kilometers: 165,xxx
Transmission type: 5spd manual
Engine: SR20DET
Colour: Red
Modifications: See below
Roadworthy Certificate: N/A
Accident History: None.
Asking Price: $17k... $14k... open to sensible offers though.
Contact Details: PM
Other Comments:
Regretful sale, but its time to move on.
The whole story for this car can be found here... with the slightly less in depth ns.com version here.
Bought it dead standard in late '08 with 151,000ish kms on it.
Since then, I've done all this;
Interior & Electronics;
Clarion DB286USB HeadUnit
Clarion SRG1620R 2 ways (parcel shelf)
Clarion SRQ1620S Components (doors)
NISMO Gearknob (+ dildo shifter for shits and giggles)
JDM S2 stereo, climate, and gear surrounds.
VELO GP90 Drivers Seat on modified Bride rail
STRI White Face Gauges for; Boost.
Shadow White Face Gauges for; oil temp, oil pressure.
PIVOT Water temp gauge
Bosch 6000K HID kit and arctic white parkers
Extended + battery cables
SuperCharge Slim battery
35% Tint
Alarm
Engine/Intake/Exhaust/Cooling;
Standard turbo rebuilt and highflowed to 2860 specs
Genuine Nissan coolant
K&N Oil Filter
HKS Alloy suction kit
Elf Excellium 5w/40 fully synthetic
NGK BCPR6ES plugs (.8mm gap)
Modified Airbox w/ cold air duct + K&N element
M/Steel 3" Apex'i Catback exhaust
AM Performance S/Steel Dump & Front (with seperated wastegate flow)
X-Force Catalytic Converter
Brand new Genuine Nissan Gaskets for; Mani -> Turbo, Turbo -> Dump, Cat
Brand new Genuine Nissan turbo studs
Brand new Genuine Nissan Water lines
Braided Steel oil line
Deleted BOV
Cooling Pro FMIC w/ custom brackets
Custom S/Steel 2.5" intercooler piping
Turbotech MBC (hybrid ebc wired in, needs tune)
Earls oil cooler and relo kit with speedflow fittings
R33 GTR fuel pump
Nismo Mounts
KTS Engine Torque Damper
Driveline;
Standard 5 spd Box
Xtreme Heavy Duty Organic Clutch
Nismo Mount
Standard Nissan "LSD"
Wheels & Tyres;
Front;
Work Equip, 17 x 9 +17
225/45 Kumho KU36 (brand new)
Rear;
225/45 Kumho KU36 (down to about 30%)
Brakes;
Front;
RDA Slotted Rotors w/ ACRE Street pads
HEL Braided lines
Rear;
RDA Slotted Rotors w/ Bendix SRT pads (less than 200k's on them, worth over $300)
HEL Braided lines
Fluid;
Penrite syn 600
Suspension & Steering;
Cusco Zero 2 R Coilovers
Cusco Front strut brace
Cusco Camber Arms
KTS Tie rod ends
Kazama castor rods
Body;
JDM Kouki wing
JDM front bumper w/ foglights
Navan Zenki side skirts
Navan Zenki rear pods
Rolled guards
Domokun chilling the rear quarter glass.
Performance;
136rwkw @ Graham West Workshop (Catback exhaust, exhaust leak at turbo, missfire, 11psi, 14/3/09)
171rwkw @ Morpowa (dirty and untuned, 2860, full exhaust, cooler, standard pump, 14psi, somewhat naffed pump)
170rwkw @ Morpowa, same as above, but with gtr pump and mega rich mixtures.
PB of 1:27:00 @ Mallala.
On top of all that, its getting a brand new pair of kumho KU36's on the front in the coming days (rrp $560), the old KU36's will be moved to the rear.
And I'll throw in a set of blitz 550cc injectors, QFM A1RM rear pads (new), an ATS carbon single plate clutch (that needs a rebuild), and if wanted, i may be able to arrange a Z32 afm with plug for an additional $200.
I'll also be including, 4 stockies, 2 with legal tread, 2 without, standard dump and front pipe + cat, standard drivers seat, standard struts/arms/rod ends, standard front bar, standard intecooler/pipe work/bov, standard boost solenoid, spare rear garnish, spare bootlid w/out spoiler (does have holes).
I'm happy to remove parts to make it more affordable.
Its been religiously maintained, I don't stick to a service schedule so much as service it whenever I believe it's appropriate... or have nothing better to do. As such, it's been serviced with quality oils (at first, motul, more recently; elf excellium) and filters (nissan, and more recently k&n) every couple thousand kays (9+ times since purchase). It's most recent service was 2 weeks ago, changed oil, filter, plugs, fuel filter, and fitted a brand new k&n air filter. I'll be servicing it again in the coming days.
A compression test was performed mid last year for peace of mind, came back with 141-145 across the board, a leak down test was performed at the same time and returned results within factory tolerances.
A suspension safety checked was performed recently, with everything showing up apples.
And its passed regency with minimal work, standard wheels, borrowed standard exhaust (or baffle plate), standard boost controller, removed gauges, standard seat, and it's through without incident.
Now for the bad. there are a couple small chips in the paint, and some poorly repaired parking lot damage to the rear drivers side guard. I'll get pics of all this up later... and that's about it.
Basically, as it is, it's an lsd and a remap away from being whatever you want, drift car, grip car, hills car, or just leave it as is and have a bullshit tough streeter, it's up to you.
Hi SAU'ers.
Car: Nissan Skyline R32 GT-R
Year: 1992
Colour: Metallic black (looks super hot in the sun)
Drivetrain: Manual, Variable 4WD
Odometer: 98xxx
Power output: 269.4rwkw (Hi-Tech Dyno)
Rego: Till late June.
Mods: R34 GT-R Injectors (s/s casing), HKS pods, HKS cat back, s/s blitz front pipes, Cusco Zero1 coilovers 10kfront 8k rear spring rates (approx) which are great to ride on without bouncing all over the road no knocks or leaks what so ever, Work Meister S1 18x10 +13 all round which give the car a super tough stance, Nexen N6000 245/40's all round which offer a nice bit of stretch and these tyres hold the ground like sh!t to blanket 98% tread left, Car serviced every 3,000k's (every 3 months as I don't drive the car often), Running 14psi through bleed valve boost controller with no issues of boost spike, Nismo Ti gear knob, Nardi Torino steering wheel (all leather, suits the trim perfectly), Redline gearbox fluid (smurf blood ) put in maybe 2,500ks ago which won't need to be replaced for the life of the vehicle, transmax transfer case oil replaced at the same time, as well as a Excedy H/D clutch with custom 1,500kg pressure plate (easy hold 300rwkw), replaced rear main seal at the time of clutch swap and gearbox fluids change, Adjustable cam gears, Car received 100,000k service at 85,000k's (before I owned the car), which consists of water pump, timing belt, etc etc etc, dash lights, A/C lights, tripple din cluster lights are all blue however I do have all the standard globes to go with the car and if the buyer insists I can change them back, slight guard roll on the rear guards (too allow for the phat wheels) but no paint was cracked what so ever, perfect job. EBC Green stuff front pads with plenty of meat as with the standard rear pads, HID headlight kit
The trim is spotless on the whole vehicle, as with the exterior with the exception of a few tiny little defualts being a 18 year old car although is WELL ABOVE average. I am the 2nd owner of the vehicle in Australia and do currently have all of the import papers etc. I'm sure I have missed things about the car so should you have any questions don't hesitate to shoot me through a PM. I do love this car, and no I am not really in a rush if it doesn't sell so please save your time and my time and no low ball me, it is perfectly maintained, never tracked while I have owned it, it is the cleanest sounding RB26 I have heard ideling.
I am after $25,500 Firm.
Contact via PM or 0433830055.
Got a drift car, rego or no rego.. Want something you can daily and still be sickflamin mongrel? PM me. After drift car. Will require cash my way.
Thanks for reading,
Wayne.
hey guys, have some rims i no longer need as buying a new set for the new drift car.
First is a pair of Volk Gt-c's in 17x9, i think +24 offset but will need to double check. Included with purchase is the genuine Volk wheel nuts also which were imported from Japan to use. They have some scratches which most will buff out. Chasing $700 as is or $900 if i have the rims fixed. Will also include a pair of Federal 595 Evo's with decent amount of tread that are currently fitted to them for another $200(normally more than that each)
shot of most of the damage on the passenger wheel.
Next i have a full set of black 17x9.5 drifteks in 4/5 stud in gtr offset (+18 i believe). In good condition, couple scratches, come with tyres but 2 are dead, 2 still have bit of meat on them from what i remember. After $1000 for these with tyres.
Drifteks are pretty self explanatory but here is a pic.
(ones on the rear, thats how they sit without spacers, get your fitment on!)
Prefer local pickup but will post at buyers expense and buyer organising courier to pickup.
Drop $340...
Response 7" Double Din DVD player.
RRP $599 at Jaycar city store, asking $380. Enquire via PM.
Comes with Manual, remote, harness & mounting hardware.
Autobarn sell a Nissan to ISO wiring harness that will fit this headunit, that means plug & play, no wire-cutting/soldering for people who don't like to mess with that stuff.
Selling: was an impulse buy now I'm bored of it, want to go back to a single-din SQ deck.
2-DIN 7" motorised widescreen with touch panel controls
CD/DVD/SD card slot behind the panel
Rear USB cable (have this routed to my ashtray for easy access)
Bluetooth handsfree calling and A2DP (works with my iPhone fine)
DVD/VCD/CD/MP3/WMA/JPEG/DIVX playback
DVD/R/DVD/RW/CDR/RW
ESP and antishock mechanism
4 channels x 20W RMS power output
PLL tuner with 18FM/12AM presets
3x 6v Pre-outs (front/rear/sub)
2x Rear AV inputs (can use one of these for AUX in from a portable mp3 player/phone etc.)
1x Video Out
Remote control
Can take clearer pics on request once I get home...
For sale is 4 brand new (never been on a rim) Bridgestone RE001 Potenza Adrenalin tyres.
Size 225/45/R17 94W.
Bought for a car I no longer own.
The tyres are NOT; Rejects, seconds, damaged in any way either structurally or cosmetically and they do carry the usual new tyre warranty.
Price $780.
Price drop $720.
Hi all got a kenwood 7inch fold out touch screen dvd/cd/mp3 player for sale. It came in my stagea but im over it and want my normal cd player in. perfect condition, many add on's buy-able. still have instruction manual for it, many features. Comfirmed it is a ktv-747. pics of actual item to follow soon
comes with everything seen in the pics (no wiring diagram however)
these units still sell for $1400.00+ i've been told, so grab yourself a bargain for $900ono, or will trade for rb25neo parts/stagea parts
willing to post.
Hey just cleaning out my shed and i no longer need any of this. What i have to offer is
R32 thermo fan think its for gtr $25
Carbon canister for sr20det good condition $25
s13 engine mounts good condition $50
s13 prof muffler with 3.5 inch tip $70
Silk road adjustable castor rods in excellent condition to suit s13 r32 a31 and c33 $250 selling for a friend.
2x Bride brix 1.5 both with super low rail. Good condition sold my 180 so i took them out to lower the price. driver side will suit r32 and stuff and s13 because its a skyline rail with welded tab. pasanger side suit s13 s14 and s15. you could drill a hole to make fit a r32 or what ever you wanted. $1350
Can contact me on 0421950372 cheers
Hey guys just got this stuff to get rid of pretty quickly.
Full set of ROH Drift R's rims 17 inch by 8 inch wide 4 stud without tyres, unknown offset but sit just out side guards with a 25mm bolt on spacer on s13's. in alright condition,they all have gutter rash,1 rim has a bit of a buckle but not very bad and still holds air. 1 grand ono.
Pair of 4 stud 25mm bolt on spacers with wheel nuts. Will only sell these if the rims get sold, $100 ono. may chuck in for a cheaper price if u buy rims.
ISC 52mm Radiator to suit R33 but I think it will suit most imports. Only bought it about 5 months ago, in perfect condition and works perfectly $250 ono.
Next thing is a pair of aerocatches, there the next thing up from a bonnet pin as they cover up the ugly pin and are %100 legal. I was gonna use these on my 33 but never got around to putting them on. So they have never been used and are still in the box. $120ono
Cusco strut brace to suit R33 in good condition, $150 ono
Whiteline 22mm sway bar to suit R33 non adj, only bought it 5 months ago in perfect condition, and comes with all the parts to put it on ie) all bolts etc. can chuck in the links for a extra $40 bucks. $195 ono
Have a machined silver drift button to put on your hand brake, $10.
Have a Momo gear knob with the box and all the screws you need. Only bought it 6 months ago and its in perfect condtion with no scratches or tears. $150ono
Momo steering wheel with the horn but no center cap in pretty good condition has a 2 cm scratch on bottom of the wheel but dosent come with screws but there only bout 3 bucks from sprint auto parts. $170 ono
Also have a 16inch space saver $15
Have the rear seats out of a s13 in very gd nick $40 ono
Finaly have a Sony explode subwoofer and pioneer amp in a box. $250 ono
I have pics for everything listed but its not letting me upload them for some reason so if ur intrested send me a sms and I can send u a pic of what ur intrested in
Best to contact me on 0424383824
Cheers Aaron
Edited by Angry33
    • Hi everyone, I've found some free time to write up my "build thread" which is 10% 'build' and 90% fixing problems of a skyline that has endured a lifetime of abuse. I will start with the backstory & get everyone up to speed. Ever since I was just a teenager in high school I have had a spot in my heart for the shape of an R32 rivaled only by the look of an S13, my mates & I all having overly ambitious dreams as one does about having the sickest car in the school carpark. Unfortunately I started my journey of cars down the path of the Silvia and after spending years of putting up with the underwhelming SR20 life I dipped my toes into the 1J Toyota pool for a small moment until my true compass brought me back to that incomplete dream of an R32. At this point the trawl through marketplace, gumtree, carsales etc. starts looking Aus wide for an affordable example in the current economy which was extremely barebones compared to the good old days of sub 10k cars everywhere. Out of the handful of cars in the budget at the time I settled on a 1992 R32 GTS-T that was located in Adelaide. It had caught my eyes as it was similar price to the others on the east coast and had been RB25DET NEO converted and an open door respray in a custom colour based off TH1. It was also a stand out to me because it already had some NSW registration left which saved me the hassle of getting it on the road in my state. As for mods I was told it was pretty stock other than the motor swap, a nistune to run it, and an unknown fuel pump. My first mistake was trusting the seller blindly that the car was in good condition in all aspects and decided to purchase the car unseen other than some walkaround videos & pictures as the flights down there were very expensive at the time. The price of getting it transported to my door from Adelaide from Sydney was surprisingly cheaper than the flights at the time. I was told the few issues it apparently had was only 1 speaker not working, some cracked or missing trims, and it had been rear ended at some point but had been all professionally repaired (this is all foreshadowing at this point). I paid for the car, and then booked the interstate transport. Now at this point save your criticism as I already know how stupid I sound in hindsight, this was a major lapse of judgement and I accept the problems that followed. I spent the next 2 weeks in a crazed excitement knowing I am finally the owner of an R32 & that it was on its way. I started preparing as when negotiating with the seller I opted out of the Lenso wheels as they aren't really my style & I wanted a set of genuine wheels, and the bucket seats in the car as I am 6ft5 and not the skinniest guy so I had my predictions that I wouldn't fit in them anyway. Due to this the car was put on a set of R33 stockies and some average condition R33 seats that he had laying around. While I waited for the car to arrive I went and picked up a pair of R32 seats and some R32 GTR wheels to fit nicely on it once it had arrived. Being the first time I had done anything like this or had a car transported interstate I had no clue how the logistics of it were, I chose my work as the delivery address assuming it would arrive at some point in the middle of the day. You can imagine my surprise when I wake up to a call from the truck at 5:30am telling me his about 20 minutes away. When I tell you that was the fastest drive to work I have ever done, I managed to catch up to the truck before it even got there. Spent the hours before work taking in the car and living my first experience with one, I had never even been inside one so I spent some time getting familiar with the interior before doing the seat swap. Here is my first proper photo of it as the sun rose in the background. I also noticed it had the switch for the electronic front lip which was a pleasant surprised but sadly upon looking it didn't actually have the lip or the motors or even any wiring behind the switch. As I swapped the seats, the extremely questionable history of the car started to show itself starting with some really dodgy seatbelt buckles that had been extended for some reason with horrendous welds. This was followed by me noticing the drivers side front was quite bent up to which the owner then decided to let me know it had been hit in the front at the same time as the rear end. It also had a pretty leaky power steering rack and the pump was screaming for its life. By now I was a little on edge but I had to get to work for the day, I sent the car down to my mechanic to get the fluids changed and a general check over as I started to question what I had got myself into. I packed the GTR wheels into the car to get put on while it was there as I ran out of time which was a struggle because the handle to release the fuel door/boot was non-existent and just had the end of the cable tied to a bolt. It wasn't much of a surprise when I got a call saying that it looked like the fluids hadn't been done in quite some time. Although that didn't come as a shock, it did catch me off guard when I was told he couldn't open the boot which had the wheels in which I just had open not long before. Mission #1 was to squeeze through the back panel and open the boot from the latch while loaded with a set of wheels which to my amazement he pulled off after a bit of a struggle to reveal there was nothing holding the cable mechanism in place where it sits at the fuel cap. After that dilemma was solved the mechanic did an inspection over the car while on the hoist with nothing too interesting being found other than the expected crushed frame rails. It seems to have had some bilstein shocks installed at some point and judging by the AWD sump that has been sealed up I suspect the NEO is out of a stagea. By the time I got the car back and was ready to have my first drive home in it I was still excited but now quite anxious with the car already. First stop was to the servo to get a nice fresh tank of fuel as I had no idea how long it may have been sitting around for before I bought it. It sat quite nicely on the GTR stockies I must say. Now my drive home from work is short only being a 15-20 minute commute so the chances of anything going wrong is quite small right? WRONG. As I go over a speed bump only 100m from home I start to smell the dreaded smell of electrical burning and my lights drop out and shortly after the car dies. I am in extreme panic at this point thinking the car is going to burn down on its first drive before I have even had a chance to insure it. I move to the bonnet as quick as I can and lift it up, and as I go to grab the bonnet prop my brain is in such a frenzy that it takes me a second to realise my hand is being burnt to a crisp. This is where I notice that there is no plastic clip for the bonnet stay and when I have gone over the speed bump it has knocked the stay onto the positive terminal of the battery welding itself there. Levering it off with a nearby stick I sat there for a few minutes making sure nothing was going to burn down while waiting for a mate to come jump start me. My main stress was that I could've absolutely cooked the ECU or any other electrics. I was relieved when the car started fine with jumper leads on it but it would die as soon as the headlights were turned on so I carefully limped it home with no lights and decided it was a tomorrow task. You can see here where the stand sat on the positive terminal. Thankfully with a new battery the car behaved and seemed healthy. It was pretty smooth sailing for a little while getting to enjoy dailying the car. Interior wise it was pretty much as the seller described except for the the lack of working speakers, the digital controls had no power, and the headunit would randomly turn off & on. I installed a quick release I had laying around from an old car to help with getting in & out of the car and a nice momo wheel. I bought some oem side skirts to match the rear pods that were on the car already, who said a skyline can't be a practical parts mover. Test fit looks good! Found a good deal on a GTR wing & boot that I couldn't turn down. At this point the skyline was being too good to me and had to throw the spanner in the works again. First incident was as I was coming off the motorway and heard a bang and an awful grinding noise. As I pull over down a side street to investigate I notice my whole exhaust has basically fallen off and is dragging on the ground. After waiting around to let it cool to the touch I managed to get it back on its hangers. Thinking it was a weird 1-off instance I didn't think much of it until it happened to me again a few days later to which I see this time the middle hanger has snapped in half and the rear hangers have snapped at the welds. I manage to get the car in to a shop to get the hangers welded and while there I notice that my intercooler has broken its brackets and was being held up only by the piping. Quickly got that sorted and got some thicker brackets out of steel plate to support it all. Just when you thought at this point the car might give me a break, I fill the car up on my way home from the fabricators shop and after I pay I walk back to a good portion of my liquid gold on the floor. I just shrug it off at this point in exhaustion and call it a job for another day. The car had other plans for me though as the next morning on my commute to work, I am halfway there when I notice I am struggling to shift gears. I get lucky with a run of no red lights to work and find some time on my lunch break to investigate the problem. The slave wasn't leaking and the master still had fluid so I was left confused until I contorted myself under the dash and noticed the whole pedal moving loosely side to side when pushed in. Upon pulling it out of the car I found it to be multiple snapped spot welds on the clutch pedal bracket and the actual face of the pedal that sits against the firewall had snapped in half. I jerry rigged it with nuts & bolts at the spot welds but I will need to come back to this in the future and replace with one of the strengthened nismo brackets available. I then got to enjoy the car for another 2 months of cruising and dailying it, peep the obnoxious fireballs it would shoot every shift on the dodgy tune that was on there. On a sunday drive in that period of working car, I was on my way home on the motorway when I heard a slapping noise on my front left to which I pulled over to find my indicator had ejected itself from the car. Nothing a bit of tape can fix lol. I then bought some smoked indicators but after I realised I didn't like the look I found some damaged series 1 indicators. I repaired the tabs with some cut up cards and they looked good to me. My next venture was the hunt for some wheels, I test fit my mates Work Equip Spinning that were tiny 15" and I wasn't sold on the small wheel look. I ended up finding a killer deal on some Rays Volk Racing Group C in 17x8.5 & 17x9 that had been rebuilt many years ago and not ran on a car. I am still yet to get these on the car as they require some specific adapters and shank style lug nuts but I think they will look awesome. At this point my 2 months of reliability had ran out and on a cruise with some friends I suddenly lost the ability to shift gears again and thankfully could get it home by taking main roads and not having to stop. This time my master cylinder was bone dry and the culprit was the clutch slave that had decided to let go. It was a quick and fairly easy fix, but in my luck bad things always come in waves. Only a few weeks later I am on my way home from World Time Attack when the car completely shuts off while coasting down a hill, I try crank it while I still have momentum but no luck. Thinking I might have killed the fuel pump from running it low or maybe killed a CAS because the symptoms seemed to line up somewhat, I opt to get the car towed to a workshop to get fixed up on the Monday. When it gets there they get stuck into diagnosis and the CAS wasn't sending a signal to the ECU, and the fuel pump was also dead so it was comical for a small moment there. They replace the dead fuel pump when one of them notices some smoke coming from the passenger kick panel. Boy oh boy this is where it gets very bad and very expensive. I am not sure who wired the car when the NEO swap was done originally but I hope they never attempt auto electrical again as I am lucky that this handywork only managed to short and kill the ecu and engine loom and not do more damage. This is the point where you could say the 'build' started but not by choice. After some deliberation with my bank account I opted for a Haltech Elite 2500, RB terminated loom, and WB1. While I wish I stopped there and did the minimum of get the car running and leave it at that, I slipped into the rabbithole and decided I wanted to make the most of getting a retune and throw some bolt ons at it and see what it would do. I then threw together a bit of a mix n match build of marketplace deals starting with a GCG GTX3076R, a turbosmart FPR6, 980cc injectors, walbro 460, jackspanian ffp, throttle & fuel rail. At this point it was coming along nicely, the shop was making quick work of it and the bay was looking a lot nicer without the stock crossover intake. I also got them to replace the noisy centre bearing while it was off the road. Then we couldn't get an OEM CAS to talk to the haltech so ended up getting a PRP Street Trigger Kit for it.   While the car wasn't playing nice it decided to kill the stock alternator too so went with an LS1 alternator conversion kit. By now the car was pretty much done and ready to go but come tune day the car kept throwing the timing out every time it would warm up. Upon further investigation it seemed to be warping the PRP trigger bracket when the metal would get hot and expand which would cause the sensor to lose timing as it moves. Herman advised that they have seen the issue a few times now and don't know what the cause is. At this point I decided to switch to the PRP Pro kit with the crank trigger and considering the whole timing belt would have to come off I decided to get a new timing belt kit with water pump fitted. The car would now run fine with no issues and it was finally tune time. It ran up a healthy 275kw but ran out of boost due at 17psi to the rear housing being undersized. At this point the clutch also started slipping and due to it still being a weak RB20 box the tuner set it up to ramp from 8psi up to 17psi with the revs so that it wouldn't load up the clutch and box as hard. Car drives like a dream now. With the car back on the road I could return my focus to the smaller details, starting with getting a set of badges for the hood and quarters. I was struggling to drive with shoes on and I noticed that my accelerator pedal sits higher than my brake and clutch, if someone could confirm how it should sit that would be great. Next little changes was a killallwipers rear windscreen wiper delete, I also got some interior bits I was missing such as parcel shelf speaker covers, wiper trim cover, and boot floor and trims. Finally made it to a SAU NSW event which was awesome to cruise with a bunch of likeminded individuals. Another creature comfort I decided to look into was my lack of A/C. Since the Haltech got wired up the digital climate would power up now, and would blow but no cold air. First issue noticed was the lack of belt on the A/C compressor. After sorting that to no avail, it also had no A/C gas in it, but turns out the condenser has a huge leak. We are almost caught up on the story so far, but at the start of this month while coming into a driveway I heard a huge clunk in the front end to which I got out to witness whatever dodgy camber arms someone installed in this at some point decided to snap in half and I feel very lucky that it didn't happen at speed. Managed to get the car fixed the next day with some replacement GKtech arms. Next problem to address was the leaking gas tank from months ago. Checked the pump hanger seal first but that was fine, stuck my camera up after filling up to try scope out the leak which looked like the breather hose. Got the car up on a hoist prepared to drop the tank when I reached up to feel with my hand and I could feel that the hose clamp was missing and soon after felt that there was a gaping hole in the top of the hose. Replaced and tested and the car holds its liquid now and doesn't give me a fume headache whenever I drive it now. Finally have caught up and now onto fixing my latest issue which is the lack of dash light when driving at night, checked fuses first, then when searching I found the common problem of the headlight switch burning out but mine looks fine. Next test will be plugging a known working headlight switch into my car to tell if my switch is dead. Sorry for the long read but I wanted to be thorough, so if anyone made it this far I salute you soldier. Enjoy the rest of your day and I will keep this updated with issues I find/solve and any cool mods I can do inbetween. Merry Xmas!
    • can someone tell me what information a block number of 330680a on a rb25det engine specifies?
    • Would you suggest staying with a twin setup but upgraded turbos  ?
    • @Duncan hopefully they have a good hard look at Toyota. Both EVs AND performance vehicles!
