EOI
stock 34 gtt turbo 90ks
almost no shaft play... not of the car yet... as my new one is in the pipeline :D
ill have to check if the new one comes with lines n stuff.
will be off the car in a week or when ever someone really waves cash at me
$400
EOI
$400
PM sent
FS.
R32 GTS-t Type M 4 Pot Front Brakes (280x30mm) - calipers, rotors, caliper hardline. - $150 SOLD
JJR Coilpacks (RB20, S1 RB25, R32/33 RB26) - approx 18 months old - doesn't misfire or any of that rubbish. - $250 SOLD
RB20DET Coilpack Loom - good condition, no misfires. - $100 $50
RB20DET Turbo + Exhaust Manifold - turbo good condition, I never had a boost controller so was running on stock boost. - $150
RB20DET ECCS Inlet Manifold - complete with injectors, fuel rail, throttle body etc. - $150
PM/SMS. 0438858813.
Hey everyone up for sale i have a BRAND NEW good quality oil water line kit to suit RB20/25 with a gt series turbo (low mount) such as GT30 or 35/40
Includes:
2x 60cm braided water lines in -6 with banjo bolt ends and barb fitting for hose that runs around back of engine
1x 40cm braided oil line in -4
3x M14x1.5mm banjo bolts
banjo bolt end and banjo bolt for oil line
90 degree -4 oil fitting and nipple that screws into turbo
all required copper sealing washers
and a few other various 90 degree fittings that arent needed but come with it anyway
Asking $100
was taken out of packet for pic only
ALSO i have a blown c34 stagea turbo with op6 exhaust housing asking $50 ono
PM or call 0417 899 445 cheers lockie
R33 Series 2 Coil Packs - 6 of them.
Upgraded to yellow jackets as one of them was starting to break down occasionally, rest are fine. No idea which one was breaking down, but you get all 6 so great for spares if you dont want to fork out $400 for yellow packs!
$80 for all of them. NE Suburbs.
Still available. Will take $50 for a quick sale.
For Sale
Inlet and Exhaust Cam Shafts with Cam Gears off of a RB25DET Series 1 out of a C34 Laurel.
Price: $150 ONO, pick up or local delivery. Price is for Cam Shafts & Cam Gears Only, Backing Plate will be taken off - once I figure out how.
Got the following up for sale that i need gone, all located in the hills.
Genuine RB20 Water Pump - $80
Genuine RB25 S2 Water Pump - $120
^^ Both Brand New/Unused.
Cefiro Brake Master Cylinder, Looks almost new, hardly used - $50
HKS 2530 Turbo, in good working condition, minimal shaft play, nothing unusual for a ball bearing turbo. $1200 will be available by next weeekend as its still on my car.
Gizzmo EBC, later model with multi scramble feature. in perfect working order, removed due to not being needed. $150
RB20 Power Steering Pump and Alternator - $20 each
Pair of Enkei Circular wheels, PCD 4x114.3, 17x8 +34, in ok condition, few minor marks but nothing major - $250
Best bet is to contact me on 0407 633 573 as im not on here everyday, but PM's will be replyed to :yes:
Few Parts added, need these gone as i need the money!!
Edited by Jms_31
I have 2x gold drifttek for sale 17x8 5x114 not multi stud, not sure of offset but im guessing around the +34 mark comes with 255x40 rubber used but good, some light scratching on i think both rims will get pics up later
$550 all offers looked at, not all accepted
EDIT
because of where the car is parked i could only get a photo of the drivers side
colour, size, offset pics
for description of Hero tyres see >>Here<<
UPDATE 1 rim no good so price drop
1x 8.5" gold Drifttek $150
2x 255x40x17 $200
Includes:
Asking $100
pm sent
For sale are some Items off my 98 r34 gt-t
HKS GT 2540-46T, hasn’t done many Km’s upgraded to a bigger garret $1200 ono+shipping
Greedy 600X250X70 return flow FMIC, includes everything you need, clamps, joiners $320 ono+shipping
Stock rotors, plenty of meat left $50 each ono+shipping
Other items include
Qfm A1rm semi track pads 80% left $40+shipping
Stock r34 gtt brake lines $50+shipping
Stock intercooling piping$40+shipping
Located Port noarlunga S.A
0405326532
Please ask for pictures!!!
Hey all. I have a set of black drift teks for sale. They are 17x8 and 17x9 multi stud to suit Nissan. Tyres at 50% all round.
Asking $950 for the set.
Also have a Nintendo Wii package which includes:
Nintendo Wii with all fittings
2x Controllers with 2x nunchucks
Da Blob
Need for Speed undercover
Super Smash Bro's brawl
Wii Sports
$350 for the lot there
All items located at dernancourt SA.
Contact me on 0402 035 914. Can mms pics
Edited by Mowbuss
Bump
EOI
almost no shaft play... not of the car yet... as my new one is in the pipeline :P
$400
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
