Selling my mount and camera... mount is basically brand new, comes with box and support stand. rrp on the mount is $300 ish depending on where you get it from.
comes with cannon tape cam, with firewire cable and charger. its reliable as hell and takes decent footage.. cam is cheap enough not to worry about it if it gets damaged by having it outside the car.
Price $280 FIRM. +postage if sending it
upgraded my camera to Full Frame and P&S to M4/3
I have the following item for sale
Tokina 12 -24mm F4 Ultra wide Lens - Canon mount
Front Lens Cap
Rear Lens Cap
Lens Hood
Instruction Manual
in the original box
lens review - http://www.bobatkins.com/photography/revie..._f4_review.html
paid $700 plus postage from oversea under 2 years ago
$475
Canon G10 & underwater housing - WP-DC28
The original box, all of the original guides and documentation, strap, A/V connector, USB connector, software, battery charger, battery, etc.
All the original materials and accessories will come with the camera, in the original box.
also included
Brand new SanDisk 2g SD card
1 extra battery
tarmac camera bag
bought them from Harvey Norman & Sea Optic 13 months ago
housing used in 1 Fiji & 1 Cairns trip
Camera review - http://www.dpreview.com/reviews/canong10/
$675
contact via PM
item can be view during business hrs in CBD Pirie street
1x bottle of this: http://cgi.ebay.com.au/104-PLUS-IMPORTS-PE...rts_Accessories
In the link above its $30 including P&H but I'm selling 1 brand new un-open bottle for $20 pick up... or can pick up at the dyno day so you can add some more horse powahhhhh on the day!
Hi All,
I have a 3 inch Universal Ceramic Catalytic Converter high flow, Redback Australian Brand, Brand New, only opened to inspect the item. Perfect for anyone who wants to upgrade and get more flow from their engine !!:D
Reason For selling: Bought a full turbo back system, which already had a cat converter.
Price: $110 (i will post at buyer expense and will only use registered post cost $15) - 3 inch cat converters cost well over $200 delivered and that's online prices.
I also have a used 3A racing Cannon stainless steel muffler with 3 inch inlet in good nick few light scratches underneath. A little dusty but a wipe will make it all goods. This be ideal for the those who cant quite afford a full system yet, but still want to unleash the RB sounds of the engine. I had this on my standard R34 GTT (standard system just replaced muffler) and it sounded awesome not drowney or ridiculously loud, simply sxy sound you know what im talking about ;) The muffler measured a reading of 92DB - legal for SA (please note this is for turbo as NA cars will most likely be drowney) i had it on tested when i was going through regency due to being defected for tint and loose pod. This will fit directly to R34 GTT coming out on angle but can be made to fit any other cars at ease.
Reason For sale: Upgraded to full system
Price: $50 (prefer pick up,)
please contact me via email [email protected] ill get back to ASAP!! OR PM
I am located Adelaide.
Wrecking whole front end of an R32, all components except the long engine for sale, post here with what you're after.
Aftermarket Stuff:
R32:
3 .3 - 3.75" Cat-Back Exhaust: $400
Carbon Fibre Vented bonnet: $500
Sparco Drivers side seat rail (same as most other aftermarket rails): $150
Mechanical 1.5 way LSD + housing and half shafts: $950
N1 Headlight (driver's side): $200
Universal (for any car):
Short-shifter: $150
Sparco Rev Fixed Back Bucket seat (average condition, has tears etc) $200
R32/R33/A31 Bride Drivers side seat rail (same as most other aftermarket rails): $150
R32/R33/A31 Sparco Drivers side seat rail (same as most other aftermarket rails): $150
3-Point Harness: $50
MOMO "Race" Steering wheel with Nissan Boss kit: $200
GReddy SM Integration Guages + sensors + control unit (water temp, oil temp, oil pressure): $450
3-Layer Copper Radiator: $300
AVS Model 6, 17x9 +36 (pair): $400
Lightweight Jap Wheels (17x8.5 +35): $250
BBS RS 17x9 +20: $1000
Work Meister 18x9/10: $2950
Stock Parts
R32 GTS(t):
Suspension/Steering
2x Front Sway Bar - $50ea
2x Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
2x Front Camber Arms - $40ea -- PICS
2x Front Passenger side Lower Control Arm - $60 -- PICS
2x Front Complete Hub and Brake Assemblys including everything: $280ea
2x Rear Traction arms - $35ea -- PICS PICS
2x Rear Camber arms - $35ea -- PICS
2x Rear Lower Control Arms - $60ea -- PICS
2x Rear sway bar links w/ Urethane bushes - $15ea -- PICS
2x Rear Hubs - $100ea -- PICS PICS
2x Rear Complete Hub/Brake Assembly's including everything - $170ea
1x Rear Sway Bar - $50ea
1x Rear Subframe - $100
2x Rear Toe Rods (non-hicas) - $35ea -- PICS
2x Rear Toe Rods (hicas) - $50ea
Misc:
2x R32 Gearbox - $500
2x Indicators: $50ea
1x Horn, can be hooked up to any car - $20 -- PICS
2x Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
1x Stock Rear Spoiler (with brake light) - $50 -- PICS
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x RB20 Fuel Pump - $40 -- PICS
1x Igniter Module (breaks down under a lot of heat) - $30 -- PICS
R32 GTR:
Passenger Side seat with rails: $250
Front Grill: $150
R33:
Standard VLSD with housing and Half shafts: $300
R33 Lower Control Arms - $200pr
S13:
Located in SA near Mitcham, can Post Anywhere
Short-shifter: $150
PM sent
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
