For Sale Thread
Cubes
Hey All,
I've got an RB30 head i'm keen to get rid of, it came off a running engine that didnt have oil/water contamination so i reckon its safe to say it isnt cracked.
I was told it had noisy lifters but i think all it needed was an oil flush and some clean oil, now that its off it'd be a breeze to change the hydraulic lifters and slap it on :D
Asking $120.00 ono
Call or Text 0401 337 481
Edited by gottavision
FOR SALE:
HKS adjustable actuator (10psi)
$100
PM me
:D
Also got:
6 x coilpacks for RB25 Neo motor. One is shorting out, but silicone/tape will fix that. Misfires at 4,200rpm ... not noticable at all during day to day driving.
Easy fix. Or keep as spares.
$100
PM me with interest.
EVERYTHING IN MINT CONDITION FROM LATE MODEL SERIES 2 TURBO R33
Viscous diff (still works perfect) - $200
Complete front and rear brake/rotor, hubs, and knuckle assembly - $800
(good for 5 stud conversion on rear, just need s14/15 knuckles for front)
Rear cradle plus all arms excluding hicas setup - $300
(good for rb25 gearbox conversions)
Front Engine X-Member plus brackets - $250
(lowest combo for RB engine conversions, just use 40mm engine mounts)
Stock turbo - $400
R33 GTR TWIN TURBO setup including extractors and dumps with all stock lines - $1000
PM if interested,other parts available... no silly offers please.
For sale:
S14 Brake Rotors (280mm) and Calipers (4 piston). Front set only. Dont know what brand pads. $200
Comes with the stock rubber lines, caliper bolts, and a hug from yours truly.
R32 GTR intercooler core, inside is clean, in decent nick. $100
R32 GTR standard radiator $50
S14 SMIC with complete stock piping $100
R33 rotors, freshly machined. $100 Firm, itll cost you $50 to machine your rotors so why not save yourself the hassle and buy mine.
S14 front and rear seats in excellent condition, with rails. $150 firm!
R34 Gtt, $21,000 neg link in sig
pm me. pickup in wingfield.
R34 oil cooler and relocation kit. Used by previous owner for <5000k's, 18 row core and long lines. Comes with filter. $290
D-Project Rear Upper Adjustable Arms
- Simple Camber Adjustment
- High Strength
- Medium Carbon Steel
- Essential For Drift
Vehicle Compatibility:
- Nissan S13
- Nissan Cefiro A31
- Nissan Skyline R32 GTS-T
- Nissan Skyline R32 GTR
- Nissan 300ZX Z32
$150
JJR Front Upper Adjustable Arms
- Forged Steel
- Adjustable (+1 / -2 Degrees)
- Nissan Skyline HCR32
- Nissan Skyline BNR32
- Nissan Skyline Z32
$150
Apexi Mechanical Boost Gauge (PSI)
$60
All Items located in Victor Harbor, may be able to arrange delivery to CBD
1-nardii wheel with horn button, no horn cover/plate thing, good nick (I think its a 350mm refer to pic with 30cm ruler)$180ono
2-pair of ssr integral a2, 5x114.3 + 44, white, good nick just needs a clean, no tyres $190ono
Located around Pt Adelaide
0415382937
Ipaq 6960 PDA and phone
Still in full working condition. Had this phone for 3 years before upgrading. Originally purchased for $1200 new.
Selling $150
Bargain. PM me.
More info on the phone/PDA here: http://h20000.www2.hp.com/bizsupport/TechS...eriesId=1822486
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
