forsale!
set of work emotions cr kai, 17x8, 17x9 +20 wrapped in firestone 215's at the fronts, and wanlin 235's at the rears 50% all round, 5 stud, suit nissans $1750 ono
contact 0421340064 alex, pm's wont be replied.
sure! Wedding in November and recent purchase of house. I can provide proof of both if need be.
cheers
Ok, can you post up a picture of an empty block and a picture of your fiance with ring attached?
jokes mate, good luck with the sale
Item: 4 x 18" Kumho ku31 235/35
Age: BRAND NEW (never been fitted)
Condition: As Above
Price: $800 ono
To Fit: (What car) 18" wheels
Contact: Private Messages will be replied to within the Day
Comments: Yeh arghhh BRAND NEW COME GET THEM TODAY!
Hey
I got a set of 4 x ROH Drift R 17's I want to get rid off cos I want to get some Starcorp Impuls :D
The front 2 tyres have good tread and the rears have about 40%
Im asking $700 ono
Ive got a rear wing Im taking of my car within a couple days
$120 ono
Front Bumper (unsure what sort of bar it is)
*Make me offers*
Call or Text Martin on 0411 585 385 anytime 24/7 and I usually get back to text's within a few minutes
Front Bar Sold
Items:
Four 18x8.5+35 (5x114.3 pcd) Axia Rims
Item Condition:
Good condition, some small imperfections in the lip.
Extra Info:
Imported from japan 2nd hand, Gold centre and polished lip, only 2 rims have used Nankang NSII tyres that need to be replaced. Unfortunately they won't clear Nissan 4 piston calipers without spacers.
Contact Details:
[email protected]
Price and price conditions:
$700
sorry forgot to add
Comments:
All these parts are from a GTR R33 that has done around 90xxx kms. Was working fine when i took them out. Only replaced to up grade.
All prices are neotiable and im open to any offers so let me know.
Im in adelaide, pick up is fine but i can post at buyers expense. Also you can view before you buy also.
Item: 6 x GTR R33 Injectors $375 ono
Item: Standered R33 GTR fuel Pump $125 ono
Item: Standered R33 GTR cam Gears $100 ono
But again open to any offers
Fuel Pump Sold
GTR Rims Sold.
Injectors $275
Cam Gears $50
ONO!!!
For Sale
Blitz Nur spec stainless steel exhaust full system from stock dump back (includes front pipe and stock cat) good straight through system no majors dents or problems with unit. selling due to wanting to go for a different looking piece. Comes with silencer for rear cannon as well.
Make an offer as not to sure what its worth!!!!
Items:
KYB Super SR Special set of suspension (suitable for Nissan Skyline R32)
Item Condition:
Very good
Extra info:
Selling just because it's too low for body-kit on my R32. Otherwise in excellent condition.
Contact Details:
PM
$380 (negotiable)
DVDS FOR SALE!
BLADE BOXSET - $20
FINAL DESTINATION BOXSET - $20
THANK GOD YOUR HERE - $20
SAW 1, 2, 3 - $15
SILENT HILL, HOUSE OF WAX, GRUDGE 2, LAND OF THE DEAD, DAWN OF THE DEAD, DOOM
all $5 each..
PM if interested :)
r33 eyelids - $20 (painted KN6 metallic, decent condition)
ha ha. ,i enquired bout that car when i was in the market..its a nice ride! cheap to.
yeah my best mates car. twin turbo, even stock, really gets up and goes!! comes with audio too, way too cheap for $7250!
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
