Hi,
Looking to sell my Wifes 2002 model S15 spec R Silvia SR20 turbo engine. She has owned the car for last 5 years and never had any mechanical problems with it, car runs and drives excellent. engine never been modified. Car is in very good condition paint and body wise weel looked after.
Metallic silver paint
18" 5 spoke wheels
Automatic trans
Very economical to run.
Unmodified sr20 turbo engine
176,000kms (Driven by my wife for last 5 years 100,000kms, without any problems)
R32 GTR front and rear brake calippers
Reason for sale, wife has purchase new car.
Will add pics on weekend.
$14,900
Car is located in SA.
PM me.
Cheers
FREE:
R32 GTR front REO - bit dented, bolts up fine - get a hammer to straighten the middle up it'll be right
R32 GTR front bumper - minus lower lip, has a small crack
both could come in handy for them pro drifters out there looking for something to do the job when they eventually prang their front end
FREE:
SOLD! or taken or whatever
turbosmart dual stage boost controller
holds boost great, good response and no spikes
good condition, comes with rocket switch
$130 posted
located in adelaide
feel free to pm or sms 0413 733 433
cheers,
Lucas
Edited by stolen-gtr
What's the offset for the rims? will it fit V35?
5 Stud 18 Inch rims for sale was fitted on a R32 Skyline $250:
Has slight gutter rash, there is only one bad rash which i have posted a pic of the rest are very very tiny, Contact me if you have any enquires thanks.
This one aparently leaks on side. You can get it fixed for a small price at a professional place. The rest of that black stuff is just from a tyre you can peel that off.
2x Turbo timers for sale, silver one is brand new never been used $10 each:
Also have a R32 GTST spoiler for sale but dont have pics atm is gunmetal grey and in very good nic make a offer.
MOB: 0451 691 099
Leave a text so i can get back to you i prob wont be able to answer phone calls
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
