R32 GTR Trust Jasma Exhuast 3" Cat back, also have larger front pipes(inc cat) to go with sale(not sure if trust front pipe though)
Cat back is all heat wrapped
Reasonable cond, has had some ressy swaps in its life, but passed with 89db at regency on mine.
$250, northern suburbs
sms or pm
0413 247 219
700cc SARD injectors to suit RB26
Excellent condition, only 3500kms of use.
Injectors will be available after March 6th.
With Bosch 044 and Sard Regulator these have supported 430rwkws at Factory base fuel pressure / pump fuel.
$550 - Western Suburbs
Fitting available for a little extra.....
PM me
I have a full set of S14 seats if anyone wants them? Upgrade your shitty S13 or R32 seats! Comes with rails and seatbelts if you want them as well
$250, take front and rear off my hands!
HSD HR Coilovers - $1200.
AMPerformance Full Stainless Steel Exhaust - Split Dump, straight though with HFC & Blastpipes - $1100.
Full R34 Nistuned ECU - $500+Standard Ecu.
Velo Podium 2 Fixed Bucket Seat With Mounting Bracket - $1000.
Bronze Work Xd9's 18x9+30 18x10+18 - With current tires and a spare - $2200.
Factory Option R34 Fourdoor Monsoon Shilds - $300
KKR Pineapple Bushes - $60
12" Soundsteam Taranchula Subwoofer inbox - $300
Contact via PM or 0432 581 798
PM me
Just tried to Pm you but it didnt work, was going to ask you if the above your selling, would they fit in a rb25, thanks.
1) Item: R34 GTR Spoiler (Genuine)
Item Condition:
Good condition, Pearl White in colour, missing the adjustable part of the spoiler. (Can get carbonfibre copys of it)
Contact Details:
PM me
Price and price conditions:
Looking at 550 negotiable
2) Item: R34 4 door factory nissan side skirt LH
Item condition:
Good condition couple scratches and one crack where it goes into the wheel bay/arch area (apparently very common)
Navy blue metallic in colour
Contact me via PM
Price: $200
Located in WINGFIELD
1) Item: Cannon IP4300 duplex printer
Item Condition: Good condition, 1 of the black ink cartridges needs replacing pronto
Contact Details: PM me or ring me 0421932750
Price: $60 firm
http://www.canon.com.au/ftp/pixma%20ip4300%20techsheet.pdf
2) Item: Diamondview Flatbed Scanner
Item condition: Good condition
Price: $25 fairly firm might come down if you buy either or both other items
3) Item: Pro Color Compatible ink cartridge 2x Black large and small cyan magenta and yellow and the chip reseter
Suits: PIXMA iP3600/ iP4600/ ip4700
MP540/ MP550/ MP560/ MP620
MP630/ MP640/ MP980/ MP990
MX860/ MX870
Item condition: Brand New
Price: $45
Factory RB25 are side feed and GTR are top feed injectors, need to convert to top feed rail and need resistor pack as well. It can be done but I'll default to RB25 guru's to confirm.
ADR Monza fiberglass recliner with 180sx/s13
Decent condition just a little faded.
$150 with rail!
RS*R Front pipe suit 180sx/s13 with some 3" split dump pipe (think the dump pipe has a crack)and a dead o2 sensor still init.
$50 for it all
180sx old school bird bath wing painted in champagne. Paint and wing are in great condition and fit perfect.
$100
PRICE DROP!!
HSD HR Coilovers - $900.
Bronze Work Xd9's 18x9+30 18x10+18 - With current tires and a spare - $2000.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
