Nissan Skyline R32 with widebody kit front and rear (S15 SR20DET motor)
TRACK ONLY
Only reason for sale is the fact that I no longer have acces to the car trailer which I did otherwise after the fun I had in the hillclimb I just did I certainly wouldn't be selling it if there was a way I could get the use out of it I hoped to when i got the car.
If someone has a registered S13/180 they want to trade with cash my way i may consider it too.
Engine:
S15 SR20DET conversion (completed in japan)
TOMEI 256 cams
550cc injectors
HKS GT SS turbo
N/A SR20 throtlle body
GTR fuel pump
xforce manifold
rb25 airflow meter
'TRUST' FMIC
'GReddy' triple core radiator
straight through 3" Exhaust
Power FC and hand controller
HKS evc 4
211rwkw on 1.2 bar
Driveline:
S13 5 speed
OS geiken twin plate clutch
KAZZ 2 way diff
Suspension:
HKS coil overs
camber adjustable
Brand new Whiteline Adjustable 24mm sway bars front and rear
Brand new Kazama Adjustable Castor rods
hicas lock bar
drift pineapples
Strut tower brace
Drift button handbrake
Interior:
SPARCO driver's seat
GTR Passenger seat
sparco steering wheel
Apexi boost gauge
Bolt in half cage
Sparco Harnesses
Exterior:
body kit is genuine BN Sport kit
Work Meister's 18 X 10" & 18 X 12"
Full wide kit 30mm rear and 25mm front.
$12,000
0488446696
Edited by mr_rbman
Few RB25 parts left over from a recent engine swap, they're all from a S2 engine unless otherwise stated.
new headgasket $100
clutch fan $60
intake manifold $50
exhaust manifold $50
new exhaust manifold to head gasket $50
power steering pump $50
alternator $50
injectors and rail $100
coilpacks $100
s1 ecu $60
injector loom $50
throttle body with tps $50
r32(?) radiator $50
25det block (water/oil/sensors still attached) - 2 pistons damaged $250
Adjustable FPR $60 (I was told it was a nismo item but there is no brand/model/serial as far as i can see to identify)
PM enquiries.
Gizzmo Dual Stage Shift Light - $130
R32GTR Rear Brakes $250 - Brake ducts / genuine nissan rotors / Endless Pads / braided lines / rebuilt calipers excellent condition
RB26 ACL Head Gasket - used but good condition and REUSABLE. $100
MUST SELL all parts must go
R33 series II GTS-T
Driver and passenger door (no dents/damage, scuff mark and small paint chip passenger door as pictured)
both doors have handles but no barrrel locks, I believe passenger door has power window motor)
$50 the pair!!!
Front windows both driver and passenger (nil damage)
$50 the pair!!!
Rear re-bar as pictured (includes most bolts)
$50
PM for response
CAS - $50
new headgasket $100
clutch fan $60 $50
intake manifold $50
alternator $50
coilpacks $100
s1 ecu $60
injector loom $50
r32(?) radiator $50
PM enquiries.
Full set of R32 GTR rims $550
Complete with centre caps, 5x114.3 16x8 +30. Great lightweight wheel.
Has 225/50/16 Kumho KU31s all around, two just above wear bars, two just under wear bars.
S14 ABS VSLD manual 3.692 ratio shimmed diff $180
Shimmed by a known workshop a few thousand kms ago, new oil put in ready to go.
Cant afford a 2 way? buy this diff, tight as a locker, great for drift and circuit.
I dropped 2 seconds at Mallala after shimming it up, get that power to the ground reliably!
Factory S14 SR20DET sump $make an offer
Taken out of car to upgrade to bigger baffled unit
Whiteline eccentric camber adjustment bolts KCA414 $40
Adjust camber on the front struts, 14mm bolt, suits S14 and lots of others
180SX factory quarter window visor thingos $make an offer
Both have been snapped in two while in storage, could probably be glued back together
pm/sms for photos
R32 handbrake cable pair $10
Can provide photos on request.
Prices somewhat negotiable, make an offer, worst I can say is no!
Located north eastern suburbs SA. PM or SMS 0424085308.
Edited by subliminal
is anyone interested in some Bilstein Struts, with King springs, to suit 33/34GTR?
These struts are $$$$ and handle great, whilst still being legal height (just) and regency friendly.
I'd love some coilovers in okay condition. could organise swaps or swaps +cash either way
Hey guys
Have a blown s2 r33 turbo suit rebuild/high flow I'll take $20 for it.
Also have a s2 r33 wing was silver in colour but has been sanded back for respray includes brake light $30 and it's yours
Pm or call/msg 0423904934
Cheers jarad
PM'd re turbo
Hi guys,
No longer in the car game. And did a shed clean up and found a couple of items.
3 x gtr wheel keyrings (brand new) - $12 each
1 x H3 Mtec bulbs good for fog lights(Brand new) - $10
R33 series 2 gear shift surround with no coin box - $15
Got a car hydraulic jack set comes with two stand, hydraulic jack with long and short handle, 2 tyre stopper. Only used a couple of times. -$35
Brand new car audio cables in packaging. Will throw in all climps and cables i have sitting around. $25
All pick up in Marion. Text me at 0433 128 610.
brake bias gauges
1 set of longacre liquid filled brake bias gauges in a alloy dash panel
good condition
$100.00
0402258352 dean
sorry pic went in twice for some reason
Edited by mid life crisis
Got a few parts i want to sell to get my turbo rebuilt:
Q45 afm. 3 inch intake. Better upgrade than a Z32 i believe. $150
S2 RB25DET coilpacks. Good condition didn't missfire. Bought splitfires and no longer need these. Offers?
A set of rear R32 rotors. Calipers, pads, rotors and braded lines. Pads have 80% meat left. $150
R31 lower controll arms. Bought new ones from Nissan. Balljoints still good don't knock etc. $50 for both.
EOI:
Single piece tailshaft to suit a RB20 box in a HR31 coupe. New unis recently.
Large Nissan flag. Red Nissan letters and white background.
Pm me if interested.
Edited by Ad's
Hi Guys,
Selling a few brake spares after installing R34 stoppers onto my C34 Series 1 Nissan Stagea on ebay....
Series 1 owners get yourself some cheap pads ;-)
Front Brake Pads on Ebay
Rear Pads on Ebay
Rear Calipers AND Pads on Ebay
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
