Also forgot to mention I have some 33 GTR rims with Toyo R888 Proxes which aren't very old!
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $30ono
2: HKS Boost guage and loom (60mm) $50ono
3: Steel Mate 386M Remote Central Locking System (No Actuators came with kit) $60ono
4: 2x 5 stud 25mm Bolt On Spacers $100 - New Item - Need to sell spacers ASAP
Or take Boost guage and piller for $70.
Central locking kit was bought for my Daily but never got round to instaling it (Has never been used)
Boost guage will NOT come with vaccum pipe due to it being used for another guage.
$120
set of Superlow King springs suit R33, only used approx 2,000kms untill the previous owner upgraded to coilovers
$40
Pair of 5MM 5STUD Spacers only done around 60-70kms?
or will swap the spacers for a working 60mm boost gauge that comes with Vacc hose etc
PM ME!
photos can be seen here
>>>photos
Edited by MRRB
For sale is my gt3076r (hks 3037 equiv) with brand new .63 a/r front housing. Was rebuilt with brand new turbine and chra internals not long ago so turbo is basically brand new. It's t3 with Garret 4 bolt dump and ex gated. Proven performer for 300-350 rwkw
Price $1300. Can post at buyers expense
Pm me if keen
In adel Sa.
TYRES
ALL PRICES ARE AS PAIRS
14"
4x 185/65 - Supercat - 60% tread - $60
15"
2x 185/55 - Hancook Optimo (one is flatspotted a little) - 60% tread - $40
16"
2x 205/55 - Mismatched pair - 60% tread - $60
2x 225/50 - Sumitomo/BJ (mismatched pair) - 50-60% tread - $50
17"
2x 205/50 - Bridgestone Potenza RE040 - 60% tread - $70
2x 205/50 - Mismatched pair - 60% tread - $60
2x 215/40 - Fulda - 50-60% tread - $60
2x 215/40 - Mismatched pair - 60% tread - $60
4x 235/45 - Bridgestone Potenza RE050A - 60-70% tread - $80
2x 235/45 - Mismatched pair - 70-80% tread - $90
2x 255/40 - Michelin/Nankang (mismatched pair) - 40-50% tread - $40
18"
PARTS
UNIVERSAL
TRUST GREDDY gear knob: $50
Blitz Mechanical Boost Gauge: $80
Blitz Blow-Off Valve w/ mandrel bent 2.5" piping: $100
R33:
Wrecking Whole R33, tell me what you're after (no gearbox or ECU)
RB25 Engine, has everything minus ECU, turbo and injectors (can include some 550's for a little extra) - $1500
6x NISMO Sidefeed 555cc Injectors (RB25) - $500
Splitfire Coilpacks for RB25 S2 - $400
GTR style fibreglass front bar (rough condition, cracks etc): $50
R33 HKS SuperDragger Exhaust: $450
R33 APEXI Front Strut Brace: $100
R33 Rear Strut brace: $90
R33 FMIC kit: $250
pics:
http://img62.imageshack.us/img62/6750/img0119jq.jpg
http://img251.imageshack.us/img251/4927/img0120ks.jpg
http://img853.imageshack.us/img853/1916/img0121dg.jpg
R33 VLSD Diff with housing and half shafts: $220
R32 GTR
R32 GTR grill: $140
Brake Master Cylinder Stopper/Reinforcer (stops firewall flex) - $80
S/S HICAS Lock Bar (extremely well built): $120
R32 GTS-T
WRECKING R32 HALF CUT MINUS ENGINE PARTS AND GEARBOX (ask in here what you're after)
Mine's Tuned ECU (genuine with certificate of authenticity plaque), to suit basic mods up to around 200rwkw, standard sensors etc - $300
R32 GTR Style Bonnet with gts-t latch (GTS-t bonnet modified to look like GTR bonnet): $180
Stock R32 Parts
Suspension/Steering
R32 GTS-t M-spec Brakes, front and rear - $500
2x Front Sway Bar - $40ea
2x Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
2x Front Camber Arms - $40ea -- PICS
2x Front Passenger side Lower Control Arm - $60 -- PICS
2x Rear Traction arms - $35ea -- PICS PICS
2x Rear Camber arms - $35ea -- PICS
2x Rear Lower Control Arms (drivers side only) - $60ea -- PICS
2x Rear Hub Uprights - $100ea -- PICS PICS
2x Rear Complete Uprights - $70ea
1x Rear Subframe - $100
2x Rear Toe Rods (non-hicas) - $35ea -- PICS
1x Rear Toe Rod (hicas) - $50ea
Misc:
6x RB20 Injectors (standard) - $100set
1x RB20 AFM - $100
2x Doors, 2door, silver - $100ea
2x Clear Front Indicators - $60ea
2x Drive-shafts - $50ea
1x Horn, can be hooked up to any car - $20 -- PICS
2x Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
1x Stock Rear Spoiler (with brake light) - $50 -- PICS
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x RB20 Fuel Pump - $40 -- PICS
1x Igniter Module (breaks down under a lot of heat) - $30 -- PICS
located near mitcham in SA
4: 2x 5 stud 15mm Bolt On Spacers $100 FIRM - New Item - Need to sell spacers ASAP or straight swap for 20mm spacers
r34 parts
r34 5 stud rear brake setup,hubs,hand brake cables,everything there needed for conversion $300
diff with 5 bolt half shafts 4.111 $130
all arms $40 each
hicas rack $40
bare subframe $80
drive shafts $40 each or $70 the pair or take the complete subframe for $550....
front lower control arms $180
steering rack with x member $150
front hubs $30 each
washer bottle $20
one reverse light off a 2 door $30
stock caster rods $30 each or $50 the pair
clutch & brake pedal $400
clutch master cylinder $40
clutch fan with fan $60
air con compressor $150
r33 washer bottle $20
r33 rear subframe all arms there,hicas rack $150
r33 drivers door with glass silver $100 straight as! last time i checked.
r33 stock front pipe with cat $40
r32 2 door tail lights $80 the pair
r32 power steering pump $40
r32 aircon compressor $100 has been freshly serviced not long ago
r32 aircon condenseor $80
r32 gtr front bar with lip and mesh minor damage easy fix sms for pics $300
r32gtr resistor pack $40
r32gtr window switch $30
located in athol pk 0422030855
Edited by hcR324door
hey all,
selling my yokomo RC drift car, i just dont use it anymore..
had it for about 1.5 years but for 1 year of that it has been just sitting..
comes with:
yokomo top secret s15 package.
you get everything that comes with the pack when you buy it new (even box)
extras:
1 set of wheels with grip tyres
1 set of DISH wantanabe with drit tyres (new never used)
1 extra controller with reciever
1 bigger motor and control box with reciever
upgraded shocks (fitted to the car) stock comes with car
spare chassis with bits and pieces (almost complete, but in pieces)
tools
spare s15 chassis
spare ae86
spare r34 gtr (never used, no hose cut yet for posts)
3 batteries (big 3800, 1800, 1700?)
2x chargers
here are pics:
after $500 FIRM, this is easily a 1-1.2k package.
pm me or 0433 290 801
cheers
1. JVC KD-AV7100 in excellent working order (see video below)
Price drop $250 ($999 new)
Some main features:
50W x 4
7-Inch touch screen Monitor
Front USB Port (MP3/WMA)
SD Slot (JPEG/MPEG1,2/MP3/WMA)
DVD player (dvd/cd/jpeg/divx/mp3
ipod video/audio playback
pics & details http://www.skylinesaustralia.com/forums/topic/365423-jvc-kd-av7100-powermat/page__p__5830119#entry5830119
2. As new GReddy Full Auto timer, in perfect working order
$80
pic & details http://www.skylinesaustralia.com/forums/topic/365414-greddy-turbo-timer/page__p__5830052#entry5830052
Items:
PENTAX K100D Digital SLR Camera
Item Condition:
Perfect Working order & condition
Extra Info:
Icludes Camera body + standard lens + lens caps + strap + Sigma 70-300mm Zoom Lens + manuals + software + carry bag + battery + charger
Contact Details:
please email [email protected]
Price and price conditions:
$600 for the lot ono
Parts from a S2 RB25det 133xxxkm unless otherwise stated.
PM Enquiries.
new headgasket $80
clutch fan $35
injectors and rail $50
s1 ecu $50
injector loom $40
throttle body with tps $40
r32 radiator $20 (average condition, never used)
25det block (water/oil pumps/sensors still attached) - 2 pistons damaged $150
Adjustable FPR $50 (I was told it was a nismo item but there is no brand/model/serial as far as i can see to identify)
Speco mechanical boost gauge $20
CAS - $50
Crossover intake pipe with stock BOV - $35
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
