Have a new clutch slave cylinder for sale.
Bought new from Grand Nissan, fitted it then found out that's not actually the problem. Bought it for $120, will sell for $100.
Live in Sheidow park, delivery MAY be an option.
PM me for more details.
Joel.
R33 GTR rims with semi-slick Toyo R888 Proxes. (Couple of marks on the rims, tyre's approximately 70% tread left)
$2200
x6 R32, RB20DET injectors. (Working fine with no leaks when removed)
$25 ($5 each)
x4 R32 RB20DET disc's. (reasonable condition)
$30 ($10 each)
x2 16 & 17" tyres. ( just leagal)
$$$FREE$$$
G-Tech (As new)
$40
X-Treme Clutch-Heavy Duty to suit RB20DET (Condition unknown)
$30
Ash - 0488446696
R32 GT-R wheels with Toyo RE01-R 60% tread, good for track days
$800
R32 GT-R front brakes - Calipers, rotars, pads and lines included. Perfect for your R32 GTS-t, S13/S14.
$300 O.N.O
Will update with some photos when I can take some
Joel.
Was half dead at work when I posted this, forgot to mention it's for a s1 R33
For sale, 125cc Pit Bike, BRAND NEW ENGINE. Just put on, not even broken on. Hi-flow race carby, great condition pit bike. 1 down, 3 Up gearbox, all brand new. Looking for $800 cash, located in Stirling, Adelaide Hills.
Contact Via mobile phone, if no answer please txt as I am at uni during the day. 0432809975.
Cheers guys :)
Brand new R32 pair front guards
Fibreglass, Vented, oversized fender
$250 for the pair, pickup only from Morphett Vale
suit R32 GTR or GTST. simply fit to suit, and paint!
BUMP
$200 pickup
brand new never fitted
Up for sale!! These came off my series 2 r33.
TEIN Super Street Damper $600 O.N.O
Stock exhaust $100
Stock Cat $30
Spitfire coilpacks taken out of my series 2 r33. $300 o.n.o
Pm me if interested
Edited by kb-r33
R32/s13/180sx stock rear camber arms
R34 auto flywheel and torque converter
R34 starter motor
R34 throttle body
......R34 power sterring pump
R33 engine mounts
r32 passenger seat minta mspec
r32 half shafts
r32 rear 5 stud hubs
r32 boot linings
Extremely bare cut up S13 shell with all id tags and plates fs pm me not defected
parts are currently on the car but I'll start taking them off within the next few weeks
Splitfire coilpacks in rail - $450
Denso 440cc injectors on standard rail, guy replaced all o rings when I bought it, never fitted on my car sad.gif
- $450
Malpassi rising rate fpr - $150
Welded diff r33 4.11 i think, to fit r 32 just swap the rear hat on the housing - $150
Pair of lambo wheels 17x9.5+44 (can b reversed for mega dish) - $150 no shoes
R34 gtt turbo with elbow and actuator
etc no play great condition - 450
R33 elbow - 50
white East bear fibre bonnet plus flush bonnet pins- 500
Twin pipes straight through after cat, sounded ridonkulous on my rb20, 99db at 5000rpm with 3" dump straight through - 300
Metal intake pipe for flutters - 80
Decat pipe 3" 80
EEC boost controller withgauge hi lo setting with in car adjustability - 250
Really pains me to get rid of all the goodies But just can't afford to get defected with all These fines and shit
Will post pics and edit stuff when I get on a computer
0488 583 800 Jesse
Still for Sale:
* stock RB26dett Manifolds, Dump Pipes, Front 2-into-1 pipe, used harmonic balancer in excellent condition, used oil pump
$100 the lot, pickup only
* aftermarket fibreglass vented oversized Front Guards (front quarter panels), brand new, to suit R32
$200 pickup only from Morphett Vale
* 1x Apexi Multichecker display unit
$200 FIRM delivered via express post
"Monitors all various aspects of NISSAN vehicles using the diagnostic signal.
The Multi-Checker is a valuable diagnostic tool designed for most NISSAN fuel injected automobiles. The unit monitors and displays a wealth of information and is unmatched by any other similar diagnostic meter on the market today.
The unit displays vehicle speed and engine RPM both in real-time and peak hold modes. Injector pulse duty is displayed in percentages with a peak hold mode. The airflow percentage, ignition timing, horsepower display, torque display, and air-fuel ratio display add to its impressive list of functions.
The unit can also alert the driver to recommended up-shifting points and will sound an alarm as the air flow meter or injectors reach maximum capacity. A large, easy-to-read display clearly shows all functions and is back-lit in orange for easy nighttime visibility. The display can also be set to a bar graph mode for quick and efficient monitoring."
Vehicle Speed Display
RPM Diplay mode
Injector Valve Opening Ratio Display
Air Flow Meter Use Ratio Display
Ignition Timing Display
Power Display
Torque Display
Air/Fuel Display
Thanks, send me a PM if interested
For Sale
All items Brand New never used or fitted -
2 x Garrett GT2860R -5 Tubos $ 2500
18 x M8 x 1.25 Turbo Studs and Nuts for Garret Turbos $ 80
1 x Set of ARP Exhaust Maniflod Studs, Nuts and Washers for RB26DETT $ 160
1 x Genuine Nissan OEM Complete Engine Gasket Kit Set for RB26DETT R34 $220
1 x 1000Hp ATI Super Damper Crank Pulley (Part No. 917753) for R33 R34 RB26DETT $650
In Adelaide ready for pick up
Call me 0401 469 148
PRICE DROP
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $20 - $10ono
2: HKS Boost guage and loom (60mm) $50 - $40ono
3: Steel Mate 386M Remote Central Locking System (No Actuators came with kit) $50 - $40ono
4: 2x 5 stud 15mm Bolt On Spacers $100 FIRM - Need to sell spacers ASAP
5: R32 2door L&R boot trim $5 each (Left side has a crack at the flappy bit)-
Or take Boost guage and piller for $50.
Central locking kit was bought for my Daily but never got round to instaling it (Has never been used)
Boost guage will NOT come with vaccum pipe due to it being used for another guage. .
PRICE DROP ON MOST ITEMS
RB25det sump $35
R33 sr2 wing needs paint $30
GTR wing no end caps needs painting $180
R33 Air Conditioning Condenser gtst 1994 $40
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $40
R33 gtst fuse box and cover $20
R33 gtst sr1 bonnet hinge set $15
R33 gtst overflow and washer bottle $25 for both
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $60
R33 gtst battery tray need painting $10
R33 manual gear shift boot/plate $20
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $50
R33 clutch master cylinder $30
R33 RB25 skyline power steering reservoir with lines $20
RB25det fuel rail $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $60
RB25det sr1 aac valve $40
r33 gtst sr1 carbon bonnet $420
fiberglass vent (uncut vent) $60
rb25 turbo 45v2 has a blown seal $50
R33 gtst sr1 abs unit and bracket $65
R33 gtr intercooler (corrosion on bottom)$40
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $35
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$30
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 sr1 eyelids(they need prep work before paint) $15
Pics http://www.skylinesaustralia.com/forums/topic/364044-shed-clean-out/
pm me or 0435888239
Will post at buyers expense
Dave
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
