L&RH DOOR LATCH INSERTS $ 15
mint 180sx door trims
centre console with mirror controlls
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $400 with the front cut
bare 180 front cut minta totaly bar 150
R34
POWERSTEARING PUMP $80
AUTO CONVERTER $50
AUTO STARTER MOTER $80
R32
4 door bn kit brand new minus front bar $250
2 door bn sideskirts good nic $100
R33 STEARING COLLUM
BUMP!!!!!
R33 stock air box and snorkel with near new apexi pannel filter $70
By joey_5004 at 2011-07-14
r33 stock coolah with all pipes $50
r33 sers2 rear seat set in mint con $50
r34 set of GT-T rims with out tyres $170
r33 stock front shocks and stock rear springs$50
r33 aftermarket front bar, needs paint. has afew cracks and is missing the left hand side cover over the fog light $150
R33 seris2 front grill in silver.. has a clip or 2 missing and afew scratches $50
Pm or 0431528958 ..
BUMP !! everything needs to go .
1: R32 "A" Piller mounted boost guage trim to suit 60mm guage $10ono - Pending payment
2: HKS Boost guage and loom (60mm) $40ono - Pending payment
3: Steel Mate 386M Remote Central Locking System (No Actuators came with kit) $40ono
4: 2x 5 stud 15mm Hubcentric Bolt On Spacers $100 FIRM - Need to sell spacers ASAP - SOLD
5: R32 2door L&R boot trim $5 each (Has holes cut out for strut brace)
Or take Boost guage and piller for $50.
Central locking kit was bought for my Daily but never got round to instaling it (Has never been used)
Boost guage will NOT come with vaccum pipe due to it being used for another guage.
Items:
Hankook RS3 265x35R18 (x4).
Item Condition:
Brand New.
Extra Info:
Surplus from Superlap, and I don't own any 18s to use them myself post event. Locally approximately $395 per tyre. Very impressed with the grip of these tyres on a racetrack. Fantastic high performance street tyre. These are the tyres you want for Superlap clubsprint class. Available now.
Contact Details:
Via PM is fine.
Price and price conditions:
$1,200 FIRM. Pickup - Cash, EFT, etc.
Now with a picture!
have 4 18'' lenso wide track rims for sale 2 in perfect condition 2 need to be re rolled due too buying them already like that, comes with 4 tires in near new condition if i remember correctly. just sittin in the garage $200
Edited by gilly_ECR33
Could you pm me width offset tyres etc with pics
For Sale following items which i purchased but never got around to installing. Due to defects I have changed my mind on what i want to do with the car so this stuff needs to go.
Sard 600cc injectors $500
Greddy cam gears to suit RB26(new) $400
Sard FPR $80
Tomei Type A poncams $600 inc postage These are for BNR32/BCNR33 (RB26DETT).
A252X A269IN lift in ex 9:15
Apexi Power FC with hand controller (suit R32/R33 RB26DETT) 1000$
For sale.
R33 S1 Dash 100$ - Has 3 screw holes on the passenger side as seen in picture.
10 000k HID Kit - Used for a few months but working fine - 50$ (Blue light)
Cusco Strut Brace - Type OS (New but with some scratches) - 100$
hey i have a silver 4door shell.
the shell is pretty bare, not much inside worth using, lhs side doors are mint, 3 out of 4 door trims mint, handbrake cables (all 3) are there, rear subframe and all rear setup is there minus diff and rear steering arms.
no boot, rear bar, rear lights.
you can make some $$ off the handbrake setup and rear brakes and the rear subframe/rear shocks.
has rego 2months
needs to be gone this weekend...
$500
has rego 2months
$500
When can I grab the handbrake handle off of you?
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
