awesome value right there I can vouch for that product
I ran about 13.7 psi daily for about 3 years reliably
Matty see Martin when your ready to set it up I'm sure he would only charge what a power run would be worth 1 hour on the dyno at max so that may be between 70-150$
disclaimer obviously I am not the dyno operator and aforementioned price is only a guide/guess
Seems like the right idea. When they did my power fc we had some dramas with the boost control kit, so gareth put a manual bleed valve on and had it on and off the dyno in a matter of minutes! We had gone through alot of s**t and it was a dream come true to finally have the car running tip top. Above all that, no charge for dyno and i had to make gareth take a $50 note for the bleed valve! 10/10!
Back onto topic.. R32 GT-R factory front grille still for sale.. $150 (silver, perfect condition)
Also SRI hicas lock bar and bypass hose kit to suit s13/r32
Unused, still wrapped..
$100
FOR SALE: CP Pistons Sets-Nissan Skyline rb25 or rb26, 86.5 Bore
Features include:
- High strength aluminum forgings
- Super lightweight designs
- Fully CNC machined and balanced to +/- 1 gram
- Wrist pins included at no extra cost
- Accumulator groove included
- Double pin oilers, force fed from oil ring
- Pick lock grooves for easy lock removal
Comes Complete with:
(6)Pistons
(16)Locks
(6)Wrist Pins
(6)Piston Ring Sets
CP Pistons Sets-Nissan Skyline, part# sc7308
im asking $850 ONO, no reasonable offers refused
any questions please PM me, sms or call me on 0439262702
ARP NISSAN RB20 RB25 HEAD STUD KIT
THIS KIT COMES WITH: STUDS, WASHERS, NUTS, AND ASSEMBLY LUBE.
TO SUIT:
NISSAN RB20DE, RB20DET, RB25DE, RB25DET
Replace your stock head bolts with ARP heavy duty head studs. The stud design helps the head and the block equalize the pressure better thereby creating a much more even and consistent seal. It is recommended to replace the head studs/bolts with a new set if the head bolts are ever loosened due to metal fatique. Reusing an old and possibly warped or stretched head bolts/studs will sacrifice the seal between the head and block and may cause head gasket leak. This is a great an easy upgrade when doing an engine rebuild or building a race motor.
the studs are still in the box and have never been used,
im asking $200 ONO, no reasonable offer refused!
any questions feel free to PM me, txt or call me on 0439262702
RB20 - RB25 - RB30 main and rod bearing kit, .25 ovesize
ACL RACE SERIES PEFORMANCE BEARINGS
THIS KIT PRICE IS FOR A FULL SET OF MAIN BEARINGS AND CONROD BEARINGS THEY ARE STILL BRAND NEW AND STILL WRAPED IN THE FACTORY PLASTIC
BEARINGS ARE .25 OVERSIZE
$200 ONO, NO REASONABLE OFFERS REFUSED!
ANY QUESTIONS PM me, TXT OR CALL ME ON 0439262702
FOR SALE:
- HIS IceQ X Radeon HD 6950 - pretty much BRAND NEW as I've only taken it out of the box, fitted it up, havent powered up as I was short a PCI-e power cord(was going to get another one today but something has came up and rather the money) - I paid $291 posted a few days ago so it's under warranty and have receipt to prove - selling for $250 firm
Prefer SA buyers for the following to save postage so will post it up here and will open it up to interstate buyers in a few days
- rear upper adjustable camber arms to suit R32 GTR/GTST and maybe other Nissan models - $100
- pair of NISMO N1 turbos to suit RB26DETT, made 270rwkw @ 13-14psi - still on the motor, will have it out within the next day or two - $900
Expression of interest for now - let me know if you're keen, may or may not sell but currently very likely:
- RB26DETT cam covers, spark plug cover and timing belt cover - $350
- RB26DETT head - $800
Any questions feel free to PM me!
Selling a Greddy Emanage Blue.
- Universal Fuel / VTEC Harness.
- Laptop Cable
- Injector harness
- Ignition Harness
- Various connectors, cable-ties etc
- Warranty Card
http://www.ebay.com....=item2567593ce1
If a SAU member wants to pick it up before it sells will do for $300
for sale SR20DET complete engine minus turbo .Has all manifolds stater coil packs alt exhaust everything had slight bottom end noise when pulled out only 120xxxx on clock would say conrod shell bearing. want it gone need shed space and engine stand back for the RB 25.:thumbsup: $450
R33 gtst complete diff and craddle minus brakes and hubs $150 ono front cross member minus hubs and brakes $50 also a set of bilstiens for r33 say $100 ono
cheers
bilstiens and front cross member sold
cheers
    • It's actually really good advice. And I do try to do it. I actually have 2x 3KG dumbbells that sit right beside where I sit. And I look at them a lot. Use them a little. But I'm trying to do more with it. At the moment I'm going through a heap of weight loss too which will help. I cracked into the 85kg mark this week. My weight used to have me sit consistently between 93 to 95KG! That definitely doesn't help. I've also got POTS, which flared up after I got slapped with COVID a few weeks back, and POTS really smashes fatigue and stuff into you, and has a thing even called "excercise fatigue". Basically even the minorest "excercise" (walking from the garage to the house) causes fatigue! And one of the treatments (Other than a med I'm on) is also... Excercise... Ha ha ha So it's why I'm trying to play the game of "might as well" and trying to push through things. For ADHD specifically, the general recommendation is "excercise". When you dig deep into it though, while any excercise is good, the best type is "explosive" excercise. So training for a sport like squash, tennis, even soccer. Things where you need to get the whole body able to "explode" into a different direction change. They've found with explosive sports, (I can't think of the proper term they have for it) that it actually makes the brain grow and become bigger in specific areas. The areas where ADHD causes those parts of the brain to be smaller than normal! But definitely, trying to push myself, and break those bounds mate, and get healthier!
    • Be more active mate.. , not taking the piss ❤️, your long term health will love you for it I would think something like a kettle bell or 2 laying around in areas you go past during the day would be awesome for ADHD.... "Oh look, a kettlebell", and exercise helps your brain health as well My mates son was a bit of a problem child, diagnosed wirh ADHD, and some other things that had his brain occasionally doing loops, until we got him into a training program, the difference after he started training was amazing, he had more focus, and his fitness levels exploded, it is like he is a totally different kid to be around Brain chemistry something something Stay fit stay strong mate
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
