I have an RB Gates Timing belt here, still in it's original packaging for sale. Bought it earlier in the year, selling this as I've grabbed a nismo belt instead. These typically retail for $100+, I'm offering $80 .. kinda looks like:
Hi guys I have a few spare parts lying around the shed that I no longer require. Please have a look through the list and pm or text me if you are interested in any of the parts.
1) R32 pineapples (mint condition) - $40post-57119-0-83698700-1315315674_thumb.jpg
2) SR20 (5 bolt) 3.5 inch dump pipe - $20post-57119-0-17331700-1315315696_thumb.jpg
5) RB25 power stearing reservoir - $30post-57119-0-88538300-1315315759_thumb.jpg
7) SOLD
10) Aftermarket Fuel Pressure Regulator kit (brand new) - $50post-57119-0-40200800-1315315853_thumb.jpg
11) Pod filter (freshly cleaned, unsure of brand) - $15post-57119-0-31043800-1315315872_thumb.jpg
12) SOLD
13) RB25 standard conrods, bearings & gugeon pins (take the lot) - $50post-57119-0-22746500-1315315896_thumb.jpg
Pm or text me if interested
0400 259 598
Chris
For sale,
OEM Lexus 2008 RX350 18" Wheels and Tyres + center caps
Will fit cars like Toyota Kluger, Toyota Rav4, Prados, Lexus GS/RX/SC series.
Probably fit skylines, soarers, but you'll have to double check that.
Rim size : 18x7.5 +35 114.3PCD
Tyres : Maxxis 235/55r18
Condition : Very good, some very minor gutter rash. Heaps of tread left (will probably last another 18 months or so).
Price : $700.
Available after this saturday morning (getting new rims).
Fs
Almost complete 180 worth of parts except engine gearbox and front seats.
I have almost everything
Interior bits are mint !!
have front and rear crossmemebrs with everything on them
bonnet and hatch
tail lights
Shell has front end damage up to about struts is repariable but bare (can come as a rear cut perfect for someone who want to fix there rear end damege can also do roof cut iff u want it for sunroof hole)
Doors ones black with killa paint ones matt black have glass and motor in them
$$ All these 180 bits need to go send me some offer on what u need im desperate for cash to spend on my 32
I also am wrecking out a r3 4 door gts-4
The car has damge to roof and abc pillars on drivers side
is missing motor box front brakes guards and bonnet
has 32 gtr rear brakes and all that jazz
After resonable offer here.
Also have r32 4 door bn sideskirts and rear bar brand new !
r32 rear seat slight fade on top.
vn calais rear leather seat minta
stainless rb manifold
Contact me through pm The 180 parts i need gorne asap !
Edited by Ke55pig
i have a r31 for sale, currently in bits, but have everything to put back together......in primer but engine bay is painted a dark metallic blue, paint included. no engine or trans. has TI rims on it too.
$600 ono
please pm me here if interested
Thanks
Cara
Got some offset subframe bushes for sale atm. They are CNC made to a snug fit to replace your old worn rubber bushes. They are offset so you can fit a S14/15/R33/R34 rear subframe into your S13/R32/A31 etc. Locally made and high quality items.. comes with washers also.
$180 + $5 postage anywhere in Aust.
Pm me if keen.
R34 gtr power fc with hand controller $775
Os giken cam gears suit rb $320
Tomei type b 260 9.15mm cams suit 34gtr $550
Apexi weldina exhaust (oval type) suit 34gtr $1100
Rays ce28n 19x10.5+12 x4 with rubber $3900
Wheels and exhaust sold
Pfc $750 picked up by this week or will take up
A posted offer.
Cam gears are mint and the better of the designs (some threads ware out.
And cams get ur gtr idle sounding mad, and give great mid range torque :)
hey guys, I have a couple of sets of blast pipes lying around, kinda keen to get rid of them.
All pipes are single 3" inlet - Twin 3" exit, mild steel, never been used. Can be cut to length if required.
500mm Straight pipes - $125
300mm Shorty Blast pipes - $110
400mm Offset/Staggered drift pipes - $115
All pipes can be posted anywhere in aus for under $25.
Pm me, or call me on 0423 11 10 11
Offers welcome!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
