Hi guys,
I've got 2 sets of front 33 rotors (5 stud).
One set has heavy surface rust, very bumpy and are rather worn - $20
The second pair are in good nick, very small outer lip and could be used with just a light sand - $65
PM enquiries!
Hey Guys,
Looking to sell the below wheels / tyres.
The wheels have some gutter rash on them. 19", come with spacers as they are 5x 120 so not standard for Skylines.
Uncertain about offset etc, but they barely fit in the GTR.
2 Tyres are good, almost new.
2 Tyres are shocking as they have been grinded back by previous owner.
Looking for 400$ inc spacers
Pickup required.
Thanks,
Adrian
Price drop on following items.
Sard 600cc injectors $400 (suit RB26, uncertain if these will fit on rb25 fuel-rail so if somebody knows this it would be really helpfull)
Apexi Power FC with hand controller 800$ (suit R32/R33 RB26DETT)
RB25det sump $30
R33 sr2 wing needs paint $30
GTR wing no end caps needs painting(plastic) $150
R33 Air Conditioning Condenser gtst 1994 $35
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $35
R33 gtst fuse box and cover $20
R33 gtst sr1 bonnet hinge set $15
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $50
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
catco high flow cat 2.5inch 325mm long $50
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running car but hade different plugs to myn) $40
R33 rb25det charcol canister $20
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics (page 4) is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst false rear wall $20
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50
RB25det stock dump on black vht $20
pm me or sms 0435 888 239
Will post at buyers expense
Dave
Hi guys
up for sale is my black Velo gp90 racing seat. The seat has been used for approximately 1 year. It is in immaculate condition, it comes with rails to suit r32 Skyline and Rear parcel shelf harness mount bracket which fits in place of the rear drivers side speaker all included. $600ono contact Ben on 0421675373
Pair of Recaro SP3's in excellent condition, dark grey/black with red insert $450 ono
4x Adavan 032R semis 205/60/15 $350 ono
Dont get on here much, so best to message or call on 0413697162
R33 gtr speedo 62k. Price. $200
R33 s2/r34 AFM. $ 50
Genuine R33 S1 Bomex front bar $100
R33 Radiator. $100
R33 Clutch fan. $ 40
R33 Thermo fan. $ 40
Doors an windows. $250
R33 s2 Rear Garnish $ 20
R33 gearknob. $ 20
R33 Ashtray. $ 20
R33.Indicator stalk. $ 40
R33 Washer stalk. $ 40
R33 s1 Dash. $100
R33 gtr airbag Steering wheel. $150
S1. R33 dash an engine Looms $100
R33 ignition barrel an key. $120
S1 r33 interior. $150
wrecking almost complete 4 door 32
180SX
Mint 180sx door trims.
centre dash console
some small random carpet bits
L&RH DOOR LATCH INSERTS $ 15
2X REAR SEATBELT LATCHES $10
HANDBRAKE COVER $15
1X RANDOM SMALL VENT $5
FUSEBOX COVER - SLIGHT HOLE $5
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH MIRRORS - DRIVERS SIDE MISSING GLASS
DRIVERS PLASTIC DOOR MOULD
2 SETS 180SX TAILLIGHT GARNISHES
L&RH WIPERS
1X GEARBOX MOUNT steel minus rubber $40
BLACK GOOD PAINT DRIVERS DOOR 150 (incl glass latch and power motor)
BRAKE BOSSTER
L&RH PILLAR TRIM
MINT WHITE REAR HATCH $150
PASSANGER 180SX REAR WINDOW
REAR CAMBER ARMS $50
CA LOOM
MINT BONNET WHITE $160
GEARBOX HARD CHASSIR RUBBER COVER
CHAROOL CANISTER
L&RH TOP FRONT SEAT TRIM
UPPER DOOR PLASTIC INTIRIOUR MOULDS
L&RH SIDE PEAR LOWER TRIM
GOOD SHELL STRAIGHT FROM FRONT SHOCK MOUNTS BACK can be sold with front cut t use for repair $400 with the front cut
180sx sunroof cut
R34
POWERSTEARING PUMP $80
AUTO CONVERTER $50
AUTO STARTER MOTER $80
R32
CLUTCH SLAVE
door bn kit brand new minus front bar $250
2 door bn sideskirts good nic $100
r32 gtr roof lining
32 gtr roof cut
R33 STEARING COLLUM
Also wrecking a complete r32 gts4 minus motor trans couple lil bits
I have few more 180 bits then above let me know what u want and make offer need it all gorne
Pick up from barossa valley sa
Pm here or
email [email protected]
cheers
Edited by Ke55pig
Selling my daily, AU series 2 supercab ute
-250,000 k's
-Dedicated gas
-Super reliable
-Great stereo system
-Sports exhaust
-Colour coded canopy with heavy duty roof racks worth over $2k..
Used daily as a work ute and been great. Will tow pretty much anything up to a car. Large dent behind drivers side door, needs a new quarter panel.
$4500
PM me if you're interested!
Joel.
180SX
centre dash console
HANDBRAKE COVER $15
LEFT FOOT REST $5
1X FUSE OVER $10
FLEXI GEAR BOOT $10
L&RH WIPERS
BRAKE BOSSTER
L&RH PILLAR TRIM
CA LOOM
CHAROOL CANISTER
180sx sunroof cut
R34
AUTO CONVERTER $50
R32
CLUTCH SLAVE
r32 gtr roof lining
32 gtr roof cut
R33 STEARING COLLUM
Pm here or
cheers
How much for the 32 headlight switch and plug?
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
