For sale,
OEM Lexus 2008 RX350 18" Wheels and Tyres + center caps
Will fit cars like Toyota Kluger, Toyota Rav4, Prados, Lexus GS/RX/SC series.
Probably fit skylines, soarers, but you'll have to double check that.
Rim size : 18x7.5 +35 114.3PCD
Tyres : Maxxis 235/55r18
Condition : Very good, some very minor gutter rash. Heaps of tread left (will probably last another 18 months or so).
Price : $700.
Available after this saturday morning (getting new rims).
Better pics here :
More pics here:
https://picasaweb.google.com/105059765002586173562/LexusWheels?authkey=Gv1sRgCM6rjtGJ_o2PWA#
Will go $600 for them.
Re-conditioned gearbox to suit GTR - un-used since purchased from Status Gearbox & Diff Engineering, includes receipt and has warranty - $1000 firm
let me know if you're keen - 0433743661 :thumbsup:
32 or 33gtr? i know there the same but wat was it origanlly?
come with anything like shifter, transfer etc?
Pair of Recaro SP3's in excellent condition, dark grey/black with red insert $450 ono SOLD
4x Adavan 032R semis 205/60/15 $350 ono
Dont get on here much, so best to message or call on 0413697162
R33 Bomex Front bar $100
R33 Doors with windows/mirrors mint condition $250 for both
1x s2 33 gts-t AFM $50
R33 S2 rear garnish $20
R33 S1 DASH $100
R33 GTR Speedo 62k $200
r33 radiator $100
HKS SPF Pod $60
Clutch fan $40
Thermo fan $40
r33 turbo $100
R33 Airbag s1 GTR wheel $150!!!!
r33 S1 front & rear seats $150
R33 dash an engine loom $100
For sale: Velo Podium 2 in Sparco Blue trim
Item Condition: used for a few weeks
Price and price conditions: 700
Extra Info: custom trimmed in blue with white text, comes with Velo mounting bracket ADR approved seat!!
Pictures: below, thanks Lewis
Contact Details: Josh 0411742212
Delivery & Conditions of Delivery: pick up, can post if need be
only for sale as to new seat is almost here
http://www.velo.com.au/seats/
FS Assorted parts to clean my garage out - would like to get rid of this stuff
New Rb26 Tomei sump baffle still in box - $280
Used 70amp RB/CA alternator to suit GTS-T (not GTR) - $50
Used camber worn Toyo T1R Proxes 225x50 to suit stock rims - $50 for the 4
Used No-name circle earth kit - $50
Used R32 GTR Bilstein Shocks with Eibach Springs - $800 (neg)
Used Later series R32 cluster surround (carbon taped up, doesn't fit early R32's) - $150 (neg)
Used 6x R32 GTR 440cc Injectors - at least one of them leaks, haven't used them for 2 yrs - $50 for the lot
Used 12x R32 GTR Coilpacks - several don't work, I've never tested them - $50 for the lot
PM me for pics or further questions
-D
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
