R33 Bomex Front bar $100
R33 Doors with windows/mirrors mint condition $250 for both
1x s2 33 gts-t AFM $50
R33 S2 rear garnish $20
R33 S1 DASH $100
R33 GTR Speedo 62k $200
r33 radiator $100
HKS SPF Pod $60
Clutch fan $40
Thermo fan $40
r33 turbo $100
R33 Airbag s1 GTR wheel $150!!!!
r33 S1 front & rear seats $150
r33 Ignition barrel an key r33 $100
r33 Dash Surround $30
r33Dash vents $20
r33 glovebox $50
r33 rb25det s2 coilpacks $100
Parting out my R33 S1 GTST
Body is trashed, only body parts left it good condition are the boot and GTR wing. Think the headlights may still be okay too, but I'll have to check tonight.
Interior is mint and everything in the engine bay is available at this point. Will be sorting out prices and parts list ASAP but PM me if there's anything in particular you're searching for as I'm pretty strapped for cash at the moment.
Or alternatively, message me on 0466 690 617. Prefer no phone calls please.
Located in Adelaide hills.
Cheers, Joel.
man this car has been on sale for a long time. Have you tried advertising on NS, Car Sales, Gum Tree???
i dont have an NS account and if i do i have to post like 100times or something :S cars on gumtree aswell and carsales too...
Random shit up for sale;
Velo GP90 XL, Retrimmed by Velo a little over a year ago with extra material in the bolsters, on heavy duty fixed mount rail;
Haven't seen much seat time, been without a licence or it's just been off the road for most of the time since I had it done, so it's still basically new.
$600
Apex'i stainless manifold to suit S14/15;
Purchased it a few months ago to go with my BW turbo, decided to keep using the standard manifold instead. No cracks, sits flush against the head.
$250
Hybrid boost controller;
Complete. Upgraded to a Blitz Dual SBC.
$100
Standard S14 coil packs and ignitor.
Worked fine before I removed them, no missfiring at all. Upgrading to LS2 truck coils.
$200
All located in northern suburbs.
Contact me on here or on 0408961657.
Dave.
Cheers, Joel.
Actually looking at trying to sell the whole car at the moment, $5500 for the lot minus the turbo. SMS or PM me for more details.
Ok I have a pair of front r32 gtst adjustable caster arms and I gotta go through regency so don't want them. Will swap for a standard pair with good rubbers in them. Unsure of brand as there just silver in color but defs adjustable. Pm or msg me on 0433370776
For Sale: 2x 25mm 5 Stud Bolt On Hubcentric spacers, has all studs and bolts $100ono. Need to sell ASAP
Depending on location I will deliver or meet you halfway. PM or txt for details 0433 522 234 Tim
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
