180sx Manual 1992
TRACK CAR - ( possibly could be regoed again, was defected few years ago, stickers removed papers long gone )
Sr20 low klms engine
Remapp Speedlab Over 200atw
T28bb
Braided oil an water lines
Manifold ( is leaking )
ET zorst ( also has couple leaks )
Metal intake
Hybrid Fmic
Extreme Drift Clutch
Catch Can
Tein Coilys
Cusco Camber Tops
Cusco Rear Strut Brace
Whiteline Front Strut Brace
Nissmo Castor Rods
Locked Diff
Recent New Paint Custom Purple
17's ( 5 of )
Bn Kit (slight damage to front bar)
Baby Turbo Timer
Greddy Boost Gauge
Profec B EBC
Sports Wheel
$6000 possible swap prefer cash as too many projects
Txt on 0407 627 431 before ringing or pm/ reply to this thread, Cheers
Some Price Drops!!!!!
More Stuff added:
R33 Bomex Front bar $100 $50
R33 Doors with windows/mirrors mint condition $250 for both
1x s2 33 gts-t/R34 AFM $50
R33 S2 rear garnish $20
R33 S1 DASH $100
R33 GTR Speedo 62k $200
r33 radiator $100
HKS SPF Pod $60
Clutch fan $40
Thermo fan $40
r33 turbo suit hi flow as has blown exhaust wheel $100 $90
R33 Airbag s1 GTR wheel with steering column $150!!!! $120
r33 S1 front & rear seats $150 $100
r33 Ignition barrel an key r33 $100
r33 Dash Surround $30
r33Dash vents $20
r33 glovebox $50
r33 rb25det s2 coilpacks $100
R33 rear seats $100
Titanium cannon muffler 3 inch $100
3 inch cat back Blitz exhaust suit r33 $250
R33 a/c parts inc. Condensor, motor, engine block bracket with pulley, canistor and various lines $100 all up
R33 standard camber arms $50
R33 wiper bottle $20
Genuine d1 spec racing wheel nuts m12 x 1.25 $50 never opened
Turbosmart silicon reducer 3inch - 2.5 inch $15 never used
R32 gear
All seatbelts make an offer
Trust 3.75" cat back with cannon jasma approved $250 ono
Full mspec rear seats make an offer.
All aircon gear let me know what u need open to offers.
Digital climate controlling unit mint 30$
Full set of teritorys 400$ 17x8 baller offset
Pair of r34 stockies 17x7.5
Stranded j pipe with oem bov 50$
All boot trim make an offer
Contact 0435163144
180sx Manual 1992
T28bb
Metal intake
Hybrid Fmic
Catch Can
Tein Coilys
Cusco Camber Tops
Nissmo Castor Rods
Locked Diff
17's ( 5 of )
Baby Turbo Timer
Greddy Boost Gauge
Profec B EBC
Sports Wheel
SOLD PENDING PAYMENT
Series II RX7
12a Bridgeport
Series 4/5 high flow turbo
Microtech MT8X
Bolt in half cage
External surge tank and pump
Mazdaspeed 2-way
ROH Chicane 3 piece wheels 16x7
Trust fmic
Greddy Profec ebc
Rotaflow 3" exhaust from turbine housing back
Spares to go with (front guards, doors, calipers, rotors, diff centers, series I hatch glass, and most interior trim)
Would make an excellent cheap hillclimb/sprints car
$5,000 ono
R32 gear
Standard front bar silver 200$
Contact 0435163144
Nismo Front Camber Arms to suit R32
bushes are in good condition , some of silver paint is coming off.
quick sale $70
Phone or sms only no pm
pick up Tee Tree Gully area
Paul 0422444532
Edited by DR30RSX
3inch Blitz cat back exhaust system to suit r33. $300
Pack of 20 genuine Japanese D1 spec wheel nuts m12 x 1.25 $50 never opened!
R33 rear seats mint condition $100
Need these things gone!
Call 0417084638 as i dont come on here often
Cheers
Rb20 turbo mint, no shaft play 50$
R32/s13 seatbelts.
R32 3.75" cat back with cannon 200$
Gutted cat 3" 20$
R32 front reo
Lots of interior parts just ask
Pair 34 stockies 17x7.5 100$
Territory stockies x4 350$
Mint rear seats 100$
Contact 0435163144
R33 Bomex Front bar, to suit series 1, bit rough, good for track car or if you wanna tidy it up $100
R33 S1 DASH $100
r33 glovebox $50
Item: R32 GTR Camshafts
Condition: As well as expected from a working motor.
Reason For Sale: Was going to use them for custom regrinds (Tighe). However, since then I have gone for a different route.
Price: $100 ONO. Low baller's need not bother.
Pictures: Available on request. That being said - they are camshafts, if you have any issues with not having photos, your best bet is to see them in person!
Contact: 0401 317 009 or PM or [email protected]
Location: Eastern suburbs of metropolitan SA. Address will be given to serious buyer.
Postage: Can arrange - at buyers expense
Wanted to swap with cash included if needed, a set of Starcorp Impul shadow finish 18x8, 5x114.3 off an R32 GTS4 with near new rubber, x2 235x40x18 Nankangs and some other same size pair. Rims in good condition, a little bit of clear coat peeling off.
PM if interested,
Cheers
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
